EviLEddiE Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Sakset fra Guru3D: Gainward Co., Ltd, the leading manufacturer of high performance 3D graphics and home entertainment accelerators, announces that it will introduce the world’s most powerful series of 128MB 3D graphics processor boards based on nVidia’s GeForce FX 5800 technology. The most powerful graphics board of the series; the Gainward FX PowerPack! Model Ultra/1000 Plus “Golden Sample”TM features nVidia’s fastest GeForce FX 5800 Ultra and is priced at €649 incl. VAT. The Gainward FX Power-Pack! Model Ultra/800 Plus “Golden Sample”TM is based on the nVidia GeForce FX 5800 priced at €549 incl. VAT. To further improve the versatility and gaming experience the Gainward FX PowerPack! Model Ultra/1000 Plus “Golden Sample”TM is bundled with a digital video-in IEEE 1394 FireWire daughter card, a high quality 5.1 sound card with both stereo output and optical SP/DIF output connectors, plus a variety of hot 3D games. All of Gainward’s FX PowerPack! products feature a radical new design of cooling system delivering maximum performance and incredibly low noise levels. Owing to Gainward’s advanced R&D skills the maximum noise is reduced to only 7db, the same as a human heartbeat. Competetive products maximum noise levels can be rated as high as 70db the same level as a domestic vacuum cleaner. Dette ser lovende ut for potensielle GFFX-eiere med sarte ører... Lenke til kommentar
Rikky Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 7 db???? Med luftkjøling? Må jo være skrivefeil.. Lenke til kommentar
mandela Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 de nevner ikke flytende-nitrogen tanken som følger med.... Lenke til kommentar
Lch Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Jeg tror det ikke før jeg får se/høre det. 7dB er lydløst. Ambient støynivå er rundt 20-25dB. Lenke til kommentar
EviLEddiE Skrevet 30. januar 2003 Forfatter Rapporter Del Skrevet 30. januar 2003 Ja, det ser ut til å være for godt til å være sant - de har sikkert glemt et 2 eller 3-tall foran 7-tallet. Men da forsvinner jo poenget med hjerteslaget..! Jeg får heller studere andre nettsteder og se hva de sier der... Lenke til kommentar
Ludde Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 som mange andre "glemmer", tipper jeg gainward også har "glemt" å oppgi annet enn den MEKANISKE støyen.. pga luft.. vil den reelle støyen bli betydelig høyere, hvis jeg har rett Lenke til kommentar
MDCCLXXVI Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Ting ser bare lysere og lysere ut for GFFX atm Lenke til kommentar
Lch Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Jeg tviler uansett sterkt på at den mekaniske støyen kun er 7dB. Lenke til kommentar
akzj0n Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Eh, ikke veldig sannsynlig nei. Etter at ytelsen til fx kortet ble kjent, har jeg egentlig ikke så stor tiltro til nvidia lenger, typisk salgstriks dette og sikkert. Lenke til kommentar
bel Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 .....the same as a human heartbeat..... Lenke til kommentar
dr_down Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 7 db????Med luftkjøling? Må jo være skrivefeil.. Er jo nettopp der det ligger, det er luftkjølt i form av heatpipe-teknologien, ikke ved hjelp av viftekjøling. Lenke til kommentar
mandela Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 heatpipes som tar opp 3 pci-plasser? 70W heat dispatch, øh, 7dB? høres merkelig ut. dersom det er sant betyr det vel at alle cpu-kjølere til dagens amd og intel kan byttes ut til fordel for fulstendig lydløse kjøleløsninger Lenke til kommentar
scirocco Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Kan hende at produsenten tok med seg lydkortet i et vakuum (altså verdensrommet) og testa støynivået der ute..... Lenke til kommentar
Rikky Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 7 db????Med luftkjøling? Må jo være skrivefeil.. Er jo nettopp der det ligger, det er luftkjølt i form av heatpipe-teknologien, ikke ved hjelp av viftekjøling. Lager en heatpipe 7 db da? Lenke til kommentar
mandela Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 "They are releasing the FX with a normal and most of all silent 7DB cooler! " står det i den linken.. Lenke til kommentar
Amnio Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Så, dvs heatpipe med ei 12db Papst vifte på 7V? Lenke til kommentar
DesertGlow Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Kan hende at produsenten tok med seg lydkortet i et vakuum (altså verdensrommet) og testa støynivået der ute..... 7000 kroner på at man i vakuum ikka hadde hørt noe som helst på en meters avstand 8) Lenke til kommentar
QXLNO Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Owing to Gainward’s advanced R&D skills the maximum noise is reduced to only 27db, the same as a human heartbeat. Competetive products maximum noise levels can be rated as high as 70db the same level as a domestic vacuum cleaner. ENGELSK!! LES EN GANG TIL! Lenke til kommentar
atticus Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Og som vanlig er alle like skeptiske.. Faen som dere klager da. Selvom om skulle bråke trippel så høyt som oppgitt ville det vært bra. Bare vent til den kommer.. Bare vent.. Lenke til kommentar
scirocco Skrevet 30. januar 2003 Rapporter Del Skrevet 30. januar 2003 Og som vanlig er alle like skeptiske.. skitt som dere klager da. Selvom om skulle bråke trippel så høyt som oppgitt ville det vært bra. Bare vent til den kommer.. Bare vent.. Tre ganger så høyt lydnivå blir 13 dB. Ikke helvete om det kortet greier noe sånt.. Lenke til kommentar
