Aerlas Skrevet 29. oktober 2007 Rapporter Del Skrevet 29. oktober 2007 btw til xps brukere, fant en tøft programm som fiksa lysa litt!! http://media.putfile.com/M170-Lights Lenke til kommentar
Aerlas Skrevet 29. oktober 2007 Rapporter Del Skrevet 29. oktober 2007 CPU: 1440x900 medium settings TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s) !TimeDemo Run 0 Finished. Play Time: 72.69s, Average FPS: 20.64 Min FPS: 3.97 at frame 196, Max FPS: 28.08 at frame 119 Average Tri/Sec: 15894710, Tri/Frame: 770251 Recorded/Played Tris ratio: 0.93 !TimeDemo Run 1 Finished. Play Time: 63.44s, Average FPS: 23.64 Min FPS: 3.97 at frame 196, Max FPS: 29.78 at frame 120 Average Tri/Sec: 18350028, Tri/Frame: 776069 Recorded/Played Tris ratio: 0.93 !TimeDemo Run 2 Finished. Play Time: 63.09s, Average FPS: 23.78 Min FPS: 3.97 at frame 196, Max FPS: 29.78 at frame 120 Average Tri/Sec: 18364270, Tri/Frame: 772396 Recorded/Played Tris ratio: 0.93 !TimeDemo Run 3 Finished. Play Time: 63.84s, Average FPS: 23.50 Min FPS: 3.97 at frame 196, Max FPS: 29.78 at frame 120 Average Tri/Sec: 18369148, Tri/Frame: 781805 Recorded/Played Tris ratio: 0.92 TimeDemo Play Ended, (4 Runs Performed) GPU: 1440x900 medium settings TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s) !TimeDemo Run 0 Finished. Play Time: 90.12s, Average FPS: 22.19 Min FPS: 10.39 at frame 769, Max FPS: 31.90 at frame 988 Average Tri/Sec: 18785090, Tri/Frame: 846431 Recorded/Played Tris ratio: 1.08 !TimeDemo Run 1 Finished. Play Time: 84.19s, Average FPS: 23.76 Min FPS: 6.87 at frame 1909, Max FPS: 35.49 at frame 61 Average Tri/Sec: 20302144, Tri/Frame: 854621 Recorded/Played Tris ratio: 1.07 !TimeDemo Run 2 Finished. Play Time: 87.19s, Average FPS: 22.94 Min FPS: 6.87 at frame 1909, Max FPS: 35.49 at frame 61 Average Tri/Sec: 19603966, Tri/Frame: 854589 Recorded/Played Tris ratio: 1.07 !TimeDemo Run 3 Finished. Play Time: 89.16s, Average FPS: 22.43 Min FPS: 6.87 at frame 1909, Max FPS: 35.49 at frame 61 Average Tri/Sec: 19154450, Tri/Frame: 853920 Recorded/Played Tris ratio: 1.07 TimeDemo Play Ended, (4 Runs Performed) Lenke til kommentar
Gjest Skrevet 29. oktober 2007 Rapporter Del Skrevet 29. oktober 2007 (endret) Prøvde å kjøre Benchmark_GPU.bat på min bærbare, Rock X770 med 2.4GHz Core Duo og 8700M GT klokket til 700/885... edit: Prøvde igjen uten overklokking og det samme skjedde... Den kjører 4 eller 5 runs og så stopper den og crysis har klikket. Men men... får rundt 25fps average i hvert fall, så det er jo noe info heh Oi, du har en Rock X770! Hvordan fikk du tak i den, og hvor mye kostet den deg? Forsøk forresten å oppgradere skjermkortdriveren og se om det hjelper.. Jeg ser forresten at dere må kjøre ned oppløsningen enten dere har en Toshiba x200 eller Dell XPS M1710. Hvordan blir bildekvaliteten da siden det egentlig er svært ukurant å ikke benytte en LCD-skjerms native / fysiske oppløsning (henholdsvis 1680x1050 for Toshiba'en og syke 1920x1200 på XPS'en)? Hvis jeg kjører World of Warcraft i enn lavere oppløsning enn 1440x1050 på min bærbare, så blir all tekst utrolig kantete og j*velig å lese. Savner for øvrig Asus G1S/G2S-resultater her, og er det ingen som har SLI-utgaven av Toshiba x200'en? Endret 29. oktober 2007 av Gjest Lenke til kommentar
FJERNET111 Skrevet 29. oktober 2007 Rapporter Del Skrevet 29. oktober 2007 Oi, du har en Rock X770! Hvordan fikk du tak i den, og hvor mye kostet den deg? Forsøk forresten å oppgradere skjermkortdriveren og se om det hjelper.. Er strengt tatt min lillebror sin, men jeg har lekt en del med den Er bare å bestille på sidene deres, http://rockdirect.co.uk/ og den kostet 24 000 inkludert tollavgift og mva, ,har blitt litt billigere nå så vidt jeg kan se. Skjermkortdriverene er de nyeste 169.01 beta-driverene fra nVidia så de er oppgradert, men har lest at noen har hatt litt trøbbel med disse. Lenke til kommentar
SPiLL Skrevet 29. oktober 2007 Forfatter Rapporter Del Skrevet 29. oktober 2007 Det er også mulig å kjøre Crysis i DX9 mode for de som har Vista og DX10 kort. Høyre klikke på Crysis og velg DX9. Fikk en del bedre FPS på det og det ser fortsatt veldig bra ut Lenke til kommentar
ven Skrevet 29. oktober 2007 Rapporter Del Skrevet 29. oktober 2007 hva slags maskin kjører du på enelias? Lenke til kommentar
Gjest Skrevet 29. oktober 2007 Rapporter Del Skrevet 29. oktober 2007 Jeg har en xps 1710 med 2gb ram, geforce 7950GTx og dualcore intel 2,2. Lenke til kommentar
another_visitor Skrevet 29. oktober 2007 Rapporter Del Skrevet 29. oktober 2007 Hva vil dere gamere som har god peil på tallene si til nå om forskjellene mellom Dell XPS m1710 med 7950 GTX, og Toshiba X200 med 8700 GT, er det merkbare forskjeller? Lenke til kommentar
Aerlas Skrevet 30. oktober 2007 Rapporter Del Skrevet 30. oktober 2007 Hva vil dere gamere som har god peil på tallene si til nå om forskjellene mellom Dell XPS m1710 med 7950 GTX, og Toshiba X200 med 8700 GT, er det merkbare forskjeller? Geforce 8 har støtte for DX10 såvidt jeg vet. ytelses messig ligger du sikkert en 10-15% over meg tror jeg. er ikke helt sikker på hvor graftig 8700GT er i forhold til 8800Gt kortet Lenke til kommentar
jon_o Skrevet 30. oktober 2007 Rapporter Del Skrevet 30. oktober 2007 Om man sammenligner kortee i 3dMark, er 7950gtx bedre enn 8700GT. Lenke Hva som er best i spill er likevel noe annet. Etterhvert som DX10 får fotfeste, er det vel grunn til å tro at 8700GT vil bli bedre enn 7950 (altså levere et bedre resultat). Lenke til kommentar
another_visitor Skrevet 30. oktober 2007 Rapporter Del Skrevet 30. oktober 2007 Har hørt at de kortene vi snakker om her (f.eks 8700 GT) uansett vil komme til kort innen DX10 får fotfeste, så spørs om dette med DX10 har så mye å si ved laptop kjøp akkurat nå. Si fra om noen veit bedre tho I Crysis testene her ser det ut som folk får bedre resultater med 8700GT ved å kjøre i DX9? Kan se ut som 7050 GTX ligger 7-800 over i 3DMark05 & 06, er dette merkbart? Grunnen til at jeg lurer så fælt er denne tråden: https://www.diskusjon.no/index.php?showtopic=844807&hl= Lenke til kommentar
