Goodall Skrevet 18. oktober 2007 Del Skrevet 18. oktober 2007 It seems that the Radeon 2950 we all wanted to know and love (and own two of!) might be getting a pre-launch name change to Radeon 3800. Please remember that this is only a rumor so take it with a grain of salt. “Previously, they are known as Radeon HD 2950 series. Interestingly, one of the AIB partners has even listed out Radeon HD 3800 on their website. Earlier, AMD has made changes to the naming of the Phenom processors and now the changes are being made to the graphics cards too. As such, AMD has decided to drop PRO, XT, GT, XTX from their future HD 3000 series graphics series and the last 2 digits of the series will determine the performance of the card. RV670PRO will be known as Radeon HD 3850 while RV670XT will be know as Radeon HD 3870 when they are launched on Nov 15th.” If you're scratching your head and wondering why AMD decided to change the name to the 3000 series, you're not alone. One possible explanation that comes to mind is that ATI is trying to distance the new product from the 2900 series, which didn't launch with a fully optimized driver and many of the initial reviews of the product were less than kind. Oh R700, wherefore art thou? Håper dette er litt mer enn en klype salt, hadde vært digg om de sluttet med gt, xt og alt som gjør det forvirende. Bedre med eksemplet 3850 og 3870 Lenke til kommentar
2ball_ Skrevet 18. oktober 2007 Del Skrevet 18. oktober 2007 (endret) da var vi to ...eller tre.... Endret 18. oktober 2007 av 2ball(s) Lenke til kommentar
SWAT dude... Skrevet 18. oktober 2007 Del Skrevet 18. oktober 2007 Ser ikke hva som er så vansklig med endingene. Har aldri hatt problemer med å huske endingene. De som høres mest fjortiss ut er best. Slik husker jeg det hvertfall Lenke til kommentar
madsc90 Skrevet 19. oktober 2007 Del Skrevet 19. oktober 2007 Jeg synes da alle hører fjortiss ut! Også er det jo også slik at noen modeller med spes ending kan være bedre enn et høyere nummer med en annen ending osv... :s Lenke til kommentar
MistaPi Skrevet 21. oktober 2007 Del Skrevet 21. oktober 2007 (endret) HD3870 (RV670XT): Edit: Det ser ut som kjøleløsningen er mer eller mindre den samme som den 1950XTX brukte. Endret 21. oktober 2007 av MistaPi Lenke til kommentar
