Artifacts og frysing ved spilling
Har i det siste opplevd en god del artifakts i noen spill, og også at spillet (Hele PC-en) fryser seg helt i 20-30sek. Varme kan vi utelukke, bare sånn at det ikke er "Hva med det". NEI, det er ikke det.
Fra DxDiag
Klikk for å se/fjerne innholdet nedenfor
System Information
Time of this report: 10/19/2007, 21:00:13
Machine name: NEPPE
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: English (Regional Setting: Norwegian (Bokmål))
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: P35-S3
BIOS: Award Modular BIOS v6.00PG
Processor: Intel® Core2 Duo CPU E6750 @ 2.66GHz (2 CPUs)
Memory: 3582MB RAM
Page File: 448MB used, 5015MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 7900 GT/GTO
Manufacturer: NVIDIA
Chip type: GeForce 7900 GT/GTO
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0291&SUBSYS_22131682&REV_A1
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.6371 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/17/2007 01:07:00, 5783040 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 9/17/2007 01:07:00, 6853088 bytes
Device Identifier: {D7B71E3E-41D1-11CF-D16D-180200C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0291
SubSys ID: 0x22131682
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Audigy Audio [D000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_00511102&REV_03
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.1196 (English)
WHQL Logo'd: Yes
Date and Size: 8/11/2006 14:45:38, 499584 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 191999
Static/Strm HW Mix Bufs: 64, 61
Static/Strm HW 3D Bufs: 64, 61
HW Memory: 0
Voice Management: Yes
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Audigy DirectMusic Synthesizer [D000], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB Audigy Audio [D000], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy Synth A [D000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy Sw Synth [D000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy Synth B [D000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy MIDI IO [D000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy MIDI IO [D000] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0A81, 0x0101
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2936
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 14:00:00, 57600 bytes
| Driver: usbd.sys, 8/4/2004 14:00:00, 4736 bytes
Gameport Devices
+ Intel® 82801 PCI Bridge - 244E
| Matching Device ID: pci\ven_8086&dev_244e
| Service: pci
| Driver: pci.sys, 8/4/2004 14:00:00, 68224 bytes
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7003&subsys_00401102
| | Service: gameenum
| | Driver: gameenum.sys, 8/3/2004 23:08:22, 10624 bytes
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 14:00:00, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 14:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ Microsoft USB IntelliMouse Explorer 3.0
| Vendor/Product ID: 0x045E, 0x0047
| Matching Device ID: hid\vid_045e&pid_0047
| Service: mouhid
| Driver: mouclass.sys, 8/4/2004 14:00:00, 23040 bytes
| Driver: mouhid.sys, 8/4/2004 14:00:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 84.3 GB
Total Space: 100.0 GB
File System: NTFS
Model: ST3320620AS
Drive: D:
Free Space: 119.2 GB
Total Space: 205.2 GB
File System: NTFS
Model: ST3320620AS
Drive: E:
Model: Compaq DVD-ROM DVD-117
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Norwegian (Bokmål)), 8/4/2004 14:00:00, 49536 bytes
Drive: F:
Model: AOPEN CD-RW CRW5224
System Devices
Name: PCI Simple Communications Controller
Device ID: PCI\VEN_8086&DEV_29C4&SUBSYS_29C41458&REV_02\3&13C0B0C5&0&18
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_8086&DEV_29C1&SUBSYS_00000000&REV_02\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 68224 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_8086&DEV_29C0&SUBSYS_00000000&REV_02\3&13C0B0C5&0&00
Driver: n/a
Device ID: PCI\VEN_8086&DEV_2948&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E4
Device ID: PCI\VEN_8086&DEV_2946&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E3
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E0
Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_A0021458&REV_02\3&13C0B0C5&0&D8
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_50061458&REV_02\3&13C0B0C5&0&D7
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 02:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 7168 bytes
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_50061458&REV_02\3&13C0B0C5&0&EF
Name: Standard Universal PCI to USB Host Controller
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D2
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 20480 bytes
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D1
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D0
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_50041458&REV_02\3&13C0B0C5&0&EA
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_50041458&REV_02\3&13C0B0C5&0&E9
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_50041458&REV_02\3&13C0B0C5&0&E8
Name: SM Bus Controller
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_50011458&REV_02\3&13C0B0C5&0&FB
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_8086&DEV_2926&SUBSYS_B0021458&REV_02\3&13C0B0C5&0&FD
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Norwegian (Bokmål)), 8/4/2004 14:00:00, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/4/2004 14:00:00, 3328 bytes
Device ID: PCI\VEN_8086&DEV_2921&SUBSYS_B0021458&REV_02\3&13C0B0C5&0&FA
Name: PCI standard ISA bridge
Device ID: PCI\VEN_8086&DEV_2918&SUBSYS_00000000&REV_02\3&13C0B0C5&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/4/2004 14:00:00, 35840 bytes
Name: Intel® 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_92\3&13C0B0C5&0&F0
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_B0001458&REV_02\4&24C54F4F&0&00E3
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7003&SUBSYS_00401102&REV_03\4&1ADD88A5&0&11F0
Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:22, 10624 bytes
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_00\4&1ADD88A5&0&12F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 15:46:40, 6400 bytes
Name: Creative SB Audigy
Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_00511102&REV_03\4&1ADD88A5&0&10F0
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (Norwegian (Bokmål)), 8/4/2004 00:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (Norwegian (Bokmål)), 8/4/2004 00:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (Norwegian (Bokmål)), 8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (Norwegian (Bokmål)), 8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:56:58, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:14, 502272 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:38, 499584 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:24, 116224 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:40, 7168 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:18, 143872 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:18, 78336 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:26, 766976 bytes
Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:26, 154112 bytes
Driver: C:\WINDOWS\system32\drivers\haP17v2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:28, 180224 bytes
Driver: C:\WINDOWS\system32\drivers\ha20x2k.sys, 5.12.0001.1196 (English), 8/11/2006 14:45:32, 1110016 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 8/11/2006 14:56:36, 8192 bytes
Driver: C:\WINDOWS\system32\ctdlang.dat, 8/11/2006 14:49:24, 323640 bytes
Driver: C:\WINDOWS\system32\ctdnlstr.dat, 8/11/2006 14:49:24, 44567 bytes
Driver: C:\WINDOWS\system32\ctstatic.dat, 8/11/2006 14:43:04, 313207 bytes
Driver: C:\WINDOWS\system32\ctdaught.dat, 8/11/2006 14:43:04, 53932 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 2.09.0000.0000 (English), 8/17/2001 22:36:10, 98304 bytes
Driver: C:\WINDOWS\system32\commonfx.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:08, 87552 bytes
Driver: C:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:12, 536576 bytes
Driver: C:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:32, 548352 bytes
Driver: C:\WINDOWS\system32\cteapsfx.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:28, 160768 bytes
Driver: C:\WINDOWS\system32\CTEXFIFX.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:42, 1170432 bytes
Driver: C:\WINDOWS\system32\CTHWIUT.DLL, 5.12.0001.1196 (English), 8/11/2006 14:48:52, 61952 bytes
Driver: C:\WINDOWS\system32\CT20XUT.DLL, 5.12.0001.1196 (English), 8/11/2006 14:48:50, 158720 bytes
Driver: C:\WINDOWS\system32\ctemupia.dll, 5.12.0001.1196 (English), 8/11/2006 14:48:52, 108032 bytes
Driver: C:\WINDOWS\system32\piaproxy.dll, 5.12.0001.1196 (English), 8/11/2006 14:45:16, 73728 bytes
Driver: C:\WINDOWS\system32\ctdproxy.dll, 5.12.0001.1196 (English), 8/11/2006 14:45:34, 71680 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 8/11/2006 14:45:20, 21504 bytes
Driver: C:\WINDOWS\system32\ctbas2w.dat, 8/11/2006 14:45:08, 140643 bytes
Driver: C:\WINDOWS\system32\ctsbas2w.dat, 8/11/2006 14:43:26, 265042 bytes
Driver: C:\WINDOWS\system32\SBAudigy.ico, 8/17/2001 12:42:28, 7406 bytes
Driver: C:\WINDOWS\system32\Audigy.bmp, 11/13/2001 09:48:20, 1912 bytes
Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0002.0036 (English), 8/11/2006 14:57:04, 81920 bytes
Driver: C:\WINDOWS\system32\ctdvinst.dll, 0.04.0000.0036 (English), 8/11/2006 14:57:06, 146432 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0467 (English), 11/10/2005 17:06:04, 340704 bytes
Name: Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_01\4&345CAFAF&0&00E4
Driver: C:\WINDOWS\system32\DRIVERS\Rtenicxp.sys, 5.674.0807.2007 (English), 8/7/2007 17:40:38, 98944 bytes
Name: NVIDIA GeForce 7900 GT/GTO
Device ID: PCI\VEN_10DE&DEV_0291&SUBSYS_22131682&REV_A1\4&1A9C9F1A&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 6853088 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 5783040 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 155716 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 364544 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 6746112 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 8491008 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11117 (English), 9/17/2007 01:07:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 6344704 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 3334144 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 1150976 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 3551232 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 2371584 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 9/17/2007 01:07:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 9/17/2007 01:07:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 9/17/2007 01:07:00, 36864 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 9/17/2007 01:07:00, 36864 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 14:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 14:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 14:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:08:22 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 14:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 14:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 14:00:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/4/2004 14:00:00 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/30/2005 05:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 14:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 14:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 14:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 14:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 14:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 14:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 14:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 14:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 204288 bytes
ks.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 Norwegian (Bokmål) Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/4/2004 14:00:00 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
SB Audigy Audio [D000],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy MIDI IO [D000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy Sw Synth [D000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy Synth A [D000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy Synth B [D000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
SB Audigy MIDI IO [D000],0x00200000,2,2,,5.03.2600.2180
SB Audigy Audio [D000],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
SB Audigy DirectMusic Synthesizer [D000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Sw Synth [D000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Synth A [D000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Synth B [D000],0x00200000,1,1,,5.03.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
SB Audigy Audio [D000],0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: SB Audigy Audio [D000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
SB Audigy Synth A [D000],0x00200000,11,2,,5.03.2600.2180
SB Audigy Audio [D000],0x00200000,13,2,,5.03.2600.2180
Det er slik at i noen spill er det masse artifacs, mens i andre er det omtrent ingen. Noen spill fryser seg, andre ikke. Om det, f.eks skulle komme så mye artifacts at jeg ikke ser noe som helst, så kan jeg bare minimere, å åpne spillet igjen, så er det greit i ett par minutt. Noen ganger kan jeg spille i flere timen, noen ganger er det artifacts så fort jeg starter opp. Som sagt, så er det inget møstre. Eneste jeg har merket er at om jeg lar spillet stå, så får jeg masse artifacts.
Er det bare i noen spill? Har du nyeste drivere? Er noen av komponentene overklokket?
Er vel ting du har kommet på dette, og sjekket, men spør i tilfelle du ikke har kommet på det.
Er det programvare til skjermkortet utenom driverene? Altså lignende ATI's catalyst control center?
Det er ille i noen spill, men det oppstår i alle. Ingen av komponentene er overklokket. Ingen programvare utenom driveren, og ja, har de nyeste.
Fikk tips om at det kanskje kunne være en av minnebrikkene. Finnes det noen tester det går ann å kjøre for å sjekke?
Jeg har en venn med samme grafikkort og samme problemet, jeg har prøvd det meste men har ikke funnet årsaken...
Det er neppe skjermkortet. Har hatt dette veldig lenge. Men CPU, ram, hk og hdd er byttet ut.
Finnes ingen programmer jeg kan kjøre rett fra windows?
Endret av Neppe
Jeg har nøyaktig samme problemet med mitt 7900GT, og kjenner flere som har trøbbel med sine 7900GT-kort. Artifactsene kom gradvis etter 4-5 måneder hos meg.
Når sant skal sies er mitt nåværende kort det andre 7900GT-kortet jeg har, fordi jeg byttet kort p.g.a at det første jeg fikk hadde virkelig psykedeliske artifacts i både spill og Windows fra dag én.
Nå er jeg ingen ekspert på skjermkort og grafisk rendering, men siden jeg får samme artifacts i teksturer som jeg får som enkeltpiksler her og der, så antyder det at problemet ligger i minnet på skjermkortet hvor bl.a teksturene lagres. Samtidig har jeg en del forvridd geometri, som også lagres i minnet før rendering. Med mindre man er en maestro med loddebolt er eneste måte å fikse dette på å kjøpe nytt skjermkort.
Endret av skag1
men les kva han skriver da! Når han vil at det ikkje skal være skjermkortet hans, så er det vel ikkje det. Det må vi godta. Vi får finne på noke anna...
Uhm... ikkje var det varme heller? uhm... men kva om du finner deg ei feit bordvifte, setter den til å blåse inn på sida av kabinettet ditt.. bare for å utelukke det.
Artifacts kjem jo ofte av for varme grafikkkort...
Sist gang dette skjedde hos meg så tok jeg ut skjermkortet og sjekket inni. Der så det ut som jeg hadde kjørt over en kanin eller et annen hårete dyr.
En fullstendig sjekk av vifter o.l. er jo en selvfølge.
EDIT: Kan jo eventuelt prøve nyest driver tilgjengelig for skjermkortet.
Endret av Teejay187
AtiTool passer vel neppe så godt til et nVidia GT7900 skjermkort? "normalt" har ATI og nVidia drivere som ikke ligner hverandre.
RivaTuner kan visst brukes på begge typer: http://downloads.guru3d.com/download.php?det=163
Når eg hadde nVidia skjermkort brukte eg ExperTool fra Gainward til og overvåke temperaturer og frekvenser, kan hentes her: http://www.gainward.com/support/support_uk.html
AtiTool fungerer på nvidiakort. Funket på begge mine 7600GS og GT. Bare at programmet har "ATI" i seg betyr jo ikke at det ikke fungerer med nvidia kort -.-
Ati tool fungerer utmerket for å teste ram'en på nvidiakort også.
Når det er sagt må jeg påpeke at jeg har lest at det IKKE er feil på skjermkortet, men alikevel......
Slik jeg ser det har du for høy temp på skjermkortet eller ramfeil på skjermkortet eller for høy freq. på pcie bussen eller evt for lite power.
Løsning : Gjøres i rekkefølge
Gjør ren kjøleløsningen slik at den fungerer (som en tidligere poster sa "kanin" :no: )
Sjekk at det er ordentlig kontakt på powerkablene til skjermkortet og at spenningene er ok.
Sjekk freq. på pcie <100Mhz
Bruk ati tool el. for å sjekke ram'en på skjermkortet.
Dersom du finner feil, prøv evt. å underklokke skjermkortet for å se om feilene forsvinner.
Send evt. inn kortet som reklamasjon?
Lykke til
Endret av inferror
*snip*
Om du har hatt det veldig lenge så begynner det kanskje å bli slitent? Mest sansynlig er det skjermkortet som er defekt. Hvis du har muligheten til det så kan du jo teste kortet i en annen maskin og se om problemet er der enda.
