Først sett inn dette i klassen din...
[DllImport("kernel32.dll")]
private static extern long GetVolumeInformation(string PathName, StringBuilder VolumeNameBuffer, UInt32 VolumeNameSize, ref UInt32 VolumeSerialNumber, ref UInt32 MaximumComponentLength, ref UInt32 FileSystemFlags, StringBuilder FileSystemNameBuffer, UInt32 FileSystemNameSize);
Lag deretter en funksjon alla dette...
public string GetDriveName(string drive)
           //receives volume name of drive
           StringBuilder volname = new StringBuilder(256);
           //receives serial number of drive,not in case of network drive(win95/98)
           long sn= new long();
           long maxcomplen = new long();//receives maximum component length
           long sysflags = new long();//receives file system flags
           StringBuilder sysname = new StringBuilder(256);//receives the file system name
           long retval= new long();//return value
           retval = GetVolumeInformation(drive, volname, 256, sn, maxcomplen,
                                         sysflags, sysname,256);
           if(retval!=0)return volname.ToString();
           else return "";
Til slutt kan du finne navnet med...
string strDriveName = getDriveName("D:"); //viktig at du avslutter med en backslash
