Problem med å kjøre COD 4
dao
Tok denne her, ettersom jeg mener det er et problem med OS og ikke selve spillet. Sorry hvis det er feil.
Skal starte single player og får feilmelding:
C Run-Time Error
R6002
-floating-point support not loaded
___________________________
Fant følgende tips, men det blir i grunn litt kryptisk for meg, håper noen kanskje kan forenkle det for meg.
To fix by checking the following possible causes
1.
The program was compiled or linked with an option, such as /FPi87, that requires a coprocessor, but the program was run on a machine that did not have a coprocessor installed.
2.
A format string for a printf or scanf function contained a floating-point format specification and the program did not contain any floating-point values or variables.
3.
The compiler minimizes a program's size by loading floating-point support only when necessary. The compiler cannot detect floating-point format specifications in format strings, so it does not load the necessary floating-point routines.
4.
Use a floating-point argument to correspond to the floating-point format specification, or perform a floating-point assignment elsewhere in the program. This causes floating-point support to be loaded.
5.
In a mixed-language program, a C library was specified before a FORTRAN library when the program was linked. Relink and specify the C library last.
På forhånd, takk for alt hjelp!!
