Er det plass til xp på i-ram?
andper
Here's What You Need to Use Windows XP Professional
• PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Du kan få xp mye mindre, under 500MB uten problem, Lykke til. Husk sidevekslings fila tar mye plass da
Men går det ikke ann å gjøre det slik at du tar operativsystemet på en I-ram? også alt annet du skal lagre på vanlige harddisker?=/
