Ståle Skrevet 10. november 2007 Del Skrevet 10. november 2007 Hei, har et lite problem med mbmon. stale@stale-ubuntu:~$ sudo mbmon -DProbe Request: none >>> Testing Reg's at SMBus <<< [intel8XX(ICH/ICH2/ICH3/ICH4/ICH5/ICH6), IO-Base:0x1880] SMBus slave 0x6E(0x37) found... SMBus slave 0xA0(0x50) found... SMBus slave 0xA2(0x51) found... SMBus[intel8XX(ICH/ICH2/ICH3/ICH4/ICH5/ICH6)] found, but No HWM available on it!! >>> Testing Reg's at ISA-IO <<< [iSA Port IO-Base:0x290] Probing Winbond/Asus/LM78/79 chip: CR40:0xFF, CR41:0xFF, CR42:0xFF, CR43:0xFF CR44:0xFF, CR45:0xFF, CR46:0xFF, CR47:0xFF CR48:0xFF, CR49:0xFF, CR4A:0xFF, CR4B:0xFF CR4C:0xFF, CR4D:0xFF, CR4E:0xFF, CR4F:0xFF CR56:0xFF, CR58:0xFF, CR59:0xFF, CR5D:0xFF CR3E:0xFF, CR13:0xFF, CR17:0xFF, CRA1:0xFF CR20:0xFF, CR22:0xFF, CR23:0xFF, CR24:0xFF CR27:0xFF, CR29:0xFF, CR2A:0xFF, CR2B:0xFF No Hardware Monitor found!! InitMBInfo: Success stale@stale-ubuntu:~$ Jeg har en liten CPU kontroll ting i "start menyen", som jeg kan se temp og klokkehastighet pa . Sa det burde jo vaere en chip i maskinen. I windows xp kan jeg se CPU og HDD temp. Lenke til kommentar
anders iver Skrevet 10. november 2007 Del Skrevet 10. november 2007 dersom du bare skal ha opp temperaturen på komponentene dine burde sensors gjøre samme jobben. bruk sensors-detect for å finne og konfigurere sensorene dine. Lenke til kommentar
Ståle Skrevet 10. november 2007 Forfatter Del Skrevet 10. november 2007 stale@stale-ubuntu:~$ sensorsNo sensors found! Make sure you loaded all the kernel drivers you need. Try sensors-detect to find out which these are. stale@stale-ubuntu:~$ sudo sensors-detect [sudo] password for stale: # sensors-detect revision 4609 (2007-07-14 09:28:39 -0700) This program will help you determine which kernel modules you need to load to use lm_sensors most effectively. It is generally safe and recommended to accept the default answers to all questions, unless you know what you're doing. We can start with probing for (PCI) I2C or SMBus adapters. Do you want to probe now? (YES/no): yes Probing for PCI bus adapters... Use driver `i2c-i801' for device 0000:00:1f.3: Intel 82801CA/CAM ICH3 We will now try to load each adapter module in turn. Module `i2c-i801' already loaded. If you have undetectable or unsupported adapters, you can have them scanned by manually loading the modules before running this script. To continue, we need module `i2c-dev' to be loaded. Do you want to load `i2c-dev' now? (YES/no): yes Module loaded successfully. We are now going to do the I2C/SMBus adapter probings. Some chips may be double detected; we choose the one with the highest confidence value in that case. If you found that the adapter hung after probing a certain address, you can specify that address to remain unprobed. Next adapter: SMBus I801 adapter at 1880 (i2c-0) Do you want to scan it? (YES/no/selectively): yes Client found at address 0x50 Handled by driver `eeprom' (already loaded), chip type `eeprom' (note: this is probably NOT a sensor chip!) Client found at address 0x51 Handled by driver `eeprom' (already loaded), chip type `eeprom' (note: this is probably NOT a sensor chip!) Next adapter: NVIDIA i2c adapter (i2c-1) Do you want to scan it? (YES/no/selectively): yes Next adapter: NVIDIA i2c adapter (i2c-2) Do you want to scan it? (YES/no/selectively): yes Next adapter: NVIDIA i2c adapter (i2c-3) Do you want to scan it? (YES/no/selectively): yes Some chips are also accessible through the ISA I/O ports. We have to write to arbitrary I/O ports to probe them. This is usually safe though. Yes, you do have ISA I/O ports even if you do not have any ISA slots! Do you want to scan the ISA I/O ports? (YES/no): yes Probing for `National Semiconductor LM78' at 0x290... No Probing for `National Semiconductor LM78-J' at 0x290... No Probing for `National Semiconductor LM79' at 0x290... No Probing for `Winbond W83781D' at 0x290... No Probing for `Winbond W83782D' at 0x290... No Probing for `Silicon Integrated Systems SIS5595'... No Probing for `VIA VT82C686 Integrated Sensors'... No Probing for `VIA VT8231 Integrated Sensors'... No Probing for `IPMI BMC KCS' at 0xca0... No Probing for `IPMI BMC SMIC' at 0xca8... No Some Super I/O chips may also contain sensors. We have to write to standard I/O ports to probe them. This is usually safe. Do you want to scan for Super I/O sensors? (YES/no): yes Probing for Super-I/O at 0x2e/0x2f Trying family `National Semiconductor'... Yes Found `Nat. Semi. PC8739x Super IO' (no hardware monitoring capabilities) Probing for Super-I/O at 0x4e/0x4f Trying family `National Semiconductor'... No Trying family `SMSC'... No Trying family `VIA/Winbond/Fintek'... No Trying family `ITE'... No Some CPUs or memory controllers may also contain embedded sensors. Do you want to scan for them? (YES/no): yes AMD K8 thermal sensors... No Intel Core family thermal sensor... No Intel AMB FB-DIMM thermal sensor... No Sorry, no sensors were detected. Either your sensors are not supported, or they are connected to an I2C or SMBus adapter that is not supported. See doc/FAQ, doc/lm_sensors-FAQ.html or http://www.lm-sensors.org/wiki/FAQ (FAQ #4.24.3) for further information. If you find out what chips are on your board, check http://www.lm-sensors.org/wiki/Devices for driver status. Lenke til kommentar
Sokkalf™ Skrevet 10. november 2007 Del Skrevet 10. november 2007 (endret) Med nye CPUer og disker trenger du ikke en sensorchip for å se temperaturene. HDD-temp kan avleses med SMART, CPU-temp kan hos meg avleses i fila "/proc/acpi/thermal_zone/THM/temperature". Endret 10. november 2007 av Sokkalf^ Lenke til kommentar
Ståle Skrevet 10. november 2007 Forfatter Del Skrevet 10. november 2007 hvor finner jeg SMART? Hadde ikke den filen jeg. Hvor ny er ny? Denne PC-en er fra ~2002 med en P4 Mobile CPU. Lenke til kommentar
Sokkalf™ Skrevet 10. november 2007 Del Skrevet 10. november 2007 # smartctl --all /dev/sda | grep Temp 194 Temperature_Celsius 0x0002 125 125 000 Old_age Always - 44 (Lifetime Min/Max 19/2286) Sånn ser jeg HD-temp, trenger pakken smartmontools. Lenke til kommentar
Ståle Skrevet 10. november 2007 Forfatter Del Skrevet 10. november 2007 Men ingen av de der er jo temperaturen. :errm: sorry for at jeg er helt ute na altsa Lenke til kommentar
Sokkalf™ Skrevet 10. november 2007 Del Skrevet 10. november 2007 44 er temperaturen. Så er lifetime minimum 19. Lifetime max ville jeg ikke stolt på i dette tilfellet, siden den er på 2286°. Lenke til kommentar
Ståle Skrevet 10. november 2007 Forfatter Del Skrevet 10. november 2007 stale@stale-ubuntu:~$ sudo smartctl --all /dev/sda | grep Temp194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 43 (Lifetime Min/Max 14/52) Hmm.. det var litt rart. Fordi Windows rapporterer den til a ligge mellom 55 og 60, og der gjor den app-en som ligger pa "startmenyen" i Ubuntu ogsa. CPUen er en Pentium 4 Mobile Northwood pa 1.7 GHz, som klokker seg selv ned til 1.2GHz nar "all den" prossessorkraften ikke trengs. Viften gar temmelig ofte, da ligger den pa ~63-66 i Windows og app-en. Lenke til kommentar
