Nyhet: Fanatec Headshot Controller (MUS)
The Fanatec Headshot Controller is the ultimate weapon for PC gaming. It features a revolutionary integrated concept of highly innovative gaming components that combine to create a precision gaming mouse that will change how you play games. Take your game to a whole new level and blow your competition away!
Advantages:
  • ERGONOMIC size adjustment gives the ultimate in precision control to hands of all shapes and sizes.
  • JOYSTICK EMULATION makes it the perfect controller for mixed mode games by allowing you to quickly switch "on-the-fly" to work as a 3-axis, 9-button joystick.
  • POWERFUL emul8or software allows users to program sophisticated macros easily during game play and map it not only to one of the 6 buttons or the 5 way scroll wheel, but also to any keyboard key.
  • PLASMAGLYDETM TECHNOLOGY eliminates friction while giving quick and precise aiming.
  • LATEST GENERATION hi-grade precision laser sensor gives you precise control (up to 4000 dpi).
Features:
Headshot Controller
  • Ergonomic size adjustment to fit any hand comfortably.
  • Latest generation hi-grade precision laser sensor.
  • 6 buttons plus 5-way scroll wheel.
  • PlasmaGlydeTM mouse feet.
  • Innovative design allows your fingers to rest comfortably on the mouse eliminating friction.
  • Up to 4,000 dpi (2,000 native) resolution; switchable during game play.
  • Lightweight, non-tangle cable.
  • Non-slip high-injection mold TPR rubber grip.
aURa Mouse Pad
  • Illuminated cable arch and mouse are separately adjustable; multi-color, brightness, and pulsing frequency.
  • Advanced gliding technology through the combination of the low-friction PlasmaGlydeTM mouse feet and aURaTM mouse pad.
  • Cable arch management system.
  • High-speed USB 2.0 hub.
emul8or Drivers
  • Joystick emulation-compatible with all racing games, flight simulators, etc...
  • Universal programming of mouse and all standard keyboard keys.
  • Macros executed with correct timing, allows for purchase scripts, grenade throw, communication, looping events, etc...
  • Double assignment of all keyboard keys with long-click or double click.
  • On-the-fly programming during game play.
  • Automatic creation of profiles for all software applications.
  • Auto-switching between profiles, depending on the active program.
  • Created with Germaneering.
Endret av Intern
