[løst][Løst]Feilmeldinger i oppstarten
Initializing Intel® Boot Agent GE v1.2.31
PXE-E05: The LAN adapter's configuration is corrupted or
has not been initialized. The Boot Agent cannot continue.
ERROR Expansion ROM not initialized - PCI on Motherboard
Bus:00, Device:00, Function:00Press
<ESC> to continue
Dette er ein IBM T60.
Forslag? :)
EDIT: Fant ein løysning:
The EEPROM of the Ethernet ship need a factory reconfiguration (reset). To make this, I made a bootable CD-ROM, to simplify the procedure, based on a solution found in the thinkpads.com forum...
“ Download PROBOOT.EXE from Intel. Get the first one from the list - the one without Network adapter, it says only "Intel® Boot Agent PROBOOT.exe version: 11.2", install that - it will create a folder with some files - put these on a bootable floppy (or two) or a bootable CD. Boot to DOS with the floppy or CD and run "IBAUtil.exe -DEFCFG" that will reset the configuration and all should be OK „
My Thinkpad don't have a floppy reader (and it is not only), no problem, I made a CD-ROM boot-disk for this.
1.- Download CDProBoot ISO image and burn it with your favorite burner (with Nero: Recorder -> Burn Image...)
2.- Boot your PC with this CD-ROM and follow the indications to reset your Intel Ethernet ship.
!! NEW version 0.2 !! correct the problem encountered in the comments below.
- CDProBOOT-0.2.iso - FreeDOS boot cd-rom, customized with PROBoot Intel tools and a DOS menu selector.
- md5sum: c12babeec8e1a0e9072e95575f32a69a
After a reboot, perfect, no more BXE-Boot error!
This cd-rom bootdisk (ISO) can be used for all Intel WfM-compatible adapter.
Denne kan stenges.
Endret av nefrums
Gjest
