Lost in Translation
someOen
Oii ...
Original English Text:
Sometimes, My mom use drugs ..
Translated to French:
Parfois, mes drogues d'utilisation de maman.
Translated back to English:
Sometimes, my drugs of use of mom.
Translated to German:
Manchmal meine Drogen des Gebrauches der Mammas.
Sometimes my drugs of the use of the Mammas.
Translated to Italian:
A volte le mie droghe dell'uso dei mammas.
To times my drugs of the use of the mammas.
Translated to Portuguese:
Às épocas minhas drogas do uso dos mammas.
To the times my drugs of the use of mammas.
Translated to Spanish:
A los tiempos mis drogas del uso de mamas.
To the times my drugs of the use of breasts.
:p
I am going to eat smash now!
Je vais manger le fracas maintenant !
I will eat the crash now!
Ich esse den Systemabsturz jetzt!
I eat the system crash now!
Ora mangio l'arresto di sistema!
Hour I eat the arrest of system!
A hora I come a apreensão do sistema!
Hour I eats the apprehension of the system!
¡La hora I come la aprehensión del sistema!
please wait while loading
attendez s'il vous plaît tout en chargeant
wait please while charging
warten Sie bitte bei der Aufladung
wait please during the loading
attesa prego durante il caricamento
attended I pray during the load
atendido eu pray durante a carga
taken care of I pray during the load
cuidado tomado del mí ruego durante la carga
taken care of taken from me request during the load
EVIG! Har helt ærlig ikke ledd så godt på flere år.
Jeg holder på å dette sammen av latter når jeg ser alle de latterlige tekstene som dukker opp.
Do a barrel roll
do a barrel roll
faites un roulement de baril
make a bearing of barrel
bilden Sie ein Lager vom Faß
form stocks of the barrel
formi gli stock del barilotto
forms the stocks of the keg
dá forma ao estoque do barril
it gives form to the supply of the barrel
da la forma a la fuente del barril
it gives the form to the source of the barrel
Try it for yourself!
Essayez-le pour vous-même !
Test it for yourself!
Prüfen Sie es auf selbst!
Check it for!
Controllilo!
Controllilo!
Controllilo!
Controllilo!
¡Controllilo!
Controllilo!
Endret av Lakus
Gjest Slettet-p4PIYwb6
:!: Dette var noe av det beste jeg har sett på lenge! Sitter her å ler for meg selv.
Får teste litt jeg også da.
how are you doing
Translated to Japanese:
しているどのようにあるか
It has done, how it is?
Translated to Chinese:
它做了, 怎么它是?
It has done, how is it?
Il a fait, comment est lui ?
Is it made, how him?
Wird es, wie er gebildet?
Does it become, how it in an educated manner?
diventa, come esso in un modo istruito?
it becomes, like it in a well-educated way?
torna-se, como ele em uma maneira well-educated?
becomes, as it in a way well-educated?
¿se convierte, como él de una manera instruída?
one becomes, like him of a well-educated way?
I love you
私は愛する
I love
我爱
I love
J'aime
I like :green:
Ich mag
I like
Gradisco
I appreciate
Eu aprecio
I appreciate
Aprecio
Esteem
Endret av Slettet-p4PIYwb6
i like south park
j'aime le parc du sud
I like the park of the south
Ich mag den Park des Südens
Gradisco il parco del sud
I appreciate the park of the south
Eu aprecio o parque do sul
Aprecio el parque del sur
Esteem the park of the south
how much wood could a woodchuck chop if a woodchuck could chop wood
combien de bois pourrait un coup de hache de marmotte d'Amérique si
une marmotte d'Amérique pourrait couper le bois
how much wood could a blow of axe of marmot of America if a marmot of
America could cut wood
wieviel Holz ein Schlag der Axt von marmot von Amerika könnte, wenn
ein marmot von Amerika Holz schneiden könnte
how much wood an impact of the axe of marmot could of America, if
marmot from America a wood could cut
quanto legno un effetto dell'ascia di marmot potrebbe dell'America, se
marmot dall'America che un legno potrebbe tagliare
how much wood an effect of the axe of marmot could of the America, if
marmot from the America that a wood could cut
quanto madeira um efeito do machado do marmot poderia da América, se
marmot da América que uma madeira poderia cortar
how much it works with wood a effect of the axe of marmot could of
America, if marmot of America that a wood could cut
cuánto trabaja con madera un efecto del hacha del marmot podría de
América, si el marmot de América que una madera podría cortar
how much an effect of the axe of marmot works with wood could of
XD
Endret av Kontorstol
Uhm...
Klikk for å se/fjerne innholdet nedenfor
The best movie i have seen is not Mission Impossible
Le meilleur film que j'ai vu n'est pas mission impossible
The best film than I saw is not impossible mission
Der beste Film als sah ich bin nicht unmögliche Mission
The best film as if did not see I am impossible mission
La pellicola migliore come se non lo abbia visto sono missione
impossibile
The better film like if it has not seen it is impossible mission
A película melhor gosta se não vir que é missão impossível
The film best likes if not to come that it is impossible mission
La película tiene gusto lo más mejor posible si no de venir que es
misión imposible
The film has taste more better possible if not to come that it is
impossible mission
Hvorfor så komplisert?
I love you
Je t'aime
I love you
Ich liebe Dich
I love you
Ti amo
I love to you
Eu amo-lhe
I love to it
Amo a él
Master to him
Kan ikke huske sist gang jeg lo så godt! :!:
"Drive down that road":
Drive down that road.
Entraînez une réduction cette route.
Involve a reduction this road.
Beziehen Sie eine Verkleinerung diese Straße mit ein.
Refer a reduction this road also.
Faccia riferimento una riduzione questa strada egualmente.
Face reference one reduction this road equally.
Redução da referência uma da cara esta estrada ingualmente.
Reduction of the reference one of the face this road ingualmente.
Reducción de la referencia una de la cara este ingualmente del
camino.
Reduction of reference one of the face this ingualmente of the way.
Denne er grov:
Go and fuck your dad and piss on his aunt while she does a blowjob for your sister.
彼女が姉妹のためのblowjob をする間、お父さんと性交し、彼の叔母さんで怒っている行きなさい。
While she does blowjob for the sisters, the father it has sexual
intercourse, is gotten angry with that aunt go.
当她做blowjob 为姐妹, 父亲它有性交, 被得到恼怒以那个伯母去。
When she makes blowjob is the sisters, the father it has the sexual
intercourse, is obtained angry goes by that aunt.
Quand elle fait le blowjob est les soeurs, le père qu'il a les
rapports sexuels, est fâché obtenu va par cette tante.
When it makes the blowjob is the sisters, the father whom he has the
sexual relations, is annoyed obtained goes by this aunt.
Wenn es bildet, ist das blowjob die Schwestern, der Vater, dem er die
sexuellen Relationen hat, wird gestört erreichte geht durch diese
Tante.
If it forms, blowjob the sisters, the father, are who he has the
sexual relations, disturbed achieved go through this aunt.
Se forma, il blowjob le sorelle, il padre, è chi i rapporti sessuali,
disturbato realizzato passa attraverso questa zia.
If form, blowjob the sisters, the father, the sexual relationships are
who, disturbed realized pass through this aunt.
Se o formulário, blowjob as irmãs, pai, os relacionamentos sexual
for quem, passagem realizada perturbada através desta tia.
If the form, blowjob the sisters, father, the relationships sexual
will be who, pass carried through disturbed through this aunt.
Si es quién la forma, blowjob las hermanas, padre, los lazos
sexuales, paso llevado disturbado a través a través de esta tía.
If he is who the form, blowjob the sisters, father, the sexual loops,
kept step disturbado to traverse through this aunt.
Jævlig lang historie laget av meg
When the cat comes to me at night, I usually give it milk. But this time, it got followed home by the Cat Police. I was so scared. What did she do? The Cat Police Offiser told me that my little kitten had sold drugs at all the school in Kittyville. When the Cat Police Offiser had left, I spanked my little kitten. It meowed and meowed but I keept doing it. At last she pulled of her gun and shot at me. But she is such a noob to shoot so she missed every god damn shot. I laughed like a maniac to her and punched her face. She tried to get the gun again. She got it! Oh no! I started apologizing but she shot against me again and again and again! It was horrible! But then, the Cat Police Offiser came back. He saw my little kitten was shooting at me. He pulled of his nitestick and crushed her skull to pieces. I laughed her in her face. She took the Cat Police Offisers gun and aimed at me. I did a matrix emote while she shot, and she missed. Then I tried a uppercut on her and got her. The Cat Police Offiser put handcuffs on her and took her to his car. I waved goodbye to her. She went to jail. I visited her every day. She told me she was gonna take revenge. So the next day, I visited her with a gun and headshotted her. I went to jail in the same cell as my daughter. Then we fight every day after that.
Story by Almadora at http://www.diskusjon.no
猫が夜に私に来るとき、私は通常それにミルクを与える。しかし今回、それは猫の警察によって起点に続かれて得た。私は従っておびえさせていてあった。彼女は何をしたか。私の小さい子ネコがKittyville のすべての学校で薬剤を販売するように猫の警察Offiser は私に言った。猫の警察Offiser が去ったときに、私は私の小さい子ネコを平手で打った。それはmeowed 、meowed それをするI のkeept 。最後で彼女は彼女の銃のそして私で撃たれて引っ張った。しかし彼女は撃つべきそのようなnoob である従って彼女によってはあらゆる神のののしりの打撃が抜けていた。私は彼女に狂人のように笑い、彼女の表面を打った。彼女は銃を再度得ることを試みた。彼女はそれを得た! オハイオ州の否! 私は謝り始めたが、彼女は私に対して幾度もそして再度撃った! それは恐ろしかった! しかし一方では、猫の警察Offiser
はもどって来た。彼は私の小さい子ネコが私に射撃だったことを見た。彼は彼のnitestick の引っ張り、部分に彼女の頭骨を押しつぶした。私は彼女の表面の彼女を笑わせた。彼女は猫の警察にOffisers 銃を取り、私に向けた。私は彼女が撃つ、彼女は抜けていた間、マトリックスを感情を表に出すし。そして私は彼女のuppercut を試み、彼女を得た。猫の警察Offiser は彼女に手錠を置き、彼の車に彼女を連れて行った。私は彼女にさようなら振った。彼女は拘留することを行った。私は毎日彼女を訪問した。彼女は彼女が gonna の取得復讐だったことを私に言った。そう翌日、私は銃との彼女を訪問し、headshotted 。私は私の娘と同じセルで拘留することを行った。それから私達によっては毎日がこと後戦う。
http://www.diskusjon.no のAlmadora 著物語
When the cat comes to me in the night, I usually give the milk to
that. But this time, that could you following to origin, with the
police of the cat. As for me therefore it had made can to have. Did
she do what? That the child cat where I am small sells the medicine in
all schools of Kittyville, you called police Offiser of the cat to me.
When police Offiser of the cat goes away, I struck the child cat where
I am small with the open hand. As for that meowed and I keept which
does meowed that. Being last, she pulled her gun and being I, being
shot. But she is that kind of noob which it should shoot and therefore
depending upon her, shock of denunciation of all God had come out. I
laughed, in her like the demonian struck her surface. She tried the
fact that the gun is obtained for the second time. She obtained that!
No of Ohio state! I started apologizing, but she and shot many times
for the second time vis-a-vis me! That was fearful! But with one side,
as for police Offiser of the cat it returned. He looked at that the
child cat where I am small is shooting in me. He crushed her skull in
the pulling and the part of that nitestick. I could amuse her of her
surface. She took the Offisers gun in the police of the cat, directed
to me. I shoot her, she while having come out, the matrix puts out
feeling to the table and. And I tried her uppercut, obtained her.
Police Offiser of the cat put the handcuff in her, kept accompanying
her in that car. As for me in her the way if it shook. She did
detaining. I everyday visited her. She called the fact that she is the
acquisition vengeance of gonna to me. So, the next day, I to visit her
of the gun, headshotted. I did as my daughter detaining in the same
cell. Then depending upon us, everyday after the thing it fights.
Http: The Almadora work story of //www.diskusjon.no
当猫来到我夜, 我通常给牛奶那。但这时候,
那能您随后而来对始发地, 以猫的警察。至于我因此它做罐头有。她做了什么? 我是小卖出医学在Kittyville 所有学校的儿童猫, 您叫警察Offiser 猫对我。当警察Offiser 猫走开, 我触击了我是小用未结手的儿童猫。至于那meowed 并且的I keept meowed 那。是前, 她拉扯了她的枪和是I, 被射击。但她是它应该射击和因此取决于她的那noob, 所有上帝的指斥震动来了外面。我笑了, 在她象demonian 被触击她的表面。她尝试了情况枪第二次被获得。她获得了那! 没有俄亥俄状态! 我开始道歉, 但她和第二次射击了许多次关于我! 那是可怕的! 但以一边, 至于为警察Offiser 猫它返回了。他看那儿童猫我小是射击在我的地方。他击碎了她的头骨在拉扯和那nitestick 的部份。我能使她她的表面发笑。她采取了Offisers 枪在猫的警察, 被指挥对我。我射击她, 她当出来, 矩阵投入感觉对表和。并且我尝试了她的uppercut, 被获得她。警察Offiser 猫投入了手铐在她, 保留伴随她在那辆汽车。至于我在她方式如果它震动了。她做了扣留。I 每天被访问她。她叫情况她是购买复仇去我。如此, 次日, I 拜访她枪, headshotted 。我做了作为我的女儿扣留在同样电池。然后取决于我们, 每天在它战斗的事以后。Http: //www.diskusjon.no Almadora 工作故事
When the cat arrives my night, I usually give milk that. But this
time, that can you afterwards come to the initial sending place, by
cat's police. As for me therefore it makes the canned food to have.
What has she made? I am the retail leave the medicine in the
Kittyville all schools child cat, you are called the police the
Offiser cat to me. When the police Offiser cat gets out of the way, I
have struck me am young with the child cat which has not tied the
hand. As for that meowed and I keept meowed that. Is front, she has
pulled her gun and is I, is fire. But she is it should fire and
therefore is decided by hers that noob, possessed God to criticize
vibrates outside. I have smiled, looks like demonian in her to strike
her surface. She attempted the situation gun second time to obtain.
She has obtained that! Without the Ohio state! I start to apologize,
but she and second time has fire many time about me! That is fearful!
But take the one side, as for it returned as the police Offiser cat.
He looked that child cat I am young am the fire in mine place. He
crushed her skull to pull with that nitestick part. I can cause her
her surface to laugh. She has adopted the Offisers gun in cat's
police, is directed to me. I fire at her, she when comes out, the
matrix investment feeling synchronizes watches with. And I have
attempted her uppercut, is obtained she. The police Offiser cat
invested the handcuff in her, the preservation follows her in that
automobile. As for me in her mode if it vibrated. She has made the
detention. I is accessed every day she. She is called the situation
her is the purchase takes revenge I. So, next day, I visits her gun,
headshotted. I did had taken I the daughter detained in the same
battery. Then is decided by us, every day fights in it after matter.
Http: //www.diskusjon.no Almadora work story
Quand le chat arrive ma nuit, je donne habituellement à lait cela.
Mais cette fois, celle peut vous viennent après à l'endroit d'envoi
initial, par la police du chat. Quant à moi donc il fait la
nourriture en boîte pour avoir. Qu'a-t-elle fait ? Je suis le congé
au détail la médecine dans le Kittyville tout le chat d'écolier,
vous m'appelle la police le chat d'Offiser à moi. Quand le chat
d'Offiser de police sort de la voie, je m'ai frappé des jeunes de AM
avec le chat d'enfant qui n'a pas attaché la main. Quant à cela
meowed et le keept de I meowed cela. Est avant, elle a tiré son
pistolet et est I, est le feu. Mais elle est lui devrait mettre le feu
et donc est décidée par le sien que le noob, Dieu possédé à
critiquer vibre dehors. J'ai souri, des ressembler à demonian dans
elle pour frapper sa surface. Elle a essayé fois de pistolet de
situation la deuxième d'obtenir. Elle a obtenu cela ! Sans état de
l'Ohio ! Je commence à faire des excuses, mais elle et la deuxième
fois a le feu que beaucoup chronomètrent au sujet de moi ! C'est
craintif ! Mais prenez l'un côté, quant à lui est retourné comme
chat d'Offiser de police. Il a regardé ce chat d'enfant que je suis
jeune AM le feu dans l'endroit de mine. Il a écrasé son crâne pour
tirer avec cette pièce de nitestick. Je peux lui faire rire sa
surface. Elle a adopté le pistolet d'Offisers dans la police du chat,
est dirigée vers moi. Je mets le feu à elle, elle quand sort, le
sentiment d'investissement de matrice synchronise des montres avec. Et
j'ai essayé son uppercut, est obtenu elle. Le chat d'Offiser de
police a investi le menotter dans elle, la conservation la suit dans
cette automobile. Quant à moi en son mode s'il vibrait. Elle a fait
la détention. I est consulté chaque jour elle. Elle s'appelle la
situation qu'elle est la vengeance I de prises d'achat. Ainsi, le jour
suivant, I visite son pistolet, headshotted. Je avais pris à I la
fille détenue dans la même batterie. Alors est décidé par nous,
combats de chaque jour dans elle après matière. HTTP : histoire de
travail de //www.diskusjon.no Almadora
When the cat arrives my night, I usually give to milk that. But this
time, that can come you after to the place from initial sending, by
the font of the cat. As for me thus it makes food out of box to have.
What did it make? I am the leave with the detail medicine in
Kittyville all the cat of schoolboy, you calls me the font the cat of
Offiser to me. When the cat of Offiser of font leaves the way, I
struck myself AM young people with the cat of child who did not attach
the hand. As for that meowed and the keept of I meowed that. Is front,
it fired its gun and is I, is fire. But it is him should put fire and
thus is decided by his that the noob, God had to criticize vibrates
outside. I smiled, of resembling demonian in it to strike his surface.
It tried time of gun of situation the second to obtain. It obtained
that! Without state of Ohio! I start to make excuses, but it and the
second time have fire that many times about me! It is apprehensive!
But take one side, as for him is turned over like cat of Offiser of
font. It looked at this cat of child who I am young AM fire in the
place of mine. It crushed its cranium to draw with this part from
nitestick. I can make him laugh his surface. It adopted the gun of
Offisers in the font of the cat, is directed towards me. I put fire at
it, it when leaves, the feeling of investment of matrix synchronizes
watches with. And I tested his uppercut, is obtained it. The cat of
Offiser of font invested the menotter in it, the conservation follows
it in this car. As for me of its mode if it vibrated. It made
detention. I is consulted each day it. It is called the situation
which it is the revenge I on catches of purchase. Thus, the next day,
I visits its gun, headshotted. I had taken with I the girl held in the
same battery. Then is decided by us, combat of each day in it after
matter. HTTP: history of work of //www.diskusjon.no Almadora
Wenn die Katze meine Nacht ankommt, gebe ich normalerweise zur Milch
den. Aber dieses mal, das kann Sie zum Platz vom Ausgangssenden, durch
den Schriftkegel der Katze nachher kommen. Was mich anbetrifft
folglich läßt es Nahrung aus Kasten heraus haben. Was bildete er?
Ich bin der Urlaub mit der Detailmedizin in Kittyville die ganze Katze
des Schülers, Sie nenne mich den Schriftkegel die Katze von
Offiser zu mir. Wenn die Katze von Offiser des Schriftkegels die
Methode verläßt, schlug mich ich morgens junge Leute mit der Katze
des Kindes an, die nicht die Hand anbrachte. Was das anbetrifft meowed
und das keept von meowed mir den. , ist es abfeuerte seine Gewehr und
ist I, ist Feuer vorder. Aber es ist er sollte Feuer setzen und
folglich wird entschieden durch seins, daß das noob, Gott kritisieren
mußte vibriert draußen. Ich lächelte, vom Ähneln demonian in ihm,
um seine Oberfläche anzuschlagen. Es tried Zeit der Gewehr der
Situation die Sekunde zu erreichen. Sie erreichte die! Ohne Zustand
von Ohio! Ich beginne, Entschuldigungen, aber es zu bilden und Feuer
viele Male über mich das zweite mal zu haben das dieses! Es ist
scharfsinnig! Aber nehmen Sie eine Seite, was ihn anbetrifft wie Katze
von Offiser des Schriftkegels umgedreht wird. Er betrachtete diese
Katze des Kindes, die ich junges morgens Feuer anstatt mein bin. Er
zerquetschte seinen Schädel, um mit diesem Teil vom nitestick zu
zeichnen. Ich kann ihn seine Oberfläche lachen lassen. Sie nahm die
Gewehr von Offisers im Schriftkegel der Katze, wird verwiesen in
Richtung zu mir an. Ich setze Feuer an ihm, es, wenn Blätter, das
Gefühl der Investition der Matrix Uhren mit synchronisiert. Und ich
prüfte sein uppercut, werde erreicht ihm. Die Katze von Offiser des
Schriftkegels investierte das menotter in ihm, die Erhaltung folgt ihr
in diesem Auto. Was mich anbetrifft seines Modus, wenn sie vibrierte.
Sie bildete Verzögerung. I wird jeden Tag es beraten. Es wird die
Situation genannt, die es die Rache I auf Verriegelungen des Erwerbes
ist. So am nächsten Tag, besucht I seine Gewehr, headshotted. Ich
hatte mit I das Mädchen genommen, das in der gleichen Batterie
angehalten wurde. Dann wird von uns, Kampf jedes Tages in ihr nach
Stoff entschieden. HTTP: Geschichte der Arbeit von //www.diskusjon.no
Almadora
If the cat arrives my night, I normally give that to the milk. But
this times, that can do you to the workstation of the output
transmitting, by which writing cones of the cat come afterwards. Which
me concerns therefore lets it to food from box have. What did it form?
I am the vacation with the detail medicine in Kittyville the whole cat
of the pupil, you call me the writing cone the cat from Offiser to me.
If the cat of Offiser of the writing cone leaves the method, I
fastened me in the morning young people with the cat of the child,
which did not attach the hand. Which concerns meowed and keept of
meowed me that, is it fired its rifle and I is, is fire front. But it
is it should fires set and therefore decided through seins that noob,
God had to criticize vibrated outside. I smiled, from resembling
demonian in him, in order to fasten its surface. To achieve it tried
time that rifle of the situation the second. It achieved those!
Without status of Ohio! I begin, apologies, to form but it and to have
fires many marks over me second times the this! It is astute! But you
take a page, which concerns it like cat by Offiser of the writing cone
is turned. He regarded this cat of the child, which is I in the
morning young fire instead of mine. It crushed its head, in order to
draw with this section of nitestick. I can let it laugh its surface.
It took those to rifle of Offisers in the writing cone of the cat,
referred toward to me on. I set fire at him, it, if pages, which
synchronizes feeling of the investment of the matrix clocks with. And
I checked its uppercut, achieve him. The cat of Offiser of the writing
cone invested more menotter in it, preservation follows it in this
auto. Which concerns me its mode, if she vibrated. It formed delay. I
will advise each day it. The situation is called, which is it the
revenge I on interlocks of the acquisition. So on the next day, I
visits its rifle, headshotted. I had taken the girl, who was stopped
in the same battery with I. Then by us, fight of each daily in it is
decided after material. HTTP: History of the work of
Se il gatto arriva la mia notte, dò normalmente quello al latte. Ma
questo periodi, quello può farlo alla stazione di lavoro dell'uscita
che trasmette, cui i coni di scrittura del gatto ottengono in seguito.
Quale me preoccupazioni quindi lo lascio ad alimento dalla casella
avere. Che cosa ha formato? Sono la vacanza con la medicina del
particolare in Kittyville il gatto intero dell'allievo, voi lo chiamo
il cono di scrittura il gatto da Offiser a me. Se il gatto di Offiser
del cono di scrittura lascia il metodo, lo ho fissato alla mattina i
giovani con il gatto del bambino, che non ha fissato la mano. Quali
preoccupazioni meowed ed il keept di meowed me quello, è ha infornato
il relativo fucile e la I è, è parte anteriore del fuoco. Ma è esso
se i fuochi si regolano e quindi deciso attraverso i seins che il
noob, dio ha dovuto criticare vibrato all'esterno. Ho sorriso,
dall'assomigliare demonian in lui, per fissare la relativa superficie.
Realizzarla ha provato il tempo che fucile della situazione il
secondo. Ha realizzato quelle! Senza condizione dell'Ohio! Comincio,
scuse, a formare ma esso ed ad avere fuochi molti contrassegni sopra
me seconde volte questo! È astuto! Ma prendete una pagina, che le
preoccupazioni esso gradiscono il gatto da Offiser del cono di
scrittura è girata. Ha considerato questo gatto del bambino, che è I
alla mattina il fuoco giovane anziché mine. Ha schiacciato la
relativa testa, per dissipare con questa sezione di nitestick. Posso
lasciarlo ridere la relativa superficie. Ha preso quelle al fucile di
Offisers nel cono di scrittura del gatto, fatto riferimento verso a me
sopra. Regolo il fuoco lui, esso, se pagine, cui sincronizza la
sensibilità dell'investimento degli orologi della tabella con. Ed ho
controllato il relativo uppercut, lo realizzo. Il gatto di Offiser del
cono di scrittura ha investito più menotter in esso, conservazione lo
segue in questa automobile. Quale lo interessa il relativo modo, se
vibrasse. Ha formato fa ritardare. Raccomanderò ogni giorno esso. La
situazione è chiamata, che è esso la vendetta I sugli interruttori
di sicurezza dell'aquisizione. Così sul il giorno seguente, la I
visita il relativo fucile, headshotted. Avevo preso la ragazza, che è
stata arrestata nella stessa batteria con la I. Allora da noi, la
lotta di ciascuno quotidiano in esso è decisa dopo materiale. HTTP:
Storia del lavoro di //www.diskusjon.no Almadora
If the cat arrives my night, dò normally that one to the latte ones.
But these periods, that one can make it the station of job of the
escape that it transmits, which the cones of writing of the cat obtain
later on. Which me worries therefore I leave it to food the case to
have. Which thing has formed? They are the vacation with the medicine
of particular in Kittyville the entire cat of the student, you I call
it the writing cone the cat from Offiser to me. If the cat of Offiser
of the writing cone leaves the method, I have it fixed to the morning
the young people with the cat of the child, than it does not have
fixed the hand. Which worries meowed and keept of meowed me the that
one, is has put into an oven the relative gun and it is, is front part
of the fire. But it is it if the fires are regulated and therefore
decided through the seins that the noob, God has had to criticize
vibrated to the outside. I have smile, being similar demonian in he,
in order to fix the relative surface. To realize has tried it the time
that gun of the situation the second. It has realized those! Without
condition of the Ohio! I begin, excuses, to form but it and to having
fires many marks over me second times this! It is sly! But you take a
page, than the worries it appreciate the cat from Offiser of the
writing cone is turn. This cat of the child has considered, that it is
to the morning the young fire rather than mines. It has crushed the
relative head, in order to dissipate with this section of nitestick. I
can leave it to laugh the relative surface. It has taken those to the
gun of Offisers in the cone of writing of the cat, fact reference
towards to me over. I regulate the fire he, it, if pages, which
sincronizza the sensibility of the investment of the clocks of the
table with. And I have controlled the relative one uppercut, I realize
it. The cat of Offiser of the writing cone has invested more menotter
in it, conservation follows it in this automobile. Which it interests
it the relative way, if it vibrated. It has formed ago to delay. I
will recommend every day it. The situation is called, that it is it it
vendetta on the switches of emergency of the aquisizione. Therefore on
the following day, the visit the relative gun, headshotted. I had
taken the girl, that it has been arrested in the same battery with
Allora from we, the fight of every daily paper in it is decided after
material. HTTP: History of the job of //www.diskusjon.no Almadora
Se o gato chegar minha noite, dò normalmente esse ao latte uns. Mas
estes períodos, esse pode fazer-lhe a estação do trabalho do escape
que transmite, que os cones da escrita do gato obtêm mais tarde
sobre. Qual eu me preocupa conseqüentemente deixe-lhe ao alimento o
caso para ter. Que coisa deu forma? São as férias com a medicina do
detalhe em Kittyville o gato inteiro do estudante, você que eu o
chamo o cone da escrita o gato de Offiser a mim. Se o gato de Offiser
do cone da escrita sair do método, eu tenho-o reparado à manhã os
povos novos com o gato da criança, do que não reparou a mão. O que
se preocupa meowed e o keept de meowed me esse, é pôs em um forno o
injetor relativo e é, é parte dianteira do fogo. Mas é ele se os
fogos forem regulados e decididos conseqüentemente através dos seins
que o noob, deus teve que criticar vibrado à parte externa. Eu tenho
o sorriso, sendo demonian similar dentro ele, a fim reparar a
superfície relativa. Realizar tentou-a o tempo esse injetor da
situação o segundo. Realizou aqueles! Sem condição do Ohio! Eu
começo, desculpas, a dar forma mas ele e a ter fogos muitas marcas
sobre mim segundas épocas isto! É sly! Mas você faz exame de uma
página, do que a preocupa apreciam o gato de Offiser do cone da
escrita é volta. Este gato da criança considerou, isso que é à
manhã o fogo novo melhor que às minas. Esmagou a cabeça relativa, a
fim dissipar-se com esta seção do nitestick. Eu posso deixá-lo para
rir a superfície relativa. Fêz exame daquelas ao injetor de Offisers
no cone da escrita do gato, referência do fato para a mim sobre. Eu
regulo o fogo ele, ele, se as páginas, que sincronizza o sensibility
do investimento dos pulsos de disparo da tabela com. E eu controlei o
um uppercut relativo, mim realizo-o. O gato de Offiser do cone da
escrita invested mais menotter nele, conservation segue-o neste
automóvel. Qual o interessa a maneira relativa, se vibrar. Deu forma
há a atrasa. Eu recomendarei cada dia ele. A situação é chamada,
isso que é ele ele vendetta nos interruptores da emergência do
aquisizione. Conseqüentemente no seguinte dia, a visita o injetor
relativo, headshotted. Eu tinha feito exame da menina, aquela que foi
prendida na mesma bateria com o Allora dos nós, a luta de cada papel
diário nela sou decidido após o material. HTTP: History do trabalho
If the cat to arrive my night, dò normally this to latte ones. But
these periods, this can make it to it station of the work of the
escape that it transmits, that the cones of the writing of the cat get
later on. Which I worries me consequently leaves it to it the food the
case to have. That thing gave form? They are the vacations with the
medicine of the detail in Kittyville the entire cat of the student,
you that I call it the cone the writing the cat of Offiser me. If the
cat of Offiser of the cone of the writing to leave the method, I it
have repaired to the morning the new peoples with the cat of the
child, of whom he did not repair the hand. What if it worries meowed
and keept of meowed me this, is put in an oven the relative injector
and is, is front part of the fire. But he is it if the fogos will be
regulated and determined consequently through seins that noob, god had
that to criticize vibrated to the external part. I have the smile
inside, being demonian similar it, the end to repair the surface
relative. To carry through tried it the time this injector of the
situation as. It carried through those! Without condition of the Ohio!
I start, excuses, to give to form but it and to have fogos many marks
on me second times this! He is sly! But you he makes examination of a
page, of that he worries it appreciate the cat of Offiser of the cone
of the writing is rollback. This cat of the child considered, this
that is to the morning the new fire better that to the mines. It
jammed the head, the end relative to waste itself with this section of
nitestick. I can leave it to laugh the relative surface. Fêz
examination of those to the injector of Offisers in the cone of the
writing of the cat, reference of the fact for me on. I regulate the
fire it, it, if the pages, that sincronizza sensibility of the
investment of the pulses of detonation of the table with. E I
controlled the relative one uppercut, me I carry through it. The cat
of Offiser of the cone of the writing invested more to menotter in it,
conservation follows it in this automobile. Which interests it the
relative way, to vibrate itself. It gave form has delays it. I will
recommend to each day it. The situation is called, this that is it it
vendetta in the interruptors of the emergency of aquisizione.
Consequently in the following day, the visit the relative injector,
headshotted. I had made examination of the girl, that one that was
arrested in the same battery with the Allora of we, the fight of each
daily paper in I am determined after the material. HTTP: History of
the work of //www.diskusjon.no Almadora
Si el gato a llegar mi noche, dò normalmente esto al latte unos. Pero
estos períodos, éste pueden hacerle él la estación del trabajo del
escape que transmite, que los conos de la escritura del gato consiguen
más adelante encendido. Cuál I se preocupa me por lo tanto las hojas
él a él el alimento el caso para tener. ¿Esa cosa dio la forma? Son
las vacaciones con la medicina del detalle en Kittyville el gato
entero del estudiante, usted que lo llamo el cono la escritura el gato
de Offiser yo. Si el gato de Offiser del cono de la escritura para
dejar el método, I él ha reparado a la mañana a nueva gente con el
gato del niño, de quien él no reparó la mano. Qué si se preocupa
meowed y el keept meowed me esto, se pone en un horno el inyector
relativo y es, es parte delantera del fuego. Pero él es él si los
fogos son regulados y determinados por lo tanto a través de los seins
que el noob, dios tenía eso a criticar vibrado a la parte externa.
Tengo la sonrisa adentro, siendo similar demonian él, el extremo para
reparar al pariente de la superficie. Para llevarlo con probado el
tiempo este inyector de la situación como. ¡Llevó con ésas! ¡Sin la
condición del Ohio! ¡Comienzo, las excusas, a dar la forma pero ella
y a tener fogos muchas marcas en mí las segundas veces esto! ¡Él es
sly! Pero usted él hace la examinación de una paginación, de eso
que él se preocupa lo aprecia el gato de Offiser del cono de la
escritura es restauración no actualizada. Este gato del niño
considerado, el que es a la mañana el nuevo fuego mejor eso a las
minas. Atoró la pista, la basura en relación con sí mismo del
extremo con esta sección del nitestick. Puedo dejarlo para reír la
superficie relativa. Examinación de Fêz de ésos al inyector de
Offisers en el cono de la escritura del gato, referencia del hecho
para mí encendido. Regulo el fuego él, él, si las paginaciones, esa
sensibilidad del sincronizza de la inversión de los pulsos de la
detonación del vector con. E I controló el un uppercut relativo, yo
que llevo a través de él. El gato de Offiser del cono de la
escritura invirtió más al menotter en él, conservación lo sigue en
este automóvil. Qué intereses él la manera relativa, de vibrarse.
Dio la forma tiene la retrasa. La recomendaré a cada día. Se llama
la situación, el que sea él él vendetta en los interruptores de la
emergencia del aquisizione. Por lo tanto en el día siguiente, la
visita el inyector relativo, headshotted. Había hecho la examinación
de la muchacha, aquélla que fue arrestada en la misma batería con el
Allora de nosotros, la lucha de cada diario adentro que me determinan
después del material. HTTP: Historia del trabajo de
If the cat to arrive my night, dò normally this to latte. But these
periods, this one station can do he to him it of the work of the
obtain more ahead ignition. Which I worries therefore the leaves to me
he to him the food the case to have. That thing gave the form? They
are the vacations with the medicine of the detail in Kittyville the
whole cat of the student, you who I call the cone the writing the cat
of Offiser. If the cat of Offiser of the cone of the writing to leave
the method, I he has repaired to the morning to the new people with
the cat of the boy, of whom it did not repair the hand. What if keept
worries meowed and meowed me this, puts in a furnace the relative
injector and is, is front part of the fire. But he is he if the fogos
are regulated and determined therefore through seins that noob, God
had that to criticize vibrated to the external part. I have the smile
inside, being similar demonian he, the end to repair to the relative
of the surface. In order to take it with proven the east time injector
of the situation like. It took with those! Without the condition of
the Ohio! Beginning, the excuses, to give to the form but she and to
have fogos many marks in me the second times this! It is sly! But you
he for the examinación of a pagination, about which it worries
appreciates the cat of Offiser of the cone of the writing is
restoration nonupdated. This cat of the considered boy, the one that
is to the morning the new fire better that to the mines. It obstructed
the track, the sweepings in relation to itself of the end with this
section of nitestick. I can let it to laugh the relative surface.
Examinación de Fêz of those to the injector of Offisers in the cone
of the writing of the cat, reference of the fact for ignited me. I
regulate the fire he, he, if the paginations, that sensitivity of
sincronizza of the investment of the pulses of the detonation of the
vector with. And I controlled uppercut relative, I that I take through
him. The cat of Offiser of the cone of the writing invested more when
menotter in him, conservation follows it in this automobile. What I
interest he it relative way, to vibrate. It gave the form has delays
it. I will recommend it to every day. The situation is called, the one
that is he he vendetta in the switches of the emergency of
aquisizione. Therefore in the following day, the visit the relative
injector, headshotted. It had made the examinación of the girl, that
one that was arrested in the same battery with the Allora of us, the
fight of each newspaper inside that determines to me after the
material. HTTP: History of the work of //www.diskusjon.no Almadora
  • 5 måneder senere...
One time, when I was drinking milk. My mom said I needed to do my homework. But since im a silly boy, I just started to drink Pepsi-max.
Une fois, quand j'étais lait de consommation. Ma maman a dit I requis
pour faire mon travail. Mais depuis im un garçon idiot, j'ai juste
commencé à boire Pepsi-cola-maximum.
Once, when I was drinking milk. My mom said I necessary to do my work.
But since a im idiotic boy, I just started to drink
Pepsi-cola-maximum.
Sobald, als ich Trinkmilch war. Meine Mamma sagte I, das notwendig
ist, meine Arbeit zu erledigen. Aber seit einem idiotic Jungen im,
begann ich gerade, Pepsi-Kolabaum-Maximum zu trinken.
As soon as, when I was fresh milk. My Mamma said I, which is necessary
to complete my work. But since one idiotic boys in, I began even to
drink Pepsi Kolabaum maximum.
Non appena, quando ero latte fresco. Il mio mamma ha detto la I, che
è necessaria da ultimare i miei lavori. Ma dai ragazzi idiotic uno
dentro, ho cominciato persino a bere il massimo della Pepsi-cola
Kolabaum.
Not hardly, when I was latte fresh. My mother has said the I, that it
is necessary to complete my jobs. But from the boys idiotic within, I
have begun to drink the maximum of even Pepsi-strains Kolabaum.
Não mal, quando eu era latte fresco. Minha matriz disse o I, aquele
que é necessário terminar meus trabalhos. Mas dos meninos idiotic
dentro, eu comecei a beber o máximo de Pepsi-tensões uniformes
Kolabaum.
Not badly, when I cool age latte. My array said the I, that one that
is necessary to finish my works. But of the boys idiotic inside, I
started to drink the maximum of Pepsi-tensions Kolabaum uniforms.
No gravemente, cuando latte fresco de la edad de I. Mi arsenal dijo el
I, aquél que es necesario acabar mis trabajos. Pero del interior
idiota de los muchachos, comencé a beber el máximo de los
uniformes de Kolabaum de las Pepsi-tensiones.
Not seriously, when latte fresh of the age of I. My arsenal said the
I, that one that is necessary to finish my works. But of the stupid
interior of the boys, I began to drink the maximum of the uniforms of
Kolabaum of the Pepsi-voltages.
Pepsi-max
Pepsi-cola-maximum
Pepsi-cola-maximum
Massimo della Pepsi-cola Kolabaum
Maximum of Pepsi-strains Kolabaum
Máximo das Pepsi-tensões Kolabaum
Maximum of the Kolabaum Pepsi-tensions
Máximo de las Pepsi-tensiones de Kolabaum
Maximum of the Pepsi-voltages of Kolabaum
Wondefull world:
I on the other hand sees that the trees of the red colors if getting
up of the Gruens is had........, that I v this flower of the extremity
of the sustenation..... for me and you and of me.... to think, the
narcotic world. Is v that the cloud skies of the white woman of the
system to ignite inside in gesegneten the crowned nights of the
Blaus..... of the newspaper... Nerezza and I I.....what of which a
narcotic world thinks. The colors of a rainbow.....so assez..in, that
one are ingualmente of the sky in personnes..going, close
classify.....of, that I v he them friends, the one who the
hand.....sayin. it presses it as you sayin...... of the form of the
love of Theyre I really you. I feel to shout outside the
children...... I am observed I magnify of Theyll the end to try this
very... Never defective white man of de..than and I.....what that
world narcotic (instrumental conclusion) of that one colors of
rainbow.....so assez..in thinks, that the sky anyone, that sees of the
friends, of that classifies here in personnes..going.....of close the
hand.....sayin. presses as you really form * spoken*(I... Love... He
of sayin of Theyre...). I feel to shout outside the children...... I
observe end to do * latta one of spoken*(you of I he that I correspond
the end to learn ulteriorly completely a destiny when the defect he
never knows that one) and the task a narcotic world, of that the task
I...... of me.....what that narcotic world
I have to pee
i have to pee
je dois faire pipi
I must make wee
Ich muß kleines Stueck bilden
I must form small piece
Devo formare la piccola parte
I must form the small part
Eu devo dar forma à parte pequena
I must give form to the small part
Debo dar la forma a la parte pequeña
I must give the form to the small part
led zeppelin - Stairway to heaven
There's a lady who's sure all that glitters is gold
And she's buying a stairway to heaven
And when she gets there she knows if the stores are closed
With a word she can get what she came for
Woe oh oh oh oh oh
There's a sign on the wall but she wants to be sure
And you know sometimes words have two meanings
In a tree by the brook there's a songbird who sings
Sometimes all of our thoughts are misgiven
Woe oh oh oh oh oh
There's a feeling I get when I look to the west
And my spirit is crying for leaving
In my thoughts I have seen rings of smoke through the trees
And the voices of those who stand looking
Woe oh oh oh oh oh
And it's whispered that soon, if we all call the tune
Then the piper will lead us to reason
And a new day will dawn for those who stand long
And the forest will echo with laughter
And it makes me wonder
If there's a bustle in your hedgerow
Don't be alarmed now
It's just a spring clean for the May Queen
Yes there are two paths you can go by
but in the long run
There's still time to change the road you're on
Your head is humming and it won't go in case you don't know
The piper's calling you to join him
Dear lady can't you hear the wind blow and did you know
Your stairway lies on the whispering wind
And as we wind on down the road
Our shadows taller than our soul
There walks a lady we all know
Who shines white light and wants to show
How everything still turns to gold
And if you listen very hard
The tune will come to you at last
When all are one and one is all
To be a rock and not to roll
Woe oh oh oh oh oh
And she's buying a stairway to heaven, uh uh uh.
There is an injury which has sure all that scintillates is gold
and it buys a staircase with the sky and when it arrives there it
knows if the memories are closed with a word to obtain that it can for
what it came trouble OH OH OH OH OH and it buys a staircase with the
sky There is one to connect the wall but it wants to be sure and you
know that sometimes the words have two significances in a tree by the
brook there is a songbird which sings sometimes all our thoughts
misgiven trouble OH OH OH OH OH and it buys a staircase with the sky
There is a feeling that look in the west and my spirit cries to leave
in my thoughts I saw loops of smoke by the trees and the voices of
those which are held looking at trouble OH OH OH OH OH and it buy a
staircase with the sky And one whispers to him that soon, if we all
the call the air then the player of pipeau we will carry out to reason
and a new day is born for those which which are held long and the
forest will do echo with the laughter And it makes me the wonder If
there is a movement in your edge of hedges are not alarmed that now it
is right a spring clean for the queen has two access paths which you
can go by but with long the motionless hour ago to change the road you
are on line Your head whirrs and it will not disappear if you would
not know that the player of pipeau invites you to join it dear
injury cannot hear you the wind blow and knew you your lies of
staircase about the wind of whisper And bus we roll up on to the
bottom the road our shades larger than our heart there functioning an
injury than all knows us than which polishes the white light and
wants to show how all always turns to gold and Si you the air will
come to you finally when all is one and one is very with being a rock
and not to roll trouble OH OH OH OH OH and it a staircase with the sky
There buys is an injury which has sure all that scintillates is
gold and it buys a staircase with the sky and when it arrives there it
what it came And it buys a staircase with the sky, uh of uh of uh.
There is a violation, which has reliably everything, which is gold
sparkles and a stairway with the sky buys it and if it arrives there
it white, if the memory with a word is closed, to achieve in order to
attach that it can do for, which it trouble OH- OH- OH- OH- OH- came
and it there is a stairway with the sky one buys, to the wall, but it
would like to be sometimes safe and you misgiven to know that the
words two there significances is sometimes in a tree by the brook a
singing bird has, that our whole thoughts trouble OH- OH- OH- OH- OH-
sing and it purchases a stairway with sky there is feeling, look into
the west and my spirit cries, to in my thoughts to go I saw that loops
of the smoke by the trees and the voices of those, which regarding the
trouble OH- OH- OH- OH- OH- are stopped and of its purchase a stairway
with the sky and to it whisper, which soon, if we that whole call air
the player of pipeau, whom we execute, around to then conclude and a
new day for is carried, those, which are long stopped and which does
forest echo with the laughter and it the miracle educates me, if it a
movement in your edge of the hedges alarmed does not give that it is
quite now a spring, to that is clean for the queen has two means of
access, it to go can forwards through, but with long motionless of the
hour, to the road to modify you on line your Hauptwhirrs are and he do
not disappear, if you would not know that the player of pipeau
in-loads you, to connect him whom dear violation cannot hear you the
wind impact and you over the wind of whispering and the bus knew your
lies of the stairway, we to the lower surface the road our colours to
roll on above, those as our there operating inside a violation is
larger, than everything us as if it knows which would like to show the
white light polished and, how everything always turns at gold and
silicone you finally comes air to you, if everything is in and one is
very much with its a rock and, trouble OH- OH- OH- OH- OH- and it is
not to be rolled a stairway with that of the sky purchases there a
violation, which has reliably everything, which is gold sparkles and a
stairway with the sky buys it and if it arrives there it white, if the
memory with a word is closed, in order to achieve that it for which it
came and it a stairway with the sky buys, uh of uh of uh can.
Endret av Danielsm
"Use the force!":
Use the force!
Utilisez la force !
Use the force!
Wenden Sie die Kraft auf!
Spend the strength!
Spenda la resistenza!
It spends the resistance!
Gasta a resistência!
¡Pasa la resistencia!
It passes the resistance!
Cookie-monster (Blei noko artigare når eg brukte bindestrek, istadenfor utan bindestrek):
cookie-monster
biscuit-monstre
biscuit-monster
Biskuit-Monster
Biskuit monster
Monster di Biskuit
Monster di Biskuit
Monster di Biskuit
Monster di Biskuit
Monster di Biskuit
Monster I gave Biskuit
Endret av mummi-pappa
Another one rides the bus. Another one rides the bus. And another comes on and another comes on; another rides the bus. Hey! He's gonna sit by you, another on rides the bus.
Encore monte le bus. Encore monte le bus. Et un autre avance et un
autre avance ; des autres tours le bus. Hé ! Il va s'asseoir par
vous, un autre monte en fonction le bus.
Still the bus goes up. Still the bus goes up. And another advance and
another advance; others turns drank it. Hé! It will sit down by you,
another goes up in function drank it.
Noch geht der Bus oben. Noch geht der Bus oben. Und ein anderer
Fortschritt und ein anderer Fortschritt; andere dreht sich tranken
ihn. Hé! Es sitzt durch Sie, anders geht oben in Funktion trank sie
hin.
Still the bus goes above. Still the bus goes above. And another
progress and another progress; other one turns drank it. Hé! It sits
by you, differently goes above into function drank it.
Ancora il bus va sopra. Ancora il bus va sopra. E un altro progresso e
un altro progresso; altre girate una lo hanno bevuto. Hé! Si siede da
voi, diversamente entra sopra nella funzione la ha bevuta.
Still the bus goes over. Still the bus goes over. And an other
progress and an other progress; other turns one have it drunk. Hé!
One is based from you, various enters over in the function has drunk
it.
Ainda a barra-ônibus ultrapassa. Ainda a barra-ônibus ultrapassa. E
um outro progresso e um outro progridem; outras voltas uma têm-no
bebido. Hé! Um é baseado de você, vário entra sobre na função
bebeu-a.
Still the bar-bus exceeds. Still the bar-bus exceeds. E one another
progress and one another one progresses; other rollbacks one it have
drunk. Hé! One is based of you, various enters on in the function
drank it.
Todavía el barra-megabus se excede. Todavía el barra-megabus se
excede. E un otro progreso y un otro uno progresa; otras
restauraciones no actualizadas una que ha bebido. ¡Hé! Uno se basa de
usted, vario entra encendido en la función la bebió.
Still it sweeps-megabus exceeds. Still it sweeps-megabus exceeds. And
a other progress and other one progress; other restorations nonupdated
one that has drunk. Hé! One is based of you, vario you enter ignition
the function drank it.
I like big butts and I can not lie! You motherfuckers can't deny!
J'aime de grands bouts et je ne peux pas me trouver ! Vous des
motherfuckers ne pouvez pas nier !
I like great ends and I cannot be! You of the motherfuckers cannot
deny!
Ich mag große Enden und ich kann nicht sein! Sie der motherfuckers
können nicht verweigern!
I like large ends and I cannot not be! They motherfuckers cannot
refuse!
Gradisco le grandi estremità e non posso essere! Motherfuckers non
possono rifiutare!
I appreciate the great extremities and I cannot be! Motherfuckers
cannot refuse!
Eu aprecio as extremidades grandes e eu não posso ser! Motherfuckers
não pode recusar!
cannot refuse!
¡Aprecio las grandes extremidades y no puedo ser! ¡Motherfuckers no
puede rechazar!
Esteem the great extremities and I cannot be! Motherfuckers cannot
reject!
Endret av Frohman
  • 3 uker senere...
denne er fin
Israel has carried out an exercise that appears to have been a rehearsal for an attack on Iran's nuclear facilities, US officials have told the New York Times.
l'Israel a effectué un exercice qui semble avoir été une
répétition pour une attaque sur les installations nucléaires de
l'Iran, fonctionnaires des USA ont dit les temps de New York.
Israel carried out a exercise which seems to have been a repetition
for an attack on the nuclear installations of Iran, civils servant of
the USA said times of New York.
Israel führte eine Übung, die scheint, eine Wiederholung für einen
Angriff auf den Kernkraftinstallierungen vom Iran gewesen zu sein,
civils Bediensteten der USA besagten Zeiten von New York durch.
Israel led an exercise, which seems, a repetition for an attack on the
nuclear power installations of Iran to have been civils officials of
the USA mentioned times of New York through.
L'Israele ha condotto un'esercitazione, che sembra, una ripetizione
per un attacco alle installazioni di energia nucleare dell'Iran per
essere funzionari dei civils dei tempi accennati gli S.U.A. di New
York attraverso.
The Israel has lead a practice, that it seems, a repetition for an
attack to the energy installations nuclear of the Iran for being civil
employees of the civils of the times points out the S.U.A to you. of
New York through.
A Israel tem a ligação uma prática, aquela que pareça, uma
repetição para um ataque às instalações da energia nucleares do
Irã para ser empregados civis dos civils dos tempos indica-lhe o
S.U.A de New York completamente.
The Israel has practical plugging one, that one that seems, a
replication for an attack to the nuclear installations of the energy
of the Irã to be used civil of civils of the times indicates the
S.U.A to it of New York full.
El Israel tiene que tapa el práctico, aquél que se parece, una
réplica para un ataque a las instalaciones nucleares de la energía
del Irã a ser civil usado de los civils de los tiempos indica el
S.U.A a él de Nueva York por completo.
Israel has covers the practitioner, that one that looks like, an
retort for an attack to the nuclear power plants of the energy of the
civil Irã to be used of civils of the times completely indicates the
S.U.A to him of New York.
heh, var morro, tok en fra "the rules of the internet"
* Rule 6: CAPS LOCK IS CRUISE CONTROL FOR COOL.
* 規則6: 帽子ロックは涼しいのための巡航制御である。
* Systematic 6: The hat lock is cool is control of cruise of for the
sake of.
* 系统6: 帽子锁定是冷静是巡航控制为。
* System 6: Hat locking is calm is the cruise control is.
* Système 6 : Le verrouillage de chapeau est calme est la commande de
croisière est.
* System 6: The locking of cap is calm is the ordering of cruising is.
* System 6: Das Sperrung der Schutzkappe ist Ruhe ist die Einrichtung
des Kreuzens ist.
* System 6: Blocking of the protective cap is peace is the mechanism
of crossing is.
* Sistema 6: Ostruendo della protezione protettiva è pace è il
meccanismo dell'incrocio è.
* It arranges 6: Obstructing of the protecting protection it is peace
is the mechanism of the crossing is.
* Arranja 6: Obstruir da proteção que protegendo é paz é o
mecanismo do cruzamento é.
* It arranges 6: To obstruct of the protection that protecting is
peace is the mechanism of the crossing is.
* Arregla 6: Obstruir de la protección que es la protección la paz
es el mecanismo de la travesía es.
* It fixes 6: To obstruct of the protection that is the La Paz
protection is the mechanism of the passage is.
Haha, merka at spansken var litt rar:
spanish sucks ass, just incase you didnt know. because i think i am the only one that knows this, thats why.
l'Espagnol suce l'âne, vous emballe juste que le didnt connaissent
parce que je pense que je suis le seul qui sait ceci, thats pourquoi.
the Spaniard sucks the ass, packs you just that the didnt know because
I think that I am only who know this, the thats why.
der Spaniard saugt den Esel, packt Sie, gerade daß das didnt wissen,
weil ich denke, daß ich nur wer dieses wissen, die thats warum bin.
the Spaniard sucks the donkey, packs you, even that didnt knows,
because I think that I only who this know, which thats why am.
lo spaniard succhia l'asino, li imballa, persino che il didnt conosce,
perché penso che I soltanto chi questa conosce, che thats perchè.
the spaniard it sucks the ass, packs them, even that the didnt it
knows, because task that only who this knows, than thats why.
o spaniard suga o burro, embala-os, mesmo que o didnt ele sabe, porque
a tarefa que somente quem isto sabe, do que thats porque.
spaniard sucks the donkey, packs them, exactly that didnt it knows,
because the task that who this only knows, of that thats because.
el español aspira el burro, pila de discos los, exactamente a que el
didnt él conozca, porque la tarea el a que éste conozca solamente,
de eso los thats porque.
the Spanish inhales the donkey, disc battery, exactly that didnt he
knows, because the task the a that this one only knows, of that thats
because.
:laugh:
i love mari
j'aime le mari
I love the husband
Ich liebe den Ehemann
I love the married man
Amo l'uomo sposato
Eu amo o homem casado
Amo a hombre casado
Master to married man
siste gang jeg sender kjærlighetsbudskap over internett...
og her en som er så essensiell at den er perfekt på alle språk:
the internet is for porn
l'Internet est pour le porn
the Internet is for the porn
das Internet ist für das porn
the InterNet is for porn
il Internet è per porn
the Internet is for porn
o Internet é para o porn
el Internet está para el porn
Endret av Hawk_AA
