Call of duty 4 prestige mod?
espinos
Gjest Slettet-uVTr2vDm
Trur han er på jobb, altså gjort det 10 ganger jeg !
Jeg for min del synes spillet ble kjedelig da jeg kom på 55.
Samme ble det 2nd gangen jeg kom på 55.
Nå er jeg på vei for 3rd gang, men denne gangen skal jeg skaffe meg et gullvåpen
asså, ikke bare deagelen.
Dødsgøy å levle opp :]
Jeg startet på nytt på Tirsdag og er på level 50 allerede. Spiller et par timer om kvelden, så for min del går det ganske kjapt. Bruker kanskje 2-3 timer å komme til level 30, og så bruker jeg 2-3 kamper med S&D for å komme raskt opp igjen.
Er jo bare å kjøre på med MP5+Stopping Power i starten så går det lynkjapt:)
Absolutt verdt det mener jeg :)
Endret av WangenPs3
Ok, Her er en post fra NOX sitt forum;
So after much hoopla over the last 24 hours, we've decided to just spill the beans already. No more waiting, wondering, anticipating. It's hard to believe that something so simple caused such a huge ruckus within the COD community. People seemed genuinely mad that we weren't saying anything, and that isn't right. So instead of holding out any further, we've decided to just go ahead and share the knowledge.
Thank you to everyone who has congratulated Ryan on being the first to reach level 55 of the 10th prestige. While some may trash him for it, it's an accomplishment that someone had to do eventually. I'm just glad it was one of us.
There was a lot of speculation as to what you would receive .. perks, weapons, etc. I have to admit, I wanted to know just as much as the next fella.
Without rambling on any further (yes, I did that on purpose =) here's what you receive after reaching level 55 of the 10th prestige (which Ryan did I just under 7 days of playing, if the "Time Played" on the leaderboards is correct).
you get ...
drum roll please ...
nothing.
Yes, sadly, you get nothing. Some of you already knew this, but hopefully this puts a stop to all the hate and bashing. We enjoyed our little moment in the spotlight, but it's time to move onto bigger and better things, like trying for the #1 spot on Gamebattles. We hope to see you there!
Thanks, and have fun out there.
Team NOX
Endret av Gemi9
Gjest Slettet-1ZSK0pUMX2
Prestige mode. Du kommer i lvl 55. i lvl 55 får du gold dessert eagle btw.
Så velger du prestige mode. Du hører et skudd når du trykker på knappen "Yes" ( dem spør deg mange ganger om du vil dette)
Så begynner du på nytt, og det du får er det merket, avbildet to ørner elns og et skjold. Litt vanskelig for meg og se på min tv, men det er noe sånt.
+ At du får gullcamo på hvert våpen. :cool:
Edit: Er forresten ikke sikker på dette da det bare er noe jeg har lest på et forum. Noen som kan si noe mer om dette?
Det har ikke jeg merket. Jeg spilte mot en fyr som hadde gullcamo på X1001 hagla, eller hva den heter, og han var i 34 i prestige. Jeg er i prestige 44, og har ikke sett noe til det. Mulig at det går og unlocke det som i når man tar headshots challenges. Altså de forskjellige camo skinsa, om det var det du tenkte på.
Prestige mode er og anbefale for en spiller som har tålmodighet, og som virkelig liker COD 4, og som kan sette av tid til det.
Gold Camo var veldig veldig stilig btw :p
når du aktiverer prestige mode, begynner du helt fra starten igjen, det eneste som er forskjellig er at du har et ikon ved navnet ditt, dette kan du gjøre 10 ganger...
Har du bilde av hvordan det ikonet ser ut?
Altså, første gang man trykker på prestige mode, så får man det ikonet under lvl 1, og nr 2 lvl 2 osv.
Kilde: http://www.iwsti.com/forums/gaming/104354-...mode-icons.html
Stemmer faktisk, da jeg har sett spillere med prestige ikonet under lvl 3.
Endret av Slettet-1ZSK0pUMX2
