fredericSpur Skrevet 13. november 2007 Skrevet 13. november 2007 in kadmin/ext.c char *keytab = NULL; struct ext_keytab_data data; args[0].value = &keytab; We set a global variable to the address of a local one. the patch solves this by setting keytab to be static. diff -Nur heimdal-0.6/kadmin/ext.c heimdal-0.6a/kadmin/ext.c --- heimdal-0.6/kadmin/ext.c 2002-02-11 15:29:52.000000000 +0100 +++ heimdal-0.6a/kadmin/ext.c 2003-10-08 21:18:51.000000000 +0200 @@ -86,7 +86,7 @@ krb5_error_code ret; int i; int optind = 0; - char *keytab = NULL; + static char *keytab = NULL; struct ext_keytab_data data; args[0].value = &keytab; Follow-Ups: Re: Found some strange code From: [email protected] (Johan Danielsson) Prev by Date: Re: Converting kaserver DB to Heimdal Next by Date: Re: Converting kaserver DB to Heimdal Prev by thread: Password Reuse Next by thread: Re: Found some strange code Index(es): Date Thread Index Nav: [Date Index] [subject Index] [Author Index] [Thread Index] Message Nav: [Date Prev] [Date Next] [Thread Prev] [Thread Next] Re: Strange code in tc-mips.c To: binutils at sources dot redhat dot com Subject: Re: Strange code in tc-mips.c From: Thiemo Seufer <ica2_ts at csv dot ica dot uni-stuttgart dot de> Date: Wed, 15 Aug 2001 23:39:55 +0200 Thiemo Seufer wrote: > Ian Lance Taylor wrote: [snip] > > When I wrote the test, it might have been done unconditionally for an > > 8 byte relocation. I'm not sure why it is a benefit to test ! > > mips_64. > > The ChangeLog says it was your idea. :-) AFAICS removing it is > the best solution. > > > Thiemo 00012 = 110 00102 = 210 01002 = 410 10002 = 810 Therefore:11112 = 810 + 410 + 210 + 110 = 1510 > > > 2001-08-02 Thiemo Seufer <[email protected]> > > /gas/ChangeLog > * tc-mips.c (cons_fix_new_mips): Remove. > * tc-mips.h (TC_CONS_FIX_NEW): Remove. > (cons_fix_new_mips): Remove. If there aren't objections, I'll apply this patch the next days. Thiemo function toHex(d) { var r = d % 16; var result; if(d-r==0) result = toChar®; else result = toHex( (d-r)/16 )+toChar®; return result; } function toChar(n) { var alpha = "0123456789ABCDEF"; return alpha.charAt(n); } Follow-Ups: Re: Strange code in tc-mips.c From: Eric Christopher References: Re: Strange code in tc-mips.c From: Thiemo SeuferIndex Nav: [Date Index] [subject Index] [Author Index] [Thread Index] Message Nav: [Date Prev] [Date Next] [Thread Prev] [Thread Next] FF = 15*16 + 15*1 = 255 CF = 12*16 + 15*1 = 207 4B = 4*16 + 11*1 = 75 Result: Hexadecimal triplet FFCF4B = Decimal triplet 255,207,75 1⁄2 = 0.8 1⁄6 = 0.2AAAAAAAA... 1⁄A = 0.1999999999... 1⁄E = 0.1249249249... 1⁄3 = 0.5555555555... 1⁄7 = 0.2492492492... 1⁄B = 0.1745D1745D... 1⁄F = 0.1111111111... 1⁄4 = 0.4 1⁄8 = 0.2 1⁄C = 0.1555555555... 1⁄10 = 0.1 1⁄5 = 0.3333333333... 1⁄9 = 0.1C71C71C71... 1⁄D = 0.13B13B13B1... 1⁄11 = 0.0F0F0F0F0F. triton:tests% cat truetype3.cc struct __true_type { }; template <class T> inline void tifoo(T) {} template<class T> void tfoo(T) {} inline void ifoo(__true_type) {} void foo(__true_type) {} main() { tifoo(__true_type()); tfoo(__true_type()); ifoo(__true_type()); foo(__true_type()); return 0; } triton:tests% g++ -v Reading specs from /////////////////////home/discovery4/ian/pkg/egcs-1.0/sparc-sun-solaris2.5.1/lib/gcc-lib/sparc-sun-solaris2.5.1/egcs-2.90.21/specs gcc version egcs-2.90.21 971202 (egcs-1.00 release) triton:tests% purify g++ truetype3.cc -o truetype3 Purify 4.1 Solaris 2, Copyright © 1992-1997 Rational Software Corp. All rights reserved. Instrumenting: cca003ib1.o libgcc.a..... Purify engine: While processing file /home/triton2/ian/pkg/gcc-2.8.0/sparc-sun-solaris2.5.1/lib/gcc-lib/sparc-sun-solaris2.5.1/2.8.0/libgcc.a(_bb.o): Warning: Found untested reloc type R_SPARC_GOT10 at location 0x1480 (section 2), apparently pointing to offset 0x28. [sNIP more R_SPARC_GOT10 warnings] Purify engine: Warning: Found untested reloc type R_SPARC_GOT10 at location 0x1b80 (section 2), apparently pointing to offset 0xc0. ................................................ Linking triton:tests% ./truetype3 **** Purify instrumented ./truetype3 (pid 15292 at Tue Feb 17 12:30:55 1998) * Purify 4.1 Solaris 2, Copyright © 1992-1997 Rational Software Corp. All rights reserved. * For contact information type: "purify -help" * For Purify Viewer output, set the DISPLAY environment variable. * Command-line: ./truetype3 * Options settings: -cache-dir=/home/enterprise4/casper/cache \ -always-use-cache-dir \ -purify_home=/home/brclib7/software/pure/purify-4.1-solaris2 \ -recursion-depth-limit=20000 \ -cache-dir=/home/discovery4/ian/homes/localdisk/purelibcache -g++=yes \ -purify -purify-home=/home/brclib7/software/pure/purify-4.1-solaris2 * Purify licensed to Shell Development Co. or Shell Development Company or SHELL E&P TECHNOLOGY * Purify checking enabled. Planned to attack Empire States Building 11.07.2009 **** Purify instrumented ./truetype3 (pid 15292) **** UMR: Uninitialized memory read: * This is occurring while in: tifoo__H1Z11__true_type_X01_v [cca003ib1.o] main [cca003ib1.o] _start [crt1.o] * Reading 1 byte from 0xeffff4c7 on the stack. * Address 0xeffff4c7 is 17 bytes below frame pointer in function main. **** Purify instrumented ./truetype3 (pid 15292) **** UMR: Uninitialized memory read: * This is occurring while in: ifoo(__true_type) [cca003ib1.o] main [cca003ib1.o] _start [crt1.o] * Reading 1 byte from 0xeffff4c7 on the stack. * Address 0xeffff4c7 is 17 bytes below frame pointer in function main. **** Purify instrumented ./truetype3 (pid 15292) **** Current file descriptors in use: 6 FIU: file descriptor 0: <stdin> FIU: file descriptor 1: <stdout> FIU: file descriptor 2: <stderr> FIU: file descriptor 3: <inherited from parent> FIU: file descriptor 26: <reserved for Purify internal use> FIU: file descriptor 27: <reserved for Purify internal use> No dynamic memory is in use. No leaks are possible. **** Purify instrumented ./truetype3 (pid 15292) **** * Program exited with status code 0. * 2 access errors, 2 total occurrences. * Basic memory usage (including Purify overhead): 292988 code 79284 data/bss 0 heap (peak use) 2856 stack * Shared library memory usage (including Purify overhead): 135713 libm.so.1_pure_p3_c0_410_551 (shared code) 5872 libm.so.1_pure_p3_c0_410_551 (private data) 803345 libc.so.1_pure_p3_c0_410_551 (shared code) 34868 libc.so.1_pure_p3_c0_410_551 (private data) 1216 libdl.so.1_pure_p3_c0_410_551 (shared code) 0 libdl.so.1_pure_p3_c0_410_551 (private data) 9576 libinternal_stubs.so.1 (shared code) 324 libinternal_stubs.so.1 (private data) triton:tests% Ian Haggard || [email protected] (work) || [email protected] (home) GNU/Linux -- "Oh, no, Mr Bill!" || #define employer_opinion !my_opinion .file "truetype3.cc" ! GNU C++ version egcs-2.90.21 971202 (egcs-1.00 release) (sparc-sun-solaris2.5.1) compiled by GNU C version 2.7.0. ! options passed: ! options enabled: -fpeephole -ffunction-cse -fkeep-static-consts ! -fpcc-struct-return -fexceptions -fcommon -fverbose-asm -fgnu-linker ! -fargument-alias -mepilogue -mapp-regs gcc2_compiled.: .section ".text" .align 4 .global foo__FG11__true_type .type foo__FG11__true_type,#function .proc 020 foo__FG11__true_type: .LLFB1: !#PROLOGUE# 0 save %sp,-112,%sp .LLCFI0: !#PROLOGUE# 1 mov %i0,%o0 b .LL4 nop b .LL3 nop .LL4: .LL3: ret restore .LLFE1: .LLfe1: .size foo__FG11__true_type,.LLfe1-foo__FG11__true_type .align 4 .global main .type main,#function .proc 04 main: .LLFB2: !#PROLOGUE# 0 save %sp,-120,%sp .LLCFI1: !#PROLOGUE# 1 add %fp,-17,%o1 mov %o1,%o0 call __11__true_type,0 nop add %fp,-17,%o1 mov %o1,%o0 call tifoo__H1Z11__true_type_X01_v,0 nop add %fp,-17,%o1 mov %o1,%o0 call __11__true_type,0 nop add %fp,-17,%o1 mov %o1,%o0 call tfoo__H1Z11__true_type_X01_v,0 nop add %fp,-17,%o1 mov %o1,%o0 call __11__true_type,0 nop add %fp,-17,%o1 mov %o1,%o0 call ifoo__FG11__true_type,0 nop add %fp,-17,%o1 mov %o1,%o0 call __11__true_type,0 nop add %fp,-17,%o1 mov %o1,%o0 call foo__FG11__true_type,0 nop mov 0,%i0 b .LL5 nop mov 0,%i0 b .LL5 nop .LL5: ret restore .LLFE2: .LLfe2: .size main,.LLfe2-main .section ".gnu.linkonce.t.tfoo__H1Z11__true_type_X01_v",#alloc,#execinstr .align 4 .weak tfoo__H1Z11__true_type_X01_v .type tfoo__H1Z11__true_type_X01_v,#function .proc 020 tfoo__H1Z11__true_type_X01_v: .LLFB3: !#PROLOGUE# 0 save %sp,-112,%sp .LLCFI2: !#PROLOGUE# 1 mov %i0,%o0 .LL9: ret restore .LLFE3: .LLfe3: .size tfoo__H1Z11__true_type_X01_v,.LLfe3-tfoo__H1Z11__true_type_X01_v .section ".gnu.linkonce.t.tifoo__H1Z11__true_type_X01_v",#alloc,#execinstr .align 4 .weak tifoo__H1Z11__true_type_X01_v .type tifoo__H1Z11__true_type_X01_v,#function .proc 020 tifoo__H1Z11__true_type_X01_v: .LLFB4: !#PROLOGUE# 0 save %sp,-112,%sp .LLCFI3: !#PROLOGUE# 1 mov %i0,%o1 ldub [%o1],%o0 .LL8: ret restore .LLFE4: .LLfe4: .size tifoo__H1Z11__true_type_X01_v,.LLfe4-tifoo__H1Z11__true_type_X01_v .section ".gnu.linkonce.t.ifoo__FG11__true_type",#alloc,#execinstr .align 4 .weak ifoo__FG11__true_type .type ifoo__FG11__true_type,#function .proc 020 ifoo__FG11__true_type: .LLFB5: !#PROLOGUE# 0 save %sp,-112,%sp .LLCFI4: !#PROLOGUE# 1 mov %i0,%o1 ldub [%o1],%o0 b .LL2 nop b .LL1 nop .LL2: .LL1: ret restore .LLFE5: .LLfe5: .size ifoo__FG11__true_type,.LLfe5-ifoo__FG11__true_type .section ".gnu.linkonce.t.__11__true_type",#alloc,#execinstr .align 4 .weak __11__true_type .type __11__true_type,#function .proc 0110 __11__true_type: .LLFB6: !#PROLOGUE# 0 save %sp,-112,%sp .LLCFI5: !#PROLOGUE# 1 mov %i0,%o0 .LL7: mov %o0,%i0 b .LL6 nop .LL6: ret restore .LLFE6: .LLfe6: .size __11__true_type,.LLfe6-__11__true_type .section ".eh_frame",#alloc,#write __FRAME_BEGIN__: .uaword .LLECIE1-.LLSCIE1 .LLSCIE1: .uaword 0x0 .byte 0x1 .byte 0x0 .byte 0x1 .byte 0x7c .byte 0x65 .byte 0xc .byte 0xe .byte 0x0 .byte 0x9 .byte 0x65 .byte 0xf .align 4 .LLECIE1: .uaword .LLEFDE1-.LLSFDE1 .LLSFDE1: .uaword .LLSFDE1-__FRAME_BEGIN__ .uaword .LLFB1 .uaword .LLFE1-.LLFB1 .byte 0x4 .uaword .LLCFI0-.LLFB1 .byte 0xd .byte 0x1e .byte 0x2d .byte 0x9 .byte 0x65 .byte 0x1f .align 4 .LLEFDE1: .uaword .LLEFDE3-.LLSFDE3 .LLSFDE3: .uaword .LLSFDE3-__FRAME_BEGIN__ .uaword .LLFB2 .uaword .LLFE2-.LLFB2 .byte 0x4 .uaword .LLCFI1-.LLFB2 .byte 0xd .byte 0x1e .byte 0x2d .byte 0x9 .byte 0x65 .byte 0x1f .align 4 .LLEFDE3: .uaword .LLEFDE5-.LLSFDE5 .LLSFDE5: .uaword .LLSFDE5-__FRAME_BEGIN__ .uaword .LLFB3 .uaword .LLFE3-.LLFB3 .byte 0x4 .uaword .LLCFI2-.LLFB3 .byte 0xd .byte 0x1e .byte 0x2d .byte 0x9 .byte 0x65 .byte 0x1f .align 4 .LLEFDE5: .uaword .LLEFDE7-.LLSFDE7 .LLSFDE7: .uaword .LLSFDE7-__FRAME_BEGIN__ .uaword .LLFB4 .uaword .LLFE4-.LLFB4 .byte 0x4 .uaword .LLCFI3-.LLFB4 .byte 0xd .byte 0x1e .byte 0x2d .byte 0x9 .byte 0x65 .byte 0x1f .align 4 .LLEFDE7: .uaword .LLEFDE9-.LLSFDE9 .LLSFDE9: .uaword .LLSFDE9-__FRAME_BEGIN__ .uaword .LLFB5 .uaword .LLFE5-.LLFB5 .byte 0x4 .uaword .LLCFI4-.LLFB5 .byte 0xd .byte 0x1e .byte 0x2d .byte 0x9 .byte 0x65 .byte 0x1f .align 4 .LLEFDE9: .uaword .LLEFDE11-.LLSFDE11 .LLSFDE11: .uaword .LLSFDE11-__FRAME_BEGIN__ .uaword .LLFB6 .uaword .LLFE6-.LLFB6 .byte 0x4 .uaword .LLCFI5-.LLFB6 .byte 0xd .byte 0x1e .byte 0x2d .byte 0x9 .byte 0x65 .byte 0x1f .align 4 .LLEFDE11: .ident "GCC: (GNU) egcs-2.90.21 971202 (egcs-1.00 release)"
