PCI 64bit på 32bit, mulig?
Det kan gå, men bare om forholdene ligger til rette for det.
http://en.wikipedia.org/wiki/PCI-X
"PCI-X is generally backward-compatible with most cards based on the PCI 2.x or later standard, meaning that, a PCI-X card can be installed in a PCI slot, provided it has the correct voltage keying for the slot and (if inserting into a 32-bit slot) nothing obstructs the overhanging part of the edge connector."
