Alle våpen kode til Crysis?
Som topic sier, jeg er på utkikk etter en trainer/kose som gir meg alle våpnene.
Jeg har runnet Crysis, og derfor tenker jeg å leke meg med soldatene, men helst med alle våpene man kan få.
Jeg har funnet koder til evig energi, evig liv og evig skudd etc. Men det jeg er ute etter, er alle våpen, og den finner jeg ikke.
Takker for alle svar ;)
God Mode
Locate the difficulty files in your Crysis installation folder (ie: C:\Program Files\Electronic Arts\Crytek\Crysis\Game\Config). These files are called diff_easy.cfg, diff_normal.cfg, diff_hard.cfg and diff_bauer.cfg. Open the file (with Notepad) that corresponds to the difficulty level you are playing. Add the following line to the end of the file and save it:
g_godMode = 1
Now, when playing your health will still decrease but you will not die. Instead, your health and armor will automatically replenish when your health reaches 0.
Additional Cheats
Using the same method as above, add the following lines to the end of your config file for the corresponding effect:
Code: Result:
i_unlimitedammo = 1 Unlimited Ammo
ai_IgnorePlayer = 1 Enemies Ignore You
i_noweaponlimit = 1 Carry Unlimited Number of Weapons
NOTE: ALWAYS MAKE A BACKUP BEFORE OVERWRITING GAME FILES.
