Info om Intel 45nm
Intern
Intel plans two new Quad cores in Q3
The Q9650 and Q9400
Intel plans to launch two new 45nm Yorkfield based quad cores with quite reasonable prices, and it plans to do this in Q3 2008. As many of you know, Q3 starts in July and lasts until the last day of September and in this period Intel plans to introduce the Core 2 Quad Q9650 and Core 2 Quad 9400.
The Core 2 Q9x50 model name means that the CPU has 12MB of cache while the Core 2 Q9x00 means that it comes with 6MB, the additional 6MB is simply disabled.
The Core 2 Quad Q9650 will run at 3.0GHz on a 1,333MHz FSB. fits in socket 775 and has 12MB of L2 cache memory. It will sell for $525 at launch and of course it’s made in 45nm dual core stitched process. The second quad core to launch in Q3 is the Core 2 Quad Q9400 which will run at 2.66GHz, again on a 1,333MHz FSB, using socket 775 and it has 6MB of L2 cache memory. This is CPU is the same as the current just about available Q9450, but with 6MB of L2 cache cut off. The Q9400 will sell for $268 at launch.
These might be the last Quad core 45nm high performance parts to launch, but knowing Intel, this can easily change if necessary.
Kilde
Tror jeg vil ha en sånn Q9650. :p
Det var ikke så værst til pris. 2677.5 NOK. Noe som sikkert fører til en pris rett over 3000 kroner når den kommer til norge, mens senere kan den synke under 3000 kanskje. :)
Dersom ikke Nehalem viser seg å bli en god kandidat da. :)
Endret av LockBreaker
Om man tar prisforskjellene i USD vs NOK på dagens prosessorer vil jeg tippe den vil legge seg på 3500,- (Q9550 koster pr i dag $530 og ligger på 3500 NOK, så jeg tok utgangspunkt i den).
Endret av Smirnoff
Oppi alt dette 45nm-styret synes jeg 65nm-modellene bare blir mer og mer interessante for de som trenger multiprosessering. F.eks går både Xeon X3220 og C2D Q6600 for rundt 1450 kr nå.
Man må øke prisen fra 1450 til ca 2200 kr (50%) for å øke klokkefrekvensen med usle 11% og L2 cachen fra 8 til 12 MB. Overklokkingsevnen synker faktisk på grunn av lavere multiplier og FSB-veggen. Om ikke det var nok så må man pent stille seg på venteliste. Q9450 er ikke tilgjengelig ennå.
Oppslagsverk: Direkteshop skal vistnok ha E7200 på lager.
Q6600 er en knakende god prosessor ;-)
Til prisen er den er røverkjøp!
Gjest Slettet+6132
Fornuftige Simen "strikes again". :)
Helt enig i hans betraktninger her.
En Q6600 til den prisen er ett laaangt bedre valg enn en "opphauset" E8400.
Min Q6600 "koser" seg på 3.6 @ 1.28VCOre (load) og klarer greit 4.0Ghz for utstarkt bencing, mens min E8400 relativt sett klokker *elendig* i forhold.
I tillegg til at den ikke er *helt* kompatibel med noen av de hk (mange) jeg har.
For å moderere litt:
De fleste dual core 65nm utgavene er inntil prisene blir satt kraftig ned på disse ett veldig dårlig alternatvi til 45nm dual core.
Men sålenge det er "fulle" lagere med Q6600 G0 bør man heller anskaffe en slik fremfor en E8n00. "Alle" skal ha 45nm dual core og tilbudet er jo deretter.
"Direkteshop" har jeg svært liten tiltro til har noe lager/beholdning av noesomhelst.
De må nok vise til litt mer fartstid/brukererfaringer før jeg vil si de er ett reeltt alternativ til de mer etablerte.
Ikke minst til om de har noe av vareutvalget sitt på lager/er leveringsdyktige.
Endret av Slettet+6132
Tja, jeg vil si begge er svært gode kjøp, men til hver sine ting. Jeg kunne tenkt meg begge. Firekjernen til jobb (multiprosessering) og dobbeltkjernen til hjemmebruk (mest enkelprosessering).
De har faktisk hatt nettbutikken i mange år, men jeg er også skeptisk til om lagerstatusen stemmer. De kan ha feiltolket statusen på eksternlagret sitt.
Redigert: E2200 (2,2 GHz) til 405 kr er også et røverkjøp for tida.
Med en multiplikator på 11 kommer nok aldri noen FSB-vegg til å hindre deg på den. FSB henger sikkert med på både prosessorsiden og hovedkortet opp til en dobling (800 -> 1600 FSB), men da må man sikkert redusere multiplikatoren et par hakk. F.eks til 9x (3,6 GHz), med mindre man har dyr ekstremkjøling, og da sikter man nok på dyrere prosessorer i utgangspunktet.
E2200 er vistnok ekstremt bra til overklokking på følgende felter:
- Svært høy prosentvis overklokk
- Ekstremt høy sluttytelse per krone
F.eks skulle det ikke by på store problemer å knuse en E8500 til nesten 2000 kr på original hastighet, for 1/5 av prisen
