TYAN's Tachyon G9700 PRO
Alastor
Stakk innom ATi sin side i dag, og fant ut at et nytt kort var på vei ut på markedet. Utdrag fra teksten:
"The Tachyon G9700 PRO is the only RADEON™ 9700 PRO based graphics card on the market with hardware monitoring. The Tyan Graphics Monitor is a user-friendly system monitoring utility that allows the user to monitor and modify fan speeds, and keep a close eye on voltage, VPU and memory temperatures, all in real-time.
In addition, the Tachyon G9700 PRO can be overclocked to nearly 400MHz - making it the fastest graphics card today. Fitted with an advanced cooling system, the graphics card can run cool and stable with memory speeds approaching the limits of today's DDR memory technology."
Dette høres jo utrolig lovende ut...kanskje ATi sitt Point of View GF4200XP eller noe. Hadde vært fett å overklokke dette kortet maks og så sammenligne med et GFFX :woot:
EDIT: fant en test; http://www.hardocp.com/article.html?art=NDA0LDE=
