Mapster Skrevet 24. oktober 2007 Del Skrevet 24. oktober 2007 Jeg har nettopp installert den nye fglrx driveren, men har litt problemer med å få den til å laste... glxinfo viser at det kjøres Mesa Indirect. Har stresset med dette i noen timer nå, noen som kan hjelpe? glxinfo: Klikk for å se/fjerne innholdet nedenfor name of display: :0.0display: :0 screen: 0 direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose) server glx vendor string: SGI server glx version string: 1.2 server glx extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe, GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer client glx vendor string: SGI client glx version string: 1.4 client glx extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory, GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap GLX version: 1.2 GLX extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_EXT_texture_from_pixmap OpenGL vendor string: Mesa project: www.mesa3d.org OpenGL renderer string: Mesa GLX Indirect OpenGL version string: 1.4 (2.1 Mesa 7.0.1) OpenGL extensions: GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_fragment_program, GL_ARB_imaging, GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp, GL_ARB_texture_compression, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two, GL_ARB_texture_rectangle, GL_ARB_transpose_matrix, GL_ARB_vertex_program, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate, GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint, GL_EXT_copy_texture, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_object, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_paletted_texture, GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_shared_texture_palette, GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_APPLE_packed_pixels, GL_ATI_draw_buffers, GL_ATI_texture_env_combine3, GL_ATI_texture_mirror_once, GL_ATIX_texture_env_combine3, GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_NV_blend_square, GL_NV_fragment_program, GL_NV_light_max_exponent, GL_NV_point_sprite, GL_NV_texgen_reflection, GL_NV_texture_rectangle, GL_NV_vertex_program, GL_NV_vertex_program1_1, GL_SGI_color_matrix, GL_SGI_color_table, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow, GL_SGIX_shadow_ambient, GL_SUN_multi_draw_arrays visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x23 24 tc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 0 0 None 0x24 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 0 0 None 0x25 24 tc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 0 0 None 0x26 24 tc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 0 0 None 0x27 24 dc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 0 0 None 0x28 24 dc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 0 0 None 0x29 24 dc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 0 0 None 0x2a 24 dc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 0 0 None 0x3c 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 Ncon xorg.conf: Klikk for å se/fjerne innholdet nedenfor # /etc/X11/xorg.conf (xorg X Window System server configuration file)# # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "Files" Fontpath "/usr/share/fonts/X11/cyrillic" Fontpath "/usr/share/fonts/X11/100dpi/:unscaled" Fontpath "/usr/share/fonts/X11/75dpi/:unscaled" Fontpath "/usr/share/fonts/X11/Type1" Fontpath "/usr/share/fonts/X11/100dpi" Fontpath "/usr/share/fonts/X11/75dpi" Fontpath "/usr/share/fonts/X11/misc" # path to defoma fonts Fontpath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" EndSection Section "Module" Load "i2c" Load "bitmap" Load "ddc" # Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" # Load "type1" # Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "no" Option "XkbOptions" "lv3:ralt_switch" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ExplorerPS/2" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "true" EndSection Section "InputDevice" Driver "wacom" Identifier "stylus" Option "Device" "/dev/wacom"# Change to Option "Type" "stylus" Option "ForceDevice" "ISDV4"# Tablet PC ONLY # /dev/input/event # for USB EndSection Section "InputDevice" Driver "wacom" Identifier "eraser" Option "Device" "/dev/wacom"# Change to Option "Type" "eraser" Option "ForceDevice" "ISDV4"# Tablet PC ONLY # /dev/input/event # for USB EndSection Section "InputDevice" Driver "wacom" Identifier "cursor" Option "Device" "/dev/wacom"# Change to Option "Type" "cursor" Option "ForceDevice" "ISDV4"# Tablet PC ONLY # /dev/input/event # for USB EndSection Section "Device" Identifier "ATI Technologies, Inc. ATI Default Card" Driver "fglrx" Busid "PCI:6:0:0" EndSection Section "Monitor" Identifier "Generic Monitor" Option "DPMS" Horizsync 28-72 Vertrefresh 43-60 DisplaySize 381 238.125 EndSection Section "Screen" Identifier "Default Screen" Device "ATI Technologies, Inc. ATI Default Card" Monitor "Generic Monitor" Defaultdepth 24 SubSection "Display" Depth 1 Modes "1440x900" EndSubSection SubSection "Display" Depth 4 Modes "1440x900" EndSubSection SubSection "Display" Depth 8 Modes "1440x900" EndSubSection SubSection "Display" Depth 15 Modes "1440x900" EndSubSection SubSection "Display" Depth 16 Modes "1440x900" EndSubSection SubSection "Display" Depth 24 Modes "1440x900" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" screen "Default Screen" Inputdevice "Generic Keyboard" Inputdevice "Configured Mouse" Inputdevice "stylus" "SendCoreEvents" Inputdevice "cursor" "SendCoreEvents" Inputdevice "eraser" "SendCoreEvents" EndSection Section "DRI" Mode 0666 EndSection Xorg.0.log: Klikk for å se/fjerne innholdet nedenfor X Window System Version 1.3.0 Release Date: 19 April 2007 X Protocol Version 11, Revision 0, Release 1.3 Build Operating System: Linux Ubuntu (xorg-server 2:1.3.0.0.dfsg-12ubuntu8) Current Operating System: Linux mapster-laptop 2.6.22-14-generic #1 SMP Sun Oct 14 23:05:12 GMT 2007 i686 Build Date: 29 September 2007 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Module Loader present Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Wed Oct 24 13:01:06 2007 (==) Using config file: "/etc/X11/xorg.conf" (==) ServerLayout "Default Layout" (**) |-->Screen "Default Screen" (0) (**) | |-->Monitor "Generic Monitor" (**) | |-->Device "ATI Technologies, Inc. ATI Default Card" (**) |-->Input Device "Generic Keyboard" (**) |-->Input Device "Configured Mouse" (**) |-->Input Device "stylus" (**) |-->Input Device "cursor" (**) |-->Input Device "eraser" (WW) Including the default font path /usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType. (**) FontPath set to: /usr/share/fonts/X11/cyrillic, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, /usr/share/fonts/X11/misc, /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, /usr/share/fonts/X11/misc, /usr/share/fonts/X11/cyrillic, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType (==) RgbPath set to "/etc/X11/rgb" (==) ModulePath set to "/usr/lib/xorg/modules" (II) Open ACPI successful (/var/run/acpid.socket) (II) Loader magic: 0x81ea440 (II) Module ABI versions: X.Org ANSI C Emulation: 0.3 X.Org Video Driver: 1.2 X.Org XInput driver : 0.7 X.Org Server Extension : 0.3 X.Org Font Renderer : 0.5 (II) Loader running on linux (II) LoadModule: "pcidata" (II) Loading /usr/lib/xorg/modules//libpcidata.so (II) Module pcidata: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.0.0 ABI class: X.Org Video Driver, version 1.2 (++) using VT number 7 (II) PCI: PCI scan (all values are in hex) (II) PCI: 00:00:0: chip 8086,27a0 card 1043,1167 rev 03 class 06,00,00 hdr 00 (II) PCI: 00:01:0: chip 8086,27a1 card 0000,0000 rev 03 class 06,04,00 hdr 01 (II) PCI: 00:1b:0: chip 8086,27d8 card 1043,1243 rev 02 class 04,03,00 hdr 00 (II) PCI: 00:1c:0: chip 8086,27d0 card 0000,0000 rev 02 class 06,04,00 hdr 81 (II) PCI: 00:1c:1: chip 8086,27d2 card 0000,0000 rev 02 class 06,04,00 hdr 81 (II) PCI: 00:1c:2: chip 8086,27d4 card 0000,0000 rev 02 class 06,04,00 hdr 81 (II) PCI: 00:1d:0: chip 8086,27c8 card 1043,1167 rev 02 class 0c,03,00 hdr 80 (II) PCI: 00:1d:1: chip 8086,27c9 card 1043,1167 rev 02 class 0c,03,00 hdr 00 (II) PCI: 00:1d:2: chip 8086,27ca card 1043,1167 rev 02 class 0c,03,00 hdr 00 (II) PCI: 00:1d:3: chip 8086,27cb card 1043,1167 rev 02 class 0c,03,00 hdr 00 (II) PCI: 00:1d:7: chip 8086,27cc card 1043,1167 rev 02 class 0c,03,20 hdr 00 (II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev e2 class 06,04,01 hdr 01 (II) PCI: 00:1f:0: chip 8086,27b9 card 8086,27b9 rev 02 class 06,01,00 hdr 80 (II) PCI: 00:1f:2: chip 8086,27c4 card 1043,1167 rev 02 class 01,01,80 hdr 00 (II) PCI: 01:01:0: chip 1180,0832 card 1043,1907 rev 00 class 0c,00,10 hdr 80 (II) PCI: 01:01:1: chip 1180,0822 card 1043,1217 rev 19 class 08,05,00 hdr 80 (II) PCI: 01:01:2: chip 1180,0843 card 1043,1217 rev 01 class 08,80,00 hdr 80 (II) PCI: 01:01:3: chip 1180,0592 card 1043,1217 rev 0a class 08,80,00 hdr 80 (II) PCI: 01:01:4: chip 1180,0852 card 1043,1217 rev 05 class 08,80,00 hdr 80 (II) PCI: 01:02:0: chip 1131,7133 card 1461,a836 rev d1 class 04,80,00 hdr 00 (II) PCI: 04:00:0: chip 8086,4222 card 8086,1001 rev 02 class 02,80,00 hdr 00 (II) PCI: 05:00:0: chip 10ec,8168 card 1043,11f5 rev 01 class 02,00,00 hdr 00 (II) PCI: 06:00:0: chip 1002,71c5 card 1043,10b2 rev 00 class 03,00,00 hdr 00 (II) PCI: End of PCI scan (II) Intel Bridge workaround enabled (II) Host-to-PCI bridge: (II) Bus 0: bridge is at (0:0:0), (0,0,6), BCTRL: 0x0008 (VGA_EN is set) (II) Bus 0 I/O range: [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX (II) Bus 0 non-prefetchable memory range: [0] -1 0 0x00000000 - 0xffffffff (0x0) MX (II) Bus 0 prefetchable memory range: [0] -1 0 0x00000000 - 0xffffffff (0x0) MX (II) PCI-to-PCI bridge: (II) Bus 6: bridge is at (0:1:0), (0,6,6), BCTRL: 0x000a (VGA_EN is set) (II) Bus 6 I/O range: [0] -1 0 0x0000b000 - 0x0000dfff (0x3000) IX (II) Bus 6 non-prefetchable memory range: [0] -1 0 0xfe000000 - 0xfe0fffff (0x100000) MX (II) Bus 6 prefetchable memory range: [0] -1 0 0xbff00000 - 0xdfefffff (0x20000000) MX (II) PCI-to-PCI bridge: (II) Bus 5: bridge is at (0:28:0), (0,5,5), BCTRL: 0x0002 (VGA_EN is cleared) (II) Bus 5 I/O range: [0] -1 0 0x0000a000 - 0x0000afff (0x1000) IX (II) Bus 5 non-prefetchable memory range: [0] -1 0 0xfdf00000 - 0xfdffffff (0x100000) MX (II) PCI-to-PCI bridge: (II) Bus 4: bridge is at (0:28:1), (0,4,4), BCTRL: 0x0002 (VGA_EN is cleared) (II) Bus 4 non-prefetchable memory range: [0] -1 0 0xfde00000 - 0xfdefffff (0x100000) MX (II) PCI-to-PCI bridge: (II) Bus 2: bridge is at (0:28:2), (0,2,3), BCTRL: 0x0002 (VGA_EN is cleared) (II) Bus 2 I/O range: [0] -1 0 0x00009000 - 0x00009fff (0x1000) IX (II) Bus 2 non-prefetchable memory range: [0] -1 0 0xfd600000 - 0xfddfffff (0x800000) MX (II) Bus 2 prefetchable memory range: [0] -1 0 0xbdf00000 - 0xbfefffff (0x2000000) MX (II) Subtractive PCI-to-PCI bridge: (II) Bus 1: bridge is at (0:30:0), (0,1,1), BCTRL: 0x0002 (VGA_EN is cleared) (II) Bus 1 non-prefetchable memory range: [0] -1 0 0xfd500000 - 0xfd5fffff (0x100000) MX (II) PCI-to-ISA bridge: (II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set) (--) PCI:*(6:0:0) ATI Technologies Inc M56P [Radeon Mobility X1600] rev 0, Mem @ 0xc0000000/28, 0xfe0f0000/16, I/O @ 0xd000/8, BIOS @ 0xfe0c0000/17 (II) Addressable bus resource ranges are [0] -1 0 0x00000000 - 0xffffffff (0x0) MX [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX (II) OS-reported resource ranges: [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B) [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [5] -1 0 0x00000000 - 0x000000ff (0x100) IX (II) Active PCI resource ranges: [0] -1 0 0xfdfff000 - 0xfdffffff (0x1000) MX [1] -1 0 0xfdeff000 - 0xfdefffff (0x1000) MX [2] -1 0 0xfd5ff800 - 0xfd5fffff (0x800) MX [3] -1 0 0xfd5ff400 - 0xfd5ff4ff (0x100) MX [4] -1 0 0xfd5ff000 - 0xfd5ff0ff (0x100) MX [5] -1 0 0xfd5fec00 - 0xfd5fecff (0x100) MX [6] -1 0 0xfd5fe800 - 0xfd5fe8ff (0x100) MX [7] -1 0 0xfd5fe000 - 0xfd5fe7ff (0x800) MX [8] -1 0 0xfe1ffc00 - 0xfe1fffff (0x400) MX [9] -1 0 0xfe1f8000 - 0xfe1fbfff (0x4000) MX [10] -1 0 0xfe0c0000 - 0xfe0dffff (0x20000) MX(B) [11] -1 0 0xfe0f0000 - 0xfe0fffff (0x10000) MX(B) [12] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX(B) [13] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX [14] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX [15] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [16] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [17] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [18] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [19] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX [20] -1 0 0x0000e880 - 0x0000e89f (0x20) IX [21] -1 0 0x0000e800 - 0x0000e81f (0x20) IX [22] -1 0 0x0000e480 - 0x0000e49f (0x20) IX [23] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX(B) (II) Active PCI resource ranges after removing overlaps: [0] -1 0 0xfdfff000 - 0xfdffffff (0x1000) MX [1] -1 0 0xfdeff000 - 0xfdefffff (0x1000) MX [2] -1 0 0xfd5ff800 - 0xfd5fffff (0x800) MX [3] -1 0 0xfd5ff400 - 0xfd5ff4ff (0x100) MX [4] -1 0 0xfd5ff000 - 0xfd5ff0ff (0x100) MX [5] -1 0 0xfd5fec00 - 0xfd5fecff (0x100) MX [6] -1 0 0xfd5fe800 - 0xfd5fe8ff (0x100) MX [7] -1 0 0xfd5fe000 - 0xfd5fe7ff (0x800) MX [8] -1 0 0xfe1ffc00 - 0xfe1fffff (0x400) MX [9] -1 0 0xfe1f8000 - 0xfe1fbfff (0x4000) MX [10] -1 0 0xfe0c0000 - 0xfe0dffff (0x20000) MX(B) [11] -1 0 0xfe0f0000 - 0xfe0fffff (0x10000) MX(B) [12] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX(B) [13] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX [14] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX [15] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [16] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [17] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [18] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [19] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX [20] -1 0 0x0000e880 - 0x0000e89f (0x20) IX [21] -1 0 0x0000e800 - 0x0000e81f (0x20) IX [22] -1 0 0x0000e480 - 0x0000e49f (0x20) IX [23] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX(B) (II) OS-reported resource ranges after removing overlaps with PCI: [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B) [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [5] -1 0 0x00000000 - 0x000000ff (0x100) IX (II) All system resource ranges: [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B) [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [4] -1 0 0xfdfff000 - 0xfdffffff (0x1000) MX [5] -1 0 0xfdeff000 - 0xfdefffff (0x1000) MX [6] -1 0 0xfd5ff800 - 0xfd5fffff (0x800) MX [7] -1 0 0xfd5ff400 - 0xfd5ff4ff (0x100) MX [8] -1 0 0xfd5ff000 - 0xfd5ff0ff (0x100) MX [9] -1 0 0xfd5fec00 - 0xfd5fecff (0x100) MX [10] -1 0 0xfd5fe800 - 0xfd5fe8ff (0x100) MX [11] -1 0 0xfd5fe000 - 0xfd5fe7ff (0x800) MX [12] -1 0 0xfe1ffc00 - 0xfe1fffff (0x400) MX [13] -1 0 0xfe1f8000 - 0xfe1fbfff (0x4000) MX [14] -1 0 0xfe0c0000 - 0xfe0dffff (0x20000) MX(B) [15] -1 0 0xfe0f0000 - 0xfe0fffff (0x10000) MX(B) [16] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX(B) [17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [18] -1 0 0x00000000 - 0x000000ff (0x100) IX [19] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX [20] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX [21] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [22] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [23] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [24] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [25] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX [26] -1 0 0x0000e880 - 0x0000e89f (0x20) IX [27] -1 0 0x0000e800 - 0x0000e81f (0x20) IX [28] -1 0 0x0000e480 - 0x0000e49f (0x20) IX [29] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX(B) (II) LoadModule: "i2c"(II) Module already built-in (II) LoadModule: "ddc"(II) Module already built-in (II) LoadModule: "extmod" (II) Loading /usr/lib/xorg/modules/extensions//libextmod.so (II) Module extmod: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.0.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 0.3 (II) Loading extension SHAPE (II) Loading extension MIT-SUNDRY-NONSTANDARD (II) Loading extension BIG-REQUESTS (II) Loading extension SYNC (II) Loading extension MIT-SCREEN-SAVER (II) Loading extension XC-MISC (II) Loading extension XFree86-VidModeExtension (II) Loading extension XFree86-Misc (II) Loading extension XFree86-DGA (II) Loading extension DPMS (II) Loading extension TOG-CUP (II) Loading extension Extended-Visual-Information (II) Loading extension XVideo (II) Loading extension XVideo-MotionCompensation (II) Loading extension X-Resource (II) LoadModule: "freetype" (II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so (II) Module freetype: vendor="X.Org Foundation & the After X-TT Project" compiled for 1.3.0, module version = 2.1.0 Module class: X.Org Font Renderer ABI class: X.Org Font Renderer, version 0.5 (II) Loading font FreeType (II) LoadModule: "glx" (II) Loading /usr/lib/xorg/modules/extensions//libglx.so (II) Module glx: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 0.3 (==) AIGLX enabled (II) Loading extension GLX (II) LoadModule: "int10" (II) Loading /usr/lib/xorg/modules//libint10.so (II) Module int10: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.0.0 ABI class: X.Org Video Driver, version 1.2 (II) LoadModule: "dbe" (II) Loading /usr/lib/xorg/modules/extensions//libdbe.so (II) Module dbe: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.0.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 0.3 (II) Loading extension DOUBLE-BUFFER (II) LoadModule: "record" (II) Loading /usr/lib/xorg/modules/extensions//librecord.so (II) Module record: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.13.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 0.3 (II) Loading extension RECORD (II) LoadModule: "dri" (II) Loading /usr/lib/xorg/modules/extensions//libdri.so (II) Module dri: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 0.3 (II) Loading extension XFree86-DRI (II) LoadModule: "fglrx" (II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so (II) Module fglrx: vendor="FireGL - ATI Technologies Inc." compiled for 7.1.0, module version = 8.42.3 Module class: X.Org Video Driver (II) LoadModule: "kbd" (II) Loading /usr/lib/xorg/modules/input//kbd_drv.so (II) Module kbd: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.2.1 Module class: X.Org XInput Driver ABI class: X.Org XInput driver, version 0.7 (II) LoadModule: "mouse" (II) Loading /usr/lib/xorg/modules/input//mouse_drv.so (II) Module mouse: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.2.1 Module class: X.Org XInput Driver ABI class: X.Org XInput driver, version 0.7 (II) LoadModule: "wacom" (II) Loading /usr/lib/xorg/modules/input//wacom_drv.so (II) Module wacom: vendor="X.Org Foundation" compiled for 4.3.99.902, module version = 1.0.0 Module class: X.Org XInput Driver ABI class: X.Org XInput driver, version 0.7 (II) Wacom driver level: 47-0.7.7-7 $ (II) Primary Device is: PCI 06:00:0 (II) ATI Proprietary Linux Driver Version Identifier:8.42.3 (II) ATI Proprietary Linux Driver Release Identifier: UNSUPPORTED-8.423.2 (II) ATI Proprietary Linux Driver Build Date: Oct 19 2007 16:13:26 (--) Chipset Supported AMD Graphics Processor (0x71C5) found (II) AMD Video driver is running on a device belonging to a group targeted for this release (II) AMD Video driver is signed (II) resource ranges after xf86ClaimFixedResources() call: [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B) [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [4] -1 0 0xfdfff000 - 0xfdffffff (0x1000) MX [5] -1 0 0xfdeff000 - 0xfdefffff (0x1000) MX [6] -1 0 0xfd5ff800 - 0xfd5fffff (0x800) MX [7] -1 0 0xfd5ff400 - 0xfd5ff4ff (0x100) MX [8] -1 0 0xfd5ff000 - 0xfd5ff0ff (0x100) MX [9] -1 0 0xfd5fec00 - 0xfd5fecff (0x100) MX [10] -1 0 0xfd5fe800 - 0xfd5fe8ff (0x100) MX [11] -1 0 0xfd5fe000 - 0xfd5fe7ff (0x800) MX [12] -1 0 0xfe1ffc00 - 0xfe1fffff (0x400) MX [13] -1 0 0xfe1f8000 - 0xfe1fbfff (0x4000) MX [14] -1 0 0xfe0c0000 - 0xfe0dffff (0x20000) MX(B) [15] -1 0 0xfe0f0000 - 0xfe0fffff (0x10000) MX(B) [16] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX(B) [17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [18] -1 0 0x00000000 - 0x000000ff (0x100) IX [19] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX [20] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX [21] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [22] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [23] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [24] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [25] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX [26] -1 0 0x0000e880 - 0x0000e89f (0x20) IX [27] -1 0 0x0000e800 - 0x0000e81f (0x20) IX [28] -1 0 0x0000e480 - 0x0000e49f (0x20) IX [29] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX(B) (II) fglrx(0): pEnt->device->identifier=0x8208688 (II) resource ranges after probing: [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B) [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [4] -1 0 0xfdfff000 - 0xfdffffff (0x1000) MX [5] -1 0 0xfdeff000 - 0xfdefffff (0x1000) MX [6] -1 0 0xfd5ff800 - 0xfd5fffff (0x800) MX [7] -1 0 0xfd5ff400 - 0xfd5ff4ff (0x100) MX [8] -1 0 0xfd5ff000 - 0xfd5ff0ff (0x100) MX [9] -1 0 0xfd5fec00 - 0xfd5fecff (0x100) MX [10] -1 0 0xfd5fe800 - 0xfd5fe8ff (0x100) MX [11] -1 0 0xfd5fe000 - 0xfd5fe7ff (0x800) MX [12] -1 0 0xfe1ffc00 - 0xfe1fffff (0x400) MX [13] -1 0 0xfe1f8000 - 0xfe1fbfff (0x4000) MX [14] -1 0 0xfe0c0000 - 0xfe0dffff (0x20000) MX(B) [15] -1 0 0xfe0f0000 - 0xfe0fffff (0x10000) MX(B) [16] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX(B) [17] 0 0 0x000a0000 - 0x000affff (0x10000) MS [18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS [19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS [20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [21] -1 0 0x00000000 - 0x000000ff (0x100) IX [22] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX [23] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX [24] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [25] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [26] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [27] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [28] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX [29] -1 0 0x0000e880 - 0x0000e89f (0x20) IX [30] -1 0 0x0000e800 - 0x0000e81f (0x20) IX [31] -1 0 0x0000e480 - 0x0000e49f (0x20) IX [32] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX(B) [33] 0 0 0x000003b0 - 0x000003bb (0xc) IS [34] 0 0 0x000003c0 - 0x000003df (0x20) IS (II) Setting vga for screen 0. (II) fglrx(0): === [atiddxPreInit] === begin, [x] (II) Loading sub module "vgahw" (II) LoadModule: "vgahw" (II) Loading /usr/lib/xorg/modules//libvgahw.so (II) Module vgahw: vendor="X.Org Foundation" compiled for 1.3.0, module version = 0.1.0 ABI class: X.Org Video Driver, version 1.2 (II) fglrx(0): PCI bus 6 card 0 func 0 (**) fglrx(0): Depth 24, (--) framebuffer bpp 32 (II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps) (==) fglrx(0): Default visual is TrueColor (**) fglrx(0): Option "DPMS" (==) fglrx(0): RGB weight 888 (II) fglrx(0): Using 8 bits per RGB (8 bit DAC) (==) fglrx(0): Gamma Correction for I is 0x06419064 (==) fglrx(0): Gamma Correction for II is 0x06419064 (==) fglrx(0): Buffer Tiling is ON (--) fglrx(0): Chipset: "ATI Mobility Radeon X1600" (Chipset = 0x71c5) (--) fglrx(0): (PciSubVendor = 0x1043, PciSubDevice = 0x10b2) (--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI (--) fglrx(0): Linear framebuffer (phys) at 0xc0000000 (--) fglrx(0): MMIO registers at 0xfe0f0000 (==) fglrx(0): ROM-BIOS at 0x000c0000 (II) Loading sub module "int10" (II) LoadModule: "int10" (II) Reloading /usr/lib/xorg/modules//libint10.so (II) fglrx(0): Primary V_BIOS segment is: 0xc000 (II) Loading sub module "vbe" (II) LoadModule: "vbe" (II) Loading /usr/lib/xorg/modules//libvbe.so (II) Module vbe: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.1.0 ABI class: X.Org Video Driver, version 1.2 (II) fglrx(0): VESA BIOS detected (II) fglrx(0): VESA VBE Version 3.0 (II) fglrx(0): VESA VBE Total Mem: 16384 kB (II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS (II) fglrx(0): VESA VBE OEM Software Rev: 9.12 (II) fglrx(0): VESA VBE OEM Vendor: © 1988-2005, ATI Technologies Inc. (II) fglrx(0): VESA VBE OEM Product: M56P (II) fglrx(0): VESA VBE OEM Product Rev: 01.00 (II) fglrx(0): ATI Video BIOS revision 9 or later detected drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card1 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card2 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card3 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card4 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card5 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card6 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card7 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card8 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card9 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card10 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card11 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card12 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card13 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed drmOpenDevice: node name is /dev/dri/card14 drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: open result is -1, (No such device or address) drmOpenDevice: Open failed (WW) fglrx(0): Failed to open DRM connection (--) fglrx(0): VideoRAM: 262144 kByte, Type: DDR2 (II) fglrx(0): PCIE card detected (WW) fglrx(0): board is an unknown third party board, chipset is supported (II) Loading sub module "ddc" (II) LoadModule: "ddc"(II) Module already built-in (II) fglrx(0): Connected Display1: LCD on internal LVDS [lvds] (II) fglrx(0): Display1 EDID data --------------------------- (II) fglrx(0): Manufacturer: AUO Model: 1101 Serial#: 0 (II) fglrx(0): Year: 2004 Week: 1 (II) fglrx(0): EDID Version: 1.2 (II) fglrx(0): Digital Display Input (II) fglrx(0): Max H-Image Size [cm]: horiz.: 37 vert.: 23 (II) fglrx(0): Gamma: 2.20 (II) fglrx(0): No DPMS capabilities specified; RGB/Color Display (II) fglrx(0): First detailed timing is preferred mode (II) fglrx(0): redX: 0.609 redY: 0.350 greenX: 0.300 greenY: 0.560 (II) fglrx(0): blueX: 0.139 blueY: 0.139 whiteX: 0.319 whiteY: 0.329 (II) fglrx(0): Manufacturer's mask: 0 (II) fglrx(0): Supported additional Video Mode: (II) fglrx(0): clock: 96.3 MHz Image Size: 367 x 230 mm (II) fglrx(0): h_active: 1440 h_sync: 1504 h_sync_end 1536 h_blank_end 1760 h_border: 0 (II) fglrx(0): v_active: 900 v_sync: 903 v_sync_end 906 v_blanking: 912 v_border: 0 (II) fglrx(0): AUO (II) fglrx(0): B170PW01 V.1 (II) fglrx(0): EDID (in hex): (II) fglrx(0): 00ffffffffffff0006af011100000000 (II) fglrx(0): 010e0102802517780a2dad9c594c8f23 (II) fglrx(0): 23515400000001010101010101010101 (II) fglrx(0): 0101010101019e25a04051840c304020 (II) fglrx(0): 33006fe6100000180000000f00423137 (II) fglrx(0): 305057303120562e3102000000fe0041 (II) fglrx(0): 554f0a202020202020202020000000fe (II) fglrx(0): 00423137305057303120562e310a00f2 (II) fglrx(0): End of Display1 EDID data -------------------- (II) fglrx(0): Primary Controller - LCD on internal LVDS (II) fglrx(0): Internal Desktop Setting: 0x00000008 (II) fglrx(0): POWERplay version 3. 3 power states available: (II) fglrx(0): 1. 446/396MHz @ 60Hz [enable load balancing] (II) fglrx(0): 2. 324/135MHz @ 60Hz [low voltage, enable sleep] (II) fglrx(0): 3. 392/252MHz @ 60Hz [low voltage, enable sleep] (==) fglrx(0): Qbs disabled (==) fglrx(0): FAST_SWAP disabled (==) fglrx(0): PseudoColor visuals disabled (==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0) (==) fglrx(0): Center Mode is disabled (==) fglrx(0): TMDS coherent mode is enabled (II) fglrx(0): Total of 10 modes found for primary display. (--) fglrx(0): Virtual size is 1440x900 (pitch 0) (**) fglrx(0): *Mode "1440x900": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "1440x900" 96.30 1440 1504 1536 1760 900 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "1152x864": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "1152x864" 96.30 1152 1504 1536 1760 864 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "1024x768": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "1024x768" 96.30 1024 1504 1536 1760 768 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "800x600": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "800x600" 96.30 800 1504 1536 1760 600 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "640x480": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "640x480" 96.30 640 1504 1536 1760 480 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "640x400": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "640x400" 96.30 640 1504 1536 1760 400 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "512x384": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "512x384" 96.30 512 1504 1536 1760 384 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "400x300": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "400x300" 96.30 400 1504 1536 1760 300 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "320x240": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "320x240" 96.30 320 1504 1536 1760 240 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "320x200": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "320x200" 96.30 320 1504 1536 1760 200 903 906 912 +hsync +vsync (**) fglrx(0): Display dimensions: (381, 238) mm (WW) fglrx(0): Probed monitor is 370x230 mm, using Displaysize 381x238 mm (**) fglrx(0): DPI set to (95, 96) (--) fglrx(0): Virtual size is 1440x900 (pitch 1472) (**) fglrx(0): *Mode "1440x900": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "1440x900" 96.30 1440 1504 1536 1760 900 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "1152x864": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "1152x864" 96.30 1152 1504 1536 1760 864 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "1024x768": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "1024x768" 96.30 1024 1504 1536 1760 768 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "800x600": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "800x600" 96.30 800 1504 1536 1760 600 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "640x480": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "640x480" 96.30 640 1504 1536 1760 480 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "640x400": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "640x400" 96.30 640 1504 1536 1760 400 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "512x384": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "512x384" 96.30 512 1504 1536 1760 384 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "400x300": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "400x300" 96.30 400 1504 1536 1760 300 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "320x240": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "320x240" 96.30 320 1504 1536 1760 240 903 906 912 +hsync +vsync (**) fglrx(0): Default mode "320x200": 96.3 MHz (scaled from 0.0 MHz), 54.7 kHz, 60.0 Hz (II) fglrx(0): Modeline "320x200" 96.30 320 1504 1536 1760 200 903 906 912 +hsync +vsync (II) Loading sub module "fb" (II) LoadModule: "fb" (II) Loading /usr/lib/xorg/modules//libfb.so (II) Module fb: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.0.0 ABI class: X.Org ANSI C Emulation, version 0.3 (II) Loading sub module "ramdac" (II) LoadModule: "ramdac"(II) Module already built-in (==) fglrx(0): NoAccel = NO (II) Loading sub module "xaa" (II) LoadModule: "xaa" (II) Loading /usr/lib/xorg/modules//libxaa.so (II) Module xaa: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.2.0 ABI class: X.Org Video Driver, version 1.2 (==) fglrx(0): HPV inactive (==) fglrx(0): NoDRI = NO (II) Loading sub module "fglrxdrm" (II) LoadModule: "fglrxdrm" (II) Loading /usr/lib/xorg/modules/linux//libfglrxdrm.so (II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc." compiled for 7.1.0, module version = 8.42.3 ABI class: X.Org Server Extension, version 0.3 (II) fglrx(0): Depth moves disabled by default (==) fglrx(0): Capabilities: 0x00000000 (==) fglrx(0): CapabilitiesEx: 0x00000000 (==) fglrx(0): cpuFlags: 0x8000001d (==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so" (**) fglrx(0): ATI GART size: 256 MB (WW) fglrx(0): No DRM connection for driver fglrx. (II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536 (==) fglrx(0): UseFastTLS=0 (==) fglrx(0): BlockSignalsOnLock=1 (--) Depth 24 pixmap format is 32 bpp (II) do I need RAC? No, I don't. (II) resource ranges after preInit: [0] 0 0 0xfe0f0000 - 0xfe0fffff (0x10000) MX [1] 0 0 0xc0000000 - 0xcfffffff (0x10000000) MX [2] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B) [3] -1 0 0x000f0000 - 0x000fffff (0x10000) MX [4] -1 0 0x000c0000 - 0x000effff (0x30000) MX [5] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX [6] -1 0 0xfdfff000 - 0xfdffffff (0x1000) MX [7] -1 0 0xfdeff000 - 0xfdefffff (0x1000) MX [8] -1 0 0xfd5ff800 - 0xfd5fffff (0x800) MX [9] -1 0 0xfd5ff400 - 0xfd5ff4ff (0x100) MX [10] -1 0 0xfd5ff000 - 0xfd5ff0ff (0x100) MX [11] -1 0 0xfd5fec00 - 0xfd5fecff (0x100) MX [12] -1 0 0xfd5fe800 - 0xfd5fe8ff (0x100) MX [13] -1 0 0xfd5fe000 - 0xfd5fe7ff (0x800) MX [14] -1 0 0xfe1ffc00 - 0xfe1fffff (0x400) MX [15] -1 0 0xfe1f8000 - 0xfe1fbfff (0x4000) MX [16] -1 0 0xfe0c0000 - 0xfe0dffff (0x20000) MX(B) [17] -1 0 0xfe0f0000 - 0xfe0fffff (0x10000) MX(B) [18] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX(B) [19] 0 0 0x000a0000 - 0x000affff (0x10000) MS(OprU) [20] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS(OprU) [21] 0 0 0x000b8000 - 0x000bffff (0x8000) MS(OprU) [22] 0 0 0x0000d000 - 0x0000d0ff (0x100) IX [23] -1 0 0x0000ffff - 0x0000ffff (0x1) IX [24] -1 0 0x00000000 - 0x000000ff (0x100) IX [25] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX [26] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX [27] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [28] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [29] -1 0 0x000001f0 - 0x000001f0 (0x1) IX [30] -1 0 0x000001f0 - 0x000001f7 (0x8) IX [31] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX [32] -1 0 0x0000e880 - 0x0000e89f (0x20) IX [33] -1 0 0x0000e800 - 0x0000e81f (0x20) IX [34] -1 0 0x0000e480 - 0x0000e49f (0x20) IX [35] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX(B) [36] 0 0 0x000003b0 - 0x000003bb (0xc) IS(OprU) [37] 0 0 0x000003c0 - 0x000003df (0x20) IS(OprU) (II) fglrx(0): driver needs X.org 7.1.x.y with x.y >= 0.0 (II) fglrx(0): detected X.org 7.1.0.0 (EE) fglrx(0): atiddxDriScreenInit failed, GPS not been initialized. (WW) fglrx(0): *********************************************** (WW) fglrx(0): * DRI initialization failed! * (WW) fglrx(0): * (maybe driver kernel module missing or bad) * (WW) fglrx(0): * 2D acceleraton available (MMIO) * (WW) fglrx(0): * no 3D acceleration available * (WW) fglrx(0): ********************************************* * (II) fglrx(0): FBADPhys: 0xc0000000 FBMappedSize: 0x10000000 (==) fglrx(0): Write-combining range (0xc0000000,0x10000000) (II) fglrx(0): FBMM initialized for area (0,0)-(1472,8191) (II) fglrx(0): FBMM auto alloc for area (0,0)-(1472,900) (front color buffer - assumption) (II) fglrx(0): Largest offscreen area available: 1472 x 7291 (==) fglrx(0): Backing store disabled (II) Loading extension FGLRXEXTENSION (II) Loading extension ATITVOUT (**) fglrx(0): DPMS enabled (WW) fglrx(0): Textured Video not supported without DRI enabled. (WW) fglrx(0): Video Overlay not supported on AVIVO based graphics cards. For XVideo support use Option "TexturedVideo". (II) fglrx(0): Using XFree86 Acceleration Architecture (XAA) Screen to screen bit blits Solid filled rectangles Solid Horizontal and Vertical Lines Offscreen Pixmaps Setting up tile and stipple cache: 32 128x128 slots 32 256x256 slots 16 512x512 slots (II) fglrx(0): Acceleration enabled (II) fglrx(0): Direct rendering disabled (==) fglrx(0): Silken mouse enabled (==) fglrx(0): Using hardware cursor (==) RandR enabled (II) Initializing built-in extension MIT-SHM (II) Initializing built-in extension XInputExtension (II) Initializing built-in extension XTEST (II) Initializing built-in extension XKEYBOARD (II) Initializing built-in extension XC-APPGROUP (II) Initializing built-in extension XAccessControlExtension (II) Initializing built-in extension SECURITY (II) Initializing built-in extension XINERAMA (II) Initializing built-in extension XFIXES (II) Initializing built-in extension XFree86-Bigfont (II) Initializing built-in extension RENDER (II) Initializing built-in extension RANDR (II) Initializing built-in extension COMPOSITE (II) Initializing built-in extension DAMAGE (II) Initializing built-in extension XEVIE (EE) AIGLX: Screen 0 is not DRI capable (II) Loading local sub module "GLcore" (II) LoadModule: "GLcore" (II) Loading /usr/lib/xorg/modules/extensions//libGLcore.so (II) Module GLcore: vendor="X.Org Foundation" compiled for 1.3.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 0.3 (II) GLX: Initialized MESA-PROXY GL provider for screen 0 (**) Option "CoreKeyboard" (**) Generic Keyboard: Core Keyboard (**) Option "Protocol" "standard" (**) Generic Keyboard: Protocol: standard (**) Option "AutoRepeat" "500 30" (**) Option "XkbRules" "xorg" (**) Generic Keyboard: XkbRules: "xorg" (**) Option "XkbModel" "pc105" (**) Generic Keyboard: XkbModel: "pc105" (**) Option "XkbLayout" "no" (**) Generic Keyboard: XkbLayout: "no" (**) Option "XkbOptions" "lv3:ralt_switch" (**) Generic Keyboard: XkbOptions: "lv3:ralt_switch" (**) Option "CustomKeycodes" "off" (**) Generic Keyboard: CustomKeycodes disabled (**) Option "Protocol" "ExplorerPS/2" (**) Configured Mouse: Device: "/dev/input/mice" (**) Configured Mouse: Protocol: "ExplorerPS/2" (**) Option "CorePointer" (**) Configured Mouse: Core Pointer (**) Option "Device" "/dev/input/mice" (**) Option "Emulate3Buttons" "true" (**) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50 (**) Option "ZAxisMapping" "4 5" (**) Configured Mouse: ZAxisMapping: buttons 4 and 5 (**) Configured Mouse: Buttons: 9 (**) Configured Mouse: Sensitivity: 1 (**) Option "SendCoreEvents" (**) stylus: always reports core events (**) stylus device is /dev/wacom (**) stylus is in absolute mode (**) stylus: forcing TabletPC ISD V4 protocol (**) WACOM: suppress value is 2 (**) Option "BaudRate" "9600" (**) stylus: serial speed 9600 (**) Option "SendCoreEvents" (**) cursor: always reports core events (**) cursor device is /dev/wacom (**) cursor is in relative mode (**) cursor: forcing TabletPC ISD V4 protocol (**) WACOM: suppress value is 2 (**) Option "BaudRate" "9600" (**) cursor: serial speed 9600 (**) Option "SendCoreEvents" (**) eraser: always reports core events (**) eraser device is /dev/wacom (**) eraser is in absolute mode (**) eraser: forcing TabletPC ISD V4 protocol (**) WACOM: suppress value is 2 (**) Option "BaudRate" "9600" (**) eraser: serial speed 9600 (II) XINPUT: Adding extended input device "eraser" (type: Wacom Eraser) (II) XINPUT: Adding extended input device "cursor" (type: Wacom Cursor) (II) XINPUT: Adding extended input device "stylus" (type: Wacom Stylus) (II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE) (II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD) (**) Option "Device" "/dev/wacom" (EE) xf86OpenSerial: Cannot open device /dev/wacom No such file or directory. Error opening /dev/wacom : No such file or directory (**) Option "Device" "/dev/wacom" (EE) xf86OpenSerial: Cannot open device /dev/wacom No such file or directory. Error opening /dev/wacom : No such file or directory (**) Option "Device" "/dev/wacom" (EE) xf86OpenSerial: Cannot open device /dev/wacom No such file or directory. Error opening /dev/wacom : No such file or directory (II) Configured Mouse: ps2EnableDataReporting: succeeded SetClientVersion: 0 9 AUDIT: Wed Oct 24 13:05:10 2007: 5487 X: client 18 rejected from local host (uid 1000) AUDIT: Wed Oct 24 13:07:24 2007: 5487 X: client 24 rejected from local host (uid 1000) Lenke til kommentar
stigfjel Skrevet 24. oktober 2007 Del Skrevet 24. oktober 2007 (endret) Prøv å aktivere DRI. ATI-driverne har i motsetning til driverne fra nVIDIA alltid benyttet DRI. Edit: av det jeg ser er det nok det som er feil, at du har kommentert ut DRI. Endret 24. oktober 2007 av stigfjel Lenke til kommentar
Mapster Skrevet 24. oktober 2007 Forfatter Del Skrevet 24. oktober 2007 Nå fjærnet jeg utkommenteringen av dri. Hjelper ikke... I loggen står det: (WW) fglrx(0): *********************************************** (WW) fglrx(0): * DRI initialization failed! * (WW) fglrx(0): * (maybe driver kernel module missing or bad) * (WW) fglrx(0): * 2D acceleraton available (MMIO) * (WW) fglrx(0): * no 3D acceleration available * (WW) fglrx(0): ********************************************* * Lenke til kommentar
stigfjel Skrevet 24. oktober 2007 Del Skrevet 24. oktober 2007 (endret) Hva får du med fglrxinfo? Edit: forresten, har du husket å aktivere tmpfs? Også en ting ATI-driveren trenger. Det gjøres ved at du legger til linjen under i /etc/fstab: tmpfs /dev/shm tmpfs defaults 0 0 Endret 24. oktober 2007 av stigfjel Lenke til kommentar
Mapster Skrevet 24. oktober 2007 Forfatter Del Skrevet 24. oktober 2007 fglrxinfo: display: :0.0 screen: 0 OpenGL vendor string: Mesa project: www.mesa3d.org OpenGL renderer string: Mesa GLX Indirect OpenGL version string: 1.4 (2.1 Mesa 7.0.1) Lenke til kommentar
stigfjel Skrevet 24. oktober 2007 Del Skrevet 24. oktober 2007 Gå ut av X.Org, skriv inn den linjen jeg listet opp sist, og så gjør du følgende i terminal: # mount /dev/shm Så starter du X igjen. Lenke til kommentar
Mapster Skrevet 24. oktober 2007 Forfatter Del Skrevet 24. oktober 2007 Jeg la inn den første linjen i fstab, men mount var ikke så vellykket: mapster@mapster-laptop:~$ mount /dev/shm mount: according to mtab, devshm is already mounted on /dev/shm mount failed Lenke til kommentar
NevroMance Skrevet 24. oktober 2007 Del Skrevet 24. oktober 2007 Hvilken kernel bruker du? Nyeste ati-driverne støtter ikke 2.6.23 kernelen, kun opp til 2.6.22 Lenke til kommentar
Mapster Skrevet 24. oktober 2007 Forfatter Del Skrevet 24. oktober 2007 (endret) Bruker 2.6.22-14 så det burde jo gå fint Ok, jeg har nå offisielt gitt opp og har bestemt meg for å gå tilbake til 8.37.6 - da jeg har lest (på diverse forum i hele dag) at det fører til dårligere ytelse med den driveren, AIGLX fungerer forøbig dårligere enn XGL. Men nå oppstår det ett stygt problem, nemlig at når jeg forsøker å starte compiz får jeg denne feilmeldingen: $ compiz Checking for Xgl: present. Checking for nVidia: not present. Checking for Xgl: present. Enabling Xgl with fglrx ATi drivers... Starting gtk-window-decorator /usr/bin/compiz.real (core) - Fatal: GLX_EXT_texture_from_pixmap is missing /usr/bin/compiz.real (core) - Error: Failed to manage screen: 0 /usr/bin/compiz.real (core) - Fatal: No manageable screens found on display :1.0 Advarsel fra vindushåndterer: «» funnet i konfigurasjonsdatabasen er ikke en gyldig verdi for tastaturbinding «toggle_shaded» Jeg har forsøkt å installere driverne både manuelt og ved hjelp av restricted drivers programvaren. Jeg har i tillegg prøvd å fjærne alle spor etter fglrx og xgl for å så installere det på nytt, uten hjelp. Display :0 har direct rendering og xgl kjører display :1. Ett kjapt søk på google viser til forum innlegg som sier så mye som at fglrx ikke har støtte for GLX_EXT_texture_from_pixmap, noe jeg har litt vanskelig for å tro - i og med at alt fungerte helt perfekt før jeg gjorde tabben å forsøke en oppgradering av driverne... EDIT: Fant en løsning på problemet etter en liten stund med "jeg-har-gitt-opp-holdning". Løsningen var å reinstallere libl1-mesa bibliotekene. Endret 24. oktober 2007 av MapSter Lenke til kommentar
