Hva menes med dvd screener?
What's CAM, Workprint, Telesync, Telecine, Screener,DVDRip, Subbed?
Different types of bootlegged video that can be in VCD,SVCD,DVD or DivX format.
CAM - This type of VCD was recorded by someone in a cinema with a camcorder and the audience can be heard! The picture quality is usually OK but the sound is mostly very bad and hard to make out speech.
Telesync - These are also recorded in a cinema but usually on an expensive camera and they should have a seperate audio source (so the audience cannot be heard), these are generally very good quality and highly watchable.
Telecine - Done a number of ways, all from taking directly from the reel. Ripped in either widescreen (letterbox) or in full-screen (pan and scan) with excellent audio and video. The most common way is to get a device that you attach to the reel that generates a VHS tape of the reel. (called a telecine machine, but there are other machines that generate a digital output of both audio and video that are then put into a laptop or VCR and made into a VCD).
Screener - A Screener is usually recorded form a promotional video tape which is sent to censors and film critics etc.. The quality is usually as good as a commercial VCD, some times a copyright message appears on the screen.
Work-Print - Each fram of the film is copied from celluloid (or another source), these are sometimes incomplete movies. The sound is usually perfect and the visual quality can vary.
LD/DVDRip - VCDs with this on the cover are ripped from DVD or Laserdisc versions of the film and the quality is as good as genuine VCDs.
Other bootleg info
Subbed - They have sub-titles. Sometimes only 1, that are real small. But others are real big and some movies have 2 or 3 subtitles on them taking up large portions of the screen.
Watermarks - The little BD, A, or Z (among others) symbols on the movie. They are put there buy the people in Asia who rip the movie.
