E-wok Skrevet 29. november 2007 Rapporter Del Skrevet 29. november 2007 (endret) Nei, din naab, dette er ikke nye gamemodes! Dette er "bare" de nye offisielle MLG-reglene for Halo 3, altså versjon 3. Interessen er kanskje ikke så stor, men tenkte det kunne være greit med en tråd om dette.. Vil du spille med regler som gjør spillet mer balansert og "competetive", last disse ned og prøv dem med noen venner.. Here is a list of the v3 maps and gametypes. This list specifies the official maps for each gametype. Note that only MLG CTF on The Pit and Narrows are map-specific, the rest of the game types (Team Slayer, Oddball and King of the Hill) work for all maps. Read below for more additional details about downloading the maps and changes made to the v3 gametypes. MLG Maps MLG Guardian v3 MLG Iso v3 (Isolation) MLG Cstruct v3 (Construct) MLG The Pit v3 MLG Narrows v3 MLG Gametypes MLG TS v3 MLG King v3 MLG Ball v3 MLG CTF Pit v3 MLG CTF Nar v3 GB CTF Nar v3 GB CTF Pit v3 Game types are played on the following maps: MLG TS v3 is played on: MLG Guardian v3 MLG Iso v3 (Isolation) MLG Cstruct v3 (Construct) MLG The Pit v3 MLG Narrows v3 MLG CTF v3/GB CTF v3 is played on: MLG The Pit v3 MLG Narrows v3 King of the Hill is played on: MLG Guardian v3 MLG Iso v3 (Isolation) MLG Cstruct v3 (Construct) MLG The Pit v3 Oddball is played on: MLG Guardian v3 What follows is a detailed description of how to download the new maps and the changes we made moving from version 2 to version 3: How to Download To download Halo 3 files you do NOT need to be friends with the person who made them. All you need to do is go to Bungie.net, sign in (the same email under which your Halo 3 gamertag is registered) and download from that person's file share. The next time you sign into Halo 3, the game will automatically download them. All MLG Halo 3 game types from now on will be under the gamertag “MLG Gametypes”. To download the version 3 game types go to MLG Gametypes’ Fileshare and click on the “Download to Halo 3” links for each of the maps and game types. Each time you click on a “Download to Halo 3” link, Bungie.net will tell you that the download has been queued. The next time you sign into Halo 3, you will download the files. PLEASE NOTE: Bungie.net/Halo 3 limit your download queue to eight (8) at a time. Therefore, when you are downloading the MLG Game Types, Maps and Settings, you will need to queue up the first 8, then turn on Halo 3, let them download automatically (which clears your queue), and then go back to bungie.net and put the remainder of the files in queue. Version 3 Changes Notice that there are MLG and GB (GameBattles) CTF gametypes. Since GB matches are played online, and there are no referees, there cannot be an indefinite overtime. Instead, there is a 30 second overtime period. While this is not ideal, it’s the optimum solution. All Maps Sniper spawns 2.5 minutes Plasma pistol spawns every 90 seconds Construct Rockets added to top middle (Default Sniper Spawn) Sniper added to platform below default Sword spawn Battle Rifle replaced Carbine near new Sniper spawn Plasma Pistol added near default Sword spawn 2 Plasma grenades moved from default Sword room to Top Gold Lift 2 Frag grenades removed from Top Gold Lift Guardian Plasma grenades moved from Snipe1 to Snipe3 Carbine standing against ledge on top tree stump instead of laying down Extra ball spawns were erased due to never having multiple oddballs The Pit Camo removed from map Maulers moved into default shotgun spawns Plasma Pistol added in default Sword spawn room Initial spawns moved to Platform of each base Isolation Teleport added below each base that takes you to default Bruteshot spawn Narrows Maulers removed from default Power-up spawns Mauler added to Top Middle (default Rocket spawn) Initial spawns moved closer to top middle KoTH Locations Construct 1. New Sniper Spawn 2. Open Side Street (between purple and gold) 3. New Sniper Spawn 4. Closed Side Street (between purple and gold) The Pit 1. Middle under Sword Bridge 2. Left base (Facing rockets from Sword room) 3. Middle under Sword Bridge 4. Right base Isolation 1. Top Center 2. Sniper Bridge 3. Bottom center (in between bases) Guardian 1. Top Center 2. Top Yellow Lift 3. Top Center 4. Elbow The dimensions of the bottom center hills on The Pit and Isolation were modified so that the hill walls appear as spikes of varying sizes. This makes seeing into and out of these hills much easier. Fine endringer. 3x overshield på The Pit trengs, normalt er OS-et nesten ubrukelig på Pit i forhold til Guardian, så dette var bra. 110% damage og 11 skudd isteden for 12 fra BR gjør den litt bedre. Er jo mange av stor-gutta som har klaget på dette, altså at det for vanskelig å drepe folk med 4 bursts off-host pga. at det ikke alltid kommer 3 skudd ut elns. Tester muligens når jeg kommer hjem fra "jobb". Les flere detaljer om endringer på hvert map her: mlgpro.com Last ned her: MLG Gametypes’ Fileshare Endret 9. januar 2008 av E-wok Lenke til kommentar
Laland Skrevet 29. november 2007 Rapporter Del Skrevet 29. november 2007 Er det noen moduser hvor man ikke spawner før neste runde, slik at man ikke er rambo hele tiden men MÅ spille taktisk? Det er noe av det jeg liker med GeOW, og til nød Cs. (selv om jeg ikke liker cs, that is.) Lenke til kommentar
E-wok Skrevet 29. november 2007 Forfatter Rapporter Del Skrevet 29. november 2007 Er ikke det bare å lage selv da? Lenke til kommentar
roolf Skrevet 29. november 2007 Rapporter Del Skrevet 29. november 2007 Takk E-wok. Var ikke klar over at de hadde oppdatert settingene. Ikke det at jeg spiller så mye custom MLG med det hender. Lenke til kommentar
boffeeen Skrevet 29. november 2007 Rapporter Del Skrevet 29. november 2007 Nice at dem tok bort Shotgun, lille fi**e våpen ass. Det eneste som gjenstår er matchmaking i MLG rules. Lenke til kommentar
Landeplagen Skrevet 4. desember 2007 Rapporter Del Skrevet 4. desember 2007 Synes de nye reglene var dritbra. Gjorde det morsommere. Lenke til kommentar
E-wok Skrevet 9. januar 2008 Forfatter Rapporter Del Skrevet 9. januar 2008 Jihahohe, da var versjon 3 ute. Les alt i førsteposten. Lenke til kommentar
