Battlefield 1942 patch 1.3 er ute
så ingen andre topicer angående dette så jeg starter en...
Som mange vet har 1.3 komt nå og er opp å går på det fleste servere.
Jeg syns den var en stor skuffelse, glipp i lyd, virker som fps gikk ned og ping på 70 kan merkes bedre (folk spretter frem og tilbake)
Hva syns dere om denne?
Well, etter å ha spilt noen runder med 1.3 synes jeg patchen er på sin plass. 50% mindre skade på fly med assault rifles er iallefall bra... Litt sykt at du faktisk kunne skyte ned fly med ei rifle.
Ellers er jo map-loading optimaliseringen er stor pluss.
For de som ikke aner hva 1.3 gjør: (Selvsagt en copy&paste)
NETWORK/SERVER FIXES
-Optimization of server priorities to improve Net Performance
-Smoother object movements
-Text strings are sent to the server instead of ascii, resulting in smoother text entry.
-No Lag prediction if soldier is sitting in vehicle. This fixes
the problem of pilots getting shot out of the cockpit when in a
plane.
CLIENT FIXES
#Sound improvements and optimizations
-New and improved Sounds in 1st person view for the following weapons:
*Bar 1918
*Thompson
*MG42
*Browning
-New streamed sound implementation increases performance and
decreases memory usage.
-Problems with SoundBlaster Live on WinXP and Win2000
systems are solved
#Graphical Improvements
-New and improved fire animations in 1st person view for the following weapons:
*stg44
*bar1918
*mp18
*mp40
-New and improved models in 1st person view for the following weapons:
*stg44
*bar1918
#Gameplay tweaks
-Damage to airplanes from the following has been decreased by 50%:
*BAR
*StG44
*Thompson
*MP40
*AA GUNS
-Spreading when walking and shooting increased on the following weapons:
*BAR
*StG44
-Reloading time on sniper and engineer rifles reduced by 33%.
-Rate of ticket decay when a team holds more than half of the
command points has been increased on Head-on maps
-Rate of ticket decay when Attacker holds all the control points
on Assault Maps has been reduced by 40%, leaving a better chance
for the defender to retake a CP.
-Rate of ticket decay when the defender holds the map reduced by
40% on assault maps.
-Attacker / Defender ticket ratio changed slightly to defenders
favor on assault maps
-When going outside of the map boundaries, soldiers will take 20%
of their full health of damage per second (after being warned)
#Optimizations.
-Decreased Loading times for the game and map changes.
-SafeDisk check only when starting game and not when changing maps
#AI optimization
-The AI in single player mode is much improved. Bots now focus on close range enemies over long ones, especially when their current weapon is not suited for long-range
-Radio and voice command display now have a 'greyed out' look for
commands that the bots do not respond to.
#Menu
-Message window has been modified and is now separated into three
parts:
1) User generated chat (radio and chat text) - 4 rows
2) Game Info (capture control point etc.) - 2 rows
3) Kills (x killed y) - 3 rows
The number of lines for each message window can be changed as
long as it is at least 1 line and the total amount of lines
for all message windows do not exceed 12.
These chat windows can be manipulated through new console
commands (where 'int' is any number between 1 and 12)
chat.setChatMessageSize <int>
No. of lines for chat messages display
chat.seGameInfoMessageSize <int>
No. of lines for game info display
chat.setKillMessageSize <int>
No. of lines for kills info display
chat.setChatHistory <int> <int> <int>
Sets the no of lines for all 3 message displays at once
chat.chatInfo
Returns status on how many lines each message window in using.
chat.OldChatListStyle <0 or 1>
If set to 1, the the old (v1.2) message window model is used.
chat.OldChatListHistory <int>
No. of rows used if the old message window model is used
-New Ignore input Commands
You can ignore radio messages, radio sounds and also ignore
specific players using the following commands:
chat.ignoreRadioText <0 or 1>
If 1, No radio text is printed.
chat.ignoreRadioAudio <0 or 1>
If 1, No radio sounds are played.
chat.setIgnoreRadioAudioAndText <0 or 1>
If 1, both radio sounds and radio text is supressed
chat.getIgnoreRadioAudioAndText
Prints status for these settings
chat.addToIgnoreList <user id>
Ignores a specific user's chatting.
chat.removeFromIgnoreList <user id>
Stop ignoring a specific user's chatting
chat.ignoreList
Returns the list of ignored players
NOTE: you can find a user's ID by using the 'game.listPlayers'
command in the console
-Implemented TK Forgive and Punishment system.
By default, players have to wait 1 extra spawn wave for every TK
they commit and when they have made 5 TK's that are not forgiven
they will get kicked from the server.
By default, the server is in forgive mode.
There are 2 modes:
1) If you are killed by a teammate, you can forgive the killer.
The forgive options expires when you die again (auto-punish)
2) If you are killed by a teammate, you can punish the killer.
The punish options expires when you die again. (auto-forgive)
Admin Console Commands:
admin.spawnDelayPenaltyForTK <value>
The number of extra spawn waves applied
(1.0 = wait 1 spawn wave,
1.5 = wait 1.5 spawn wave.. and so on)
admin.banPlayerOnTKKick <0 or 1>
When set to 1, players are also banned when kicked for TK
admin.nrOrTKToKick <value>
The number of punished TK's before being kicked
admin.tkPunishMode <0 or 1>
0 : Punish Mode - Players are punished by default, until the
victim forgives the TK
1 : Forgive Mode - Players are forgiven by default, until the
victim punishes the TK
Client Console Commands:
game.TKPunish
Punish a TK (works only in Forgive Mode).
game.TKForgive
Forgive a TK (works only in Punish Mode).
-Vote announcement has new text color and icon.
-Added the possibility to tag specific players as a 'buddy' and make them more
visible in the minimap
game.addPlayerToBuddyList <playerId>
Add a user with to the buddy list
game.removePlayerFromBuddyList <playerId>
Removes a user from the buddy list
game.buddyList
Prints a list of your current buddies.
#Rendering optimization
-You can disable tri-linear filtering by adding the line
"renderer.useTrilinearFiltering 0" to your
Settings/VideoDefault.con
-SiS Xabre support
-Stripping and vertex-cache optimizing terrain patches.
Increases performance for vertex cache enabled T&L cards that are
vertex transform bound in BF. I.e. it reduces slowdown somewhat
when lots of objects are displayed on screen.
-Optimization of the font writer, decreasing memory usage.
-Possibility to add lightmaps on ships and boats which can highly
increase the visual effect
Er de Dice-dustene komplette idioter:
*BAR
*StG44
*Thompson
*MP40
*AA GUNS
AA GUNS?????? Det er jo det eneste våpenet som er beregnet på å skyte fly?? At et lite jagerfly tidligere kunne overleve en fulltreffer fra et slikt våpen var jo bare latterlig, men greit nok. Nå har det blitt enda mer latterlig skjønner jeg...
Skulle ønske de kunne slutte med de "patchene" sine. En patch skal jo forbedre spillet og ikke gjøre det verre :grumpy:
Hvis det fortsetter i samme stil vil vel neste patch fjerne alle våpen untatt kjøretøyenes og flyenes. :roll:
Jeg spiller singel player for det meste, litt LAN, men ikke via internet enda.
Får jeg da noe utbytte av denne patchen, eller ville det bare skape trøbbel?
Har også lasta ned Coral sea map patchen. Har jeg bruk for denne til dette formålet?
Kan dere ikke legge ut en link til en plass der du kan laste ned 1.3 :roll:
Er du helt amøbe eller? Det er jo bare å gå inn på de offisielle sidene til BF så finner du linker. Fragzone i sverige har også hentet ned filene.
Det er greit å være tafatt, men det får da være måte på...
