Xp-antispy.de, fjerning av regsrv32, hva skjer?
Hei; går igjennom tipsene til xp-antispy, men hva slags effekt/handling vil skje hvis jeg utfører handlinge under?
Regsvr32: Unregister Regwizc.dll - Select Start->Run, enter in the upcoming dialogbox 'regsvr32 /u regwizc.dll' and press return. a messgebox should pop up, telling you that regwizc.dll was unregistered successfully.
Regsvr32: Unregister licdll.dll - Select Start->Run, enter in the upcoming dialogbox 'regsvr32 /u licdll.dll' and press return. a messgebox should pop up, telling you that licdll.dll was unregistered successfully.
