Hva er forskjell på disse to Windows'ene?
OEM har ikke support hos Microsoft
Sitat"OEM versions
Restrictions of specific license types may limit the foregoing. OEM versions of Windows XP are licensed together with the hardware with which they are purchased, as an entity, and such a copy may not be moved to a different computer. Also, other specific license types (e.g., Academic licenses) are handled in different ways. These aren’t a WPA issue per se, but rather an issue of the license for that purchase, and therefore outside the scope of this discussion of WPA.
There are two versions of OEM Windows XP systems. One can be purchased separately, with qualifying subsidiary hardware, and installed with that hardware to an existing machine, to which it becomes bound. The software may be reinstalled and reactivated indefinitely as with a retail system as long as it is still on the original machine. It may not be transferred to a different computer. It is activated as described above, but if it were installed to hardware seen as not substantially the same, the activation would be refused as falling outside the license.
In the other OEM form, the system is provided pre-installed by a major supplier. Instead of activation, the system is ‘locked’ to the BIOS on the motherboard. The validity of this lock is checked at boot. As long as this is satisfied, other hardware may be changed freely, but any replacement motherboard must be for a compatible one supplied by the original maker."
Endret av Diesel_
