Crysis screenshots tråden!
Gjest Arveen
Nå har jeg dessverre ikke fått ned Crysis ennå, men andre spill jeg har testet så er det aa og af den reagerer på, mest af som er høy, satte ned af i The Witcher og det doblet nesten fpsen, resten var makset ut og alt anna godsaker var på. Så det er bare aa\af som "ødelegger".
Beklager jeg mente AF ikke AA. Rota litt nå :blush:
Endret av Fluesopp
Nå pakker den ut :D
Både div. Vista og X64 filer her, så det kan være den er 1.8GB pga ekstra support for x64 osv. Lurer på hva ytelsen er i WinXP 64bit med Quad.
EDIT:
Ferdig installert... jeg blir borte litt hehe
EDIT2:
Kjekt å vite for Vista brukere.
Memory
management within Windows Vista has changed a bit which makes it
more memory demanding. Microsoft released a patch to improve this
situation. More details and the download can be found there:
http://support.microsoft.com/kb/940105
Og bedre ytelse i 64bit OS
Modern processors now support 64bit which mostly improves their
memory managing capabilities. This feature is only available if
the operating system support 64bits. As Crysis is demanding in its
memory requirements it can benefit from a 64bit OS. On a 64bit system
the engine texture streaming can be disabled as the operating
system can handle all data in a level. 64bit also supports more
main memory available for each application. Both are beneficial and
can result in improved frame rate and frame rate stability.
Endret av Theo343
Quad og SLI etc.
Multiple processors allow processing of some tasks in parallel which
mostly improves computational heavy situations like explosions.
The game utilizes multiple processors automatically.
Some hardware vendors have solutions to utilize multiple graphic
cards in parallel (e.g. Crossfire or SLI) and that can greatly improve
render performance. This requires the engine to run in the
"MultiGPU" mode. The speedup depends on the scene and system
properties like the main processor performance. Frame rate can be
less stable but is often much higher.
argh, 2 ganger har jeg prøvd å kjøre spillet og begge gangene har jeg gruse-kræsja... :p
ene gangen var det d3d fil som var synder, oppdaterte nettopp directx jo...
og andre gangen tryna gfx driveren tror jeg, blei bare skurr på skjermen og
måtte re-installere driveren etterpå da instillingene var låst i 4bit:p
nice... og hvilken FPS klarte maskinen din på det der Avean?
25 fps hehe.
8800 Ultra @ 700/2400
4Gb Dominator 8500
Quad 3,0 Ghz
Sier seg selv at spillet her trenger JÆVLIG mye optimalisering. Spilte det uten AA påslått også. Rimelig slap in the face for min del, men gud kor digg spill.
Regner med det er DX10 ja, har jo all fysikken osv rundt meg. Kjører på Vista 64 men må kjøre spillet i 32-bit da 64-bit exe fila ikke funker :(
Endret av Avean
