Problemer med innstallering av OS på HP G3000
Eyzteinn
Hei!
Kjøpt en HP G3000 laptop for en stund tilbake.
Denne ble levert med xp home.
Prøver nå og innstallere xp proffesional på den, men under innstallasjonsprosessen får jeg beskjed om at programmet ikke finner noen harddisker. Virker som om HP har låst datamaskinen slik at det ikke går ann å innstallere andre OS, og dette irriterer meg mektig..
Noen som vet hvordan jeg kan lure systemet og få innstallert xp proffesional?
Takk!
Eysteinn
Gå inn i bios og endre på AHCI mode.
AHCI is the acronym for the Advanced Host Controller Interface. It is a new interface specification that allows the SATA controller driver to support advanced features like Native Command Queuing and Hot Plug.
This BIOS feature controls the AHCI function of the SATA controller.
When enabled, the SATA controller enables its AHCI features when the computer boots up.
When disabled, the SATA controller disables its AHCI functions when the computer boots up.
If you would like to make use of the SATA controller's AHCI features, you should enable this BIOS feature. But please note that enabling this feature requires you to load the SATA controller driver during the Windows XP installation routine.
If you do not intend to use the AHCI features, it's recommended that you disable this BIOS feature. This allows you to use the native Windows XP driver. You won't need to load the SATA controller driver during the Windows XP installation routine.
Please note that changing this BIOS feature after installing the operating system may cause a boot failure. You may be required to reinstall the operating system.
