MPI, få *hele* cout's
Hei!
Jeg driver å debugger et program skrevet for MPI (cluster/multithreading-bibliotek), og legger derfor inn en del cout's.
Problemet er at utskriftene fra disse kommer hulter-i-bulter, som vist under:
[kyrre@sinus taskB]$ mpiexec.py -n 3 ./vmc_atoms 2 2 3 5 1.0 100 10000 out.dat
Running with configuration:
Number of particles			 = 2
Charge of nucleus (Z)		   = 2
Dimensionality				  = 3
Maximum variational parameters  = 5
Step length (MC)				= 1
Thermalization cutoff		   = 100
Number of MC integration cycles = 10000
Writing to file with name (in .): out.dat
Slave 1 awaiting orders...
Slave 1 got alpha = 1
Master warming up...
Sending alpha = 1 to slave 1
Now pending: 1 numprocs = 3
Sending alpha = 1.1 to slave 2
Now pending: 2 numprocs = 3
slavesearcher >= numprocs; This *REALLY* should not happen!
Slave 2 awaiting orders...
Slave 2 got alpha = 1.1
rank 0 in job 95  sinus_59205   caused collective abort of all ranks
 exit status of rank 0: return code 2
Noen som har en idé på hvordan man kan få cout's til å bli "atomiske"?
Endret av kyrsjo
Ok, den der var litt "heldig", var trøtt når jeg posta. Mente mer slik som dette:
kyrrens@motstand ~/computational/oblig4/code/taskB $ mpiexec -n 24 nice -n 19 ./vmc_atoms 2 2 3 20 1.0 10000000 100000 out-detailed-test2.dat 1.6 0.01
Dimensionality				  = 3
Maximum variational parameters  = 20
Thermalization cutoff		   = 10000000
Number of MC integration cycles = 100000
Writing to file with name (in .): out-detailed-test2.dat
Starting with alpha			 = 1.6
alpha steplength				= 0.01
Sending alpha = Slave Slave Slave 5 awaiting orders...
4 awaiting orders...Slave
3 awaiting orders...1.62 awaiting orders...
Slave 6 to slave  awaiting orders...
Slave 7 awaiting orders...1
Now pending: 1
numprocs = 24
Sending alpha = 1.61 to slave 2
Now pending: 2Slave  numprocs = 242 got alpha = 1.61
Sending alpha = 1.62 to slave 3
Now pending: 3Slave  numprocs = 3 got alpha = 1.62
24
Sending alpha = 1.63 to slave 4
Now pending: 4Slave 4 numprocs =  got alpha = 1.6324
Sending alpha = 1.64 to slave 5
Now pending: 5 numprocs = Slave 5 got alpha = 1.64
24
Sending alpha = 1.65 to slave 6
Now pending: Slave 6 numprocs = 6 got alpha = 1.65
24
Sending alpha = 1.66 to slave 7
Now pending: 7 numprocs = 24
Slave Sending alpha = 1.677 got alpha =  to slave 1.66
8
Now pending: 8 numprocs = 24
Sending alpha = 1.68 to slave 9
Now pending: 9 numprocs = 24
Sending alpha = 1.69 to slave 10
Now pending: 10 numprocs = 24
Sending alpha = 1.7 to slave 11
Slave Slave Slave Slave 12 awaiting orders...
Slave 14 awaiting orders...
13 awaiting orders...
9 awaiting orders...
Slave Slave 9 got alpha = Slave 8 awaiting orders...1.68
15
11 awaiting orders...
Slave 10 awaiting orders... awaiting orders...Slave 8
Slave
got alpha = 1.67
10 got alpha = 1.69Now pending:
11Slave 11 got alpha = 1.7
numprocs = 24
Sending alpha = 1.71 to slave 12
Slave 1 got alpha = 1.6
Now pending: 12Slave 12 got alpha =  numprocs = 1.71
24
Sending alpha = 1.72 to slave 13
Now pending: 13 numprocs = Slave 2413 got alpha = 1.72
Sending alpha = 1.73 to slave 14
Now pending: 14 numprocs = Slave 2414 got alpha = 1.73
Sending alpha = 1.74 to slave 15
Now pending: 15 numprocs = 24
Slave Sending alpha = 151.75 got alpha = 1.74
to slave 16
Now pending: 16 numprocs = 24
Sending alpha = 1.76 to slave 17
Now pending: 17 numprocs = 24
Sending alpha = 1.77 to slave 18
Now pending: 18 numprocs = 24
Sending alpha = 1.78 to slave 19
Now pending: 19 numprocs = 24
Sending alpha = 1.79 to slave 20
Now pending: 20 numprocs = 24
Slave 17 awaiting orders...Slave
Slave 1716 awaiting orders...Slave  got alpha =
Slave 161.76
Slave 18 awaiting orders...
Slave 18 got alpha = Slave Slave 19 got alpha = 1.75
1.77
Slave 22 awaiting orders...
2120 awaiting orders... awaiting orders...
Slave
awaiting orders...
Slave 19 got alpha = Slave 20231.78 got alpha =  awaiting orders...
1.79
Det tror jeg ikke er mulig sånn helt uten videre siden dette er separate prosesser som skriver til skjerm. Den enkleste løsningen, slik jeg ser det, er å ha en egen prosess som skriver ut debugginsinfo for de andre prosessene. Infoen sendes da fra kjørende prosesser og skrives til skjerm fortløpende av debuggingsprosessen.
Ørjan...
Ørjan...
Alt for å gjøre programmet ytterligere komplisert :)
Har droppa noen utskrifter og funnet bugg'en(e), så nå gir jeg egentlig litt f. i at det ser stygt ut under kjøring. Svarene kommer jo (omsider... 5*10^7+5*10^5 montecarlopunkter pr. integral, 20 integraler... :) )
Du kan jo alltids bruke printf for å få en linje pr thread
For da sendes hele greia som "en streng"? Har lagt merke til at de ofte deles mellom "<<"'ene...
Stemmmer, hver << er jo en funksjon så CPUen bytter litt mellom de vil jeg tro. En annen måte som gjør strengt tatt det samme, men lar deg bruke cout
er å legge mutexer rundt hver av cout linjene, det gir vel også en bedre forklaring på hvorfor du gjør som du gjør også når andre leser koden din.
Endret av Giddion
