Problemer med Samba
Har satt opp samba som PDC, og fikk meldt windowsmaskiner inn i domenet og alt funka gull. Så skulle jeg prøve å få ldap til å fungere sammen med samba, og konfigurerte smb.conf og la til disse linjene under global
passdb backend = ldapsam:ldap://127.0.0.1
ldap passwd sync = Yes
ldap suffix = dc=tklab,dc=local
ldap admin dn = cn=admin,dc=tklab,dc=local
ldap ssl = start tls
ldap user suffix = ou=People
ldap machine suffix = ou=Computers
ldap idmap suffix = ou=People
add user script = /usr/sbin/smbldap-useradd -m "%u"
ldap delete dn = Yes
add machine script = /usr/sbin/smbldap-useradd -w "%u"
Deretter restarta jeg samba serveren, og når jeg videre skulle prøve å melde inn en windowsmaskin fikk jeg denne meldinga:
The following error occurred when DNS was queried for the service location (SRV) resource record used to locate a domain controller for domain tklab.:
The error was: "DNS name does not exist."
(error code 0x0000232B RCODE_NAME_ERROR)
The query was for the SRV record for _ldap._tcp.dc._msdcs.tklab.
Common causes of this error include the following:
- The DNS SRV record is not registered in DNS.
- One or more of the following zones do not include delegation to its child zone:
tklab.
. (the root zone)
Jeg endra sonefila og la til srv recorden, og prøvde igjen, men da fikk jeg denne feilmeldinga:
The domain name tklab might be a NetBIOS domain name. If this is the case, verify that the domain name is properly registered with WINS.
If you are certain that the name is not a NetBIOS domain name, then the following information can help you troubleshoot your DNS configuration.
DNS was successfully queried for the service location (SRV) resource record used to locate a domain controller for domain tklab:
The following domain controllers were identified by the query:
nasse.tklab.local
Common causes of this error include:
- Host (A) records that map the name of the domain controller to its IP addresses are missing or contain incorrect addresses.
- Domain controllers registered in DNS are not connected to the network or are not running.
For information about correcting this problem, click Help.
Alt fungerte altså perfekt før jeg gjorde disse endringene, og alt det andre er som før i smb.conf.
Jeg har fortsatt tilgang til mappene jeg har delt i samba fra windowsmaskinen.
Hva har skjedd??
Takker for svar:-)
ps: Er ganske noobish på linux..
Endret av coolgrev1
Jeg bruker dessverre ikke ldap selv, og har ikke anledning til å sjekke opp dette nå, men det ser ut som om du finner detaljert gjennomgang her:
http://wiki.makethemove.net/index.php?title=LDAP-Samba
og et automatisert skript for å sette det opp her:
http://ubuntuforums.org/showthread.php?t=159600
Feilmeldingen du får sier at domenenavnet ikke finnes, så for alt jeg vet så trenger du å legge inn alias til IP (det er beskrevet i guiden), men ta først en titt på lenkene over, så bør det være greit å finne ut om det er satt opp riktig.
