Trenger help med forumet mitt!
Mitt forum så går det ann å bare trykke på submit knappen.
Så jeg lurte på om noen av dere ville hjelpe meg å lage sånn at: Vis du lar navnet være tomt kommer det sånn: Venligst skriv inn navnet ditt!
Kunne du lagd noe sånt ? =)
2 Filer:
Her er der du skal ta koden: (prossensen for å lege til posten)
<?php
$host="**"; // Host name
$username="**"; // Mysql username
$password="**"; // Mysql password
$db_name="**"; // Database name
$tbl_name="**"; // Table name
// Connect to server and select database.
mysql_connect("$host", "$username", "$password")or die("cannot connect");
mysql_select_db("$db_name")or die("cannot select DB");
// get data that sent from form
$topic=$_POST['topic'];
$detail=$_POST['detail'];
$name=$_POST['name'];
$email=$_POST['email'];
$datetime=date("d/m/y h:i:s"); //create date time
$sql="INSERT INTO $tbl_name(topic, detail, name, email, datetime)VALUES('$topic', '$detail', '$name', '$email', '$datetime')";
$result=mysql_query($sql);
if($result){
echo "Successful<BR>";
echo "<a href=main_forum.php>View your topic</a>";
else {
echo "ERROR";
mysql_close();
Her er for å lage nytt innlegg: (navn tekst osv...)
<table width="400" border="0" align="center" cellpadding="0" cellspacing="1" bgcolor="#CCCCCC">
<tr>
<form id="form1" name="form1" method="post" action="add_topic.php">
<td>
<table width="100%" border="0" cellpadding="3" cellspacing="1" bgcolor="#FFFFFF">
<tr>
<td colspan="3" bgcolor="#E6E6E6"><strong>Create New Topic</strong> </td>
</tr>
<tr>
<td width="14%"><strong>Topic</strong></td>
<td width="2%">:</td>
<td width="84%"><input name="topic" type="text" id="topic" size="50" /></td>
</tr>
<tr>
<td valign="top"><strong>Detail</strong></td>
<td valign="top">:</td>
<td><textarea name="detail" cols="50" rows="3" id="detail"></textarea></td>
</tr>
<tr>
<td><strong>Name</strong></td>
<td>:</td>
<td><input name="name" type="text" id="name" size="50" /></td>
</tr>
<tr>
<td><strong>Email</strong></td>
<td>:</td>
<td><input name="email" type="text" id="email" size="50" /></td>
</tr>
<tr>
<td> </td>
<td> </td>
<td><input type="submit" name="Submit" value="Submit" /> <input type="reset" name="Submit2" value="Reset" /></td>
</tr>
</table>
</td>
</form>
</tr>
</table>
Håper du kan skrive koden her :thumbup:
Endret av php_user
Jada :D
En kode slik at bare jeg kan slette trådene. At jeg kan merke av de jeg vil slette og slette dem, uten noen sånn admin kontrollpanel osv..
Vil ha slik som nordicmafia moderatorene! De kan bare trykke på slett så forsvinner tråden.
Har du noen kode for slikt ?
