Dual Screen - Ubuntu 7.10
Ståle
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder3) Wed Sep 12 14:29:35 PDT 2007
# xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
# Uncomment if you have a wacom tablet
# InputDevice "stylus" "SendCoreEvents"
# InputDevice "cursor" "SendCoreEvents"
# InputDevice "eraser" "SendCoreEvents"
Identifier "Default Layout"
screen 0 "Default Screen" 0 0
Inputdevice "Generic Keyboard"
Inputdevice "Configured Mouse"
EndSection
Section "Files"
EndSection
Section "Module"
Load "glx"
Load "v4l"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "no"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Identifier "stylus"
Driver "wacom"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4"# Tablet PC ONLY
EndSection
Identifier "eraser"
Driver "wacom"
Option "Type" "eraser"
EndSection
Identifier "cursor"
Driver "wacom"
Option "Type" "cursor"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Vendorname "Generic LCD Display"
Modelname "LCD Panel 1280x1024"
Horizsync 31.5-64.0
Vertrefresh 56.0 - 65.0
modeline "640x480@60" 25.2 640 656 752 800 480 490 492 525 -vsync -hsync
modeline "800x600@56" 36.0 800 824 896 1024 600 601 603 625 +hsync +vsync
modeline "800x600@60" 40.0 800 840 968 1056 600 601 605 628 +hsync +vsync
modeline "1024x768@60" 65.0 1024 1048 1184 1344 768 771 777 806 -vsync -hsync
modeline "1280x960@60" 102.1 1280 1360 1496 1712 960 961 964 994 -hsync +vsync
modeline "1280x1024@60" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Gamma 1.0
EndSection
Section "Device"
Identifier "nVidia Corporation NV31 [GeForce FX 5600XT]"
Boardname "nv"
Busid "PCI:2:0:0"
Driver "nvidia"
Screen 0
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation NV31 [GeForce FX 5600XT]"
Monitor "Generic Monitor"
Defaultdepth 24
Option "AddARGBVisuals" "True"
Option "NoLogo" "True"
Option "AddARGBGLXVisuals" "True"
SubSection "Display"
Depth 24
Virtual 1280 1024
Modes "1280x1024@60" "1280x960@60" "1024x768@60" "800x600@60" "800x600@56" "640x480@60"
EndSubSection
EndSection
Section "device" #
Identifier "device1"
Boardname "nv"
Busid "PCI:2:0:0"
Driver "nvidia"
Screen 1
EndSection
Section "screen" #
Identifier "screen1"
Device "device1"
Defaultdepth 24
Monitor "monitor1"
EndSection
Section "monitor" #
Identifier "monitor1"
Gamma 1.0
EndSection
Section "ServerFlags"
EndSection
vil vell bli denne
skjerm en er en viewsonic på 17" kjører 1280X1024 koblet til med dvi , skjerm to er en LG på 42" koblet til med vga , oppløsningen på den er jeg ikke sikker på .
begge er lcd paneler
EDIT: vil kjøre 1280X1024 på 17" tommeren , den andre kan jeg tilpasse etterhvert , er usikker hva som er max på den .
skjerm 2 skal kun brukes til film i full skjerm , og være i clone av skjerm en
Endret av Mato
Ok, da regner jeg med at du nå har samme oppsett som indikert tidligere i tråden, rapportert av hwinfo, og den nyeste xorg.conf. Forsøk å bytte ut følgende seksjon i xorg.conf:
Section "Device"
Identifier "Failsafe Device"
Boardname "vesa"
Busid "PCI:2:0:0"
Driver "nvidia"
Screen 0
EndSection
Med følgende (ta back-up av xorg.conf før du begynner!):
Section "Device"
Driver "nvidia"
Option "TwinView" "True"
Option "TwinViewOrientation" "Clone" #replace with LeftOf, Above, Below, Clone
Option "UseEdidFreqs" "True"
Option "MetaModes" "1280x1024,1280x1024" #Resolution of each screen
Option "UseDisplayDevice" "DFP, CRT" #replace with 'DFP' (DVI port), 'CRT' (VGA
port) or 'TV'
# Option "NoTwinViewXineramaInfo" "0" #two screens, do not maximise window to both
# Option "Coolbits" "1" #enabling overclocking
EndSection
Så lurer jeg på om vi bør fjerne nederste del av xorg.conf, så fjern gjerne denne biten:
Section "device" #
Boardname "vesa"
Busid "PCI:2:0:0"
Driver "vesa"
Screen 1
EndSection
Section "screen" #
Device "device1"
Defaultdepth 24
Monitor "monitor1"
EndSection
Section "monitor" #
Gamma 1.0
EndSection
EndSection
må jeg reboote eller holder det og restarte x ( altså relogge ) ?
har ikke hatt helt tid til og sette på dette siden fredag . er jo så uendelig mye annet og fikle med her :p
EDIT:
# This file was generated by failsafeDexconf, using
# values from the debconf database and some overrides to use vesa mode.
# You should use dexconf or another such tool for creating a "real" xorg.conf
# For example:
Section "Files"
EndSection
Section "Module"
Load		"glx"
Load		"v4l"
EndSection
Driver		"kbd"
EndSection
Driver		"mouse"
EndSection
Section "Device"
	Driver "nvidia"
	Option "UseDisplayDevice" "DFP, CRT" #replace with 'DFP' (DVI port), 'CRT' (VGA port) or 'TV'
EndSection
Section "Monitor"
Identifier	"Failsafe Monitor"
Horizsync	31.5-64.0
Gamma	1.0
EndSection
Section "Screen"
Device		"Failsafe Device"
Monitor		"Failsafe Monitor"
Defaultdepth	24
	Depth	24
EndSubSection
EndSection
da ser xorg.conf sånn ut , time to reboot ... spennende ...
EDIT : det gjørde faktisk ikke noe så vidt jeg kan se , eneste er at det nå ikke er noe valg i screens and graphics .
flere gode ider ?
EDIT" : jeg har clone bilde gjennom helle booten , det forsvinner nå ubuntu logger inn.
Endret av Mato
jeg satt og så over de noen av de backup filene , er jo en del av de .
denne virker jo som er "bedre" og jobbe ut fra , ikke så mye failsafe devices og sånt .
Klikk for å se/fjerne innholdet nedenfor
# package.
Screen		 "Default Screen" 0 0
InputDevice	"Generic Keyboard"
InputDevice	"Configured Mouse"
EndSection
Section "Files"
EndSection
Section "Module"
Load		   "glx"
EndSection
Driver		 "kbd"
EndSection
Driver		 "mouse"
EndSection
Identifier	 "stylus"
Driver		 "wacom"
EndSection
Identifier	 "eraser"
Driver		 "wacom"
EndSection
Identifier	 "cursor"
Driver		 "wacom"
EndSection
Section "Monitor"
HorizSync	   30.0 - 70.0
VertRefresh	 50.0 - 160.0
Option		 "DPMS"
EndSection
Section "Device"
Driver		 "nvidia"
EndSection
Section "Screen"
DefaultDepth	24
	Depth	   24
	Modes	  "nvidia-auto-select"
EndSubSection
EndSection
Jeg likte den forrige bedre. Med den forrige kan du sjekke
hwinfo --gfxcard
igjen? Prøv også nvidia-settings, gå til X Server Display Configuration, og trykk Detect Displays med TV koblet til. Oppdages TV'en din, eventuelt en skjerm nummer to? Jeg vil tro den eneste endringen du trenger å gjøre i xorg.conf er å modifisere linjen her:
til å inkludere oppløsning som er støttet av TV, du kan prøve med flere slik:
Option "MetaModes" "1280x1024,1280x1024; 1280x1024,1280x768" #Resolution of each screen
mato@mato-ubuntu:~$ hwinfo --gfxcard
27: PCI 200.0: 0300 VGA compatible controller (VGA)
 [Created at pci.296]
 UDI: /org/freedesktop/Hal/devices/pci_10de_314
 Unique ID: B35A.DG2hAB9CTn8
 Parent ID: 6NW+.iXAqUzhMRkA
 SysFS ID: /devices/pci0000:00/0000:00:1e.0/0000:02:00.0
 SysFS BusID: 0000:02:00.0
 Hardware Class: graphics card
 Model: "Micro-Star International GeForce FX 5600XT"
 Vendor: pci 0x10de "nVidia Corporation"
 Device: pci 0x0314 "GeForce FX 5600XT"
 SubVendor: pci 0x1462 "Micro-Star International Co., Ltd."
 SubDevice: pci 0x9119
 Revision: 0xa1
 Driver: "nvidia"
 Driver Modules: "nvidia"
 Memory Range: 0xe4000000-0xe4ffffff (rw,non-prefetchable)
 Memory Range: 0xd0000000-0xdfffffff (rw,prefetchable)
 Memory Range: 0xe5000000-0xe501ffff (ro,prefetchable,disabled)
 IRQ: 19 (8602 events)
 I/O Ports: 0x3c0-0x3df (rw)
 Module Alias: "pci:v000010DEd00000314sv00001462sd00009119bc03sc00i00"
 Driver Info #0:
XFree86 v4 Server Module: nv
 Driver Info #1:
XFree86 v4 Server Module: nvidia
3D Support: yes
 Config Status: cfg=new, avail=yes, need=no, active=unknown
 Attached to: #25 (PCI bridge)
Primary display adapter: #27
mato@mato-ubuntu:~$
nyeste hwinfo --gfxcard
jeg er ikke så keen på og legge inn nvida-settings , sist jeg gjørde det ble skjermkonfigurasjonen min til grøt .
men jeg har jo nå viten om hvordan jeg fikser det tilbake til normalen , så her i go .
EDIT: Nvidia-settings funket fint nå , bilde på begge skjermen , dog i TwinView .
tusen takk for exelent hjelp .
Endret av Mato
btw hvis du har lyst og se hvordan min nyeste config ser ut så er det slik :
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 1.0  (buildd@vernadsky)  Fri Oct 12 21:39:58 GMT 2007
Identifier	 "Layout0"
Screen	  0  "Screen0" 0 0
InputDevice	"Keyboard0" "CoreKeyboard"
InputDevice	"Mouse0" "CorePointer"
EndSection
Section "Files"
RgbPath		 "/usr/X11R6/lib/X11/rgb"
EndSection
Section "Module"
Load		   "dbe"
Load		   "extmod"
Load		   "type1"
Load		   "freetype"
Load		   "glx"
EndSection
Option		 "Xinerama" "0"
EndSection
# generated from default
Identifier	 "Mouse0"
Driver		 "mouse"
Option		 "Protocol" "auto"
Option		 "Device" "/dev/psaux"
Option		 "Emulate3Buttons" "no"
EndSection
Identifier	 "Keyboard0"
Driver		 "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier	 "Monitor0"
VendorName	 "Unknown"
ModelName	  "LG 42LC3R-ZH"
HorizSync	   31.0 - 61.0
VertRefresh	 56.0 - 75.0
ModeLine	   "1280x1024@60" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Option		 "DPMS"
EndSection
Section "Device"
Identifier	 "Videocard0"
Driver		 "nvidia"
VendorName	 "NVIDIA Corporation"
BoardName	  "GeForce FX 5600XT"
EndSection
Section "Screen"
Identifier	 "Screen0"
får i vertfall bilde , men ikke film i full skjerm på tv , faktisk velger jeg full skjerm her så vises det kunne på denne skjermen .
men men jeg får tweake litt i morgen med dette , utsetter wine prosjektene mine enda en dag , er lenge sidne jeg har hatt det gøy med og konfigurere .
