Samba - Galskapen tar ingen ende ...
stikko@Selkos:~$ cat /etc/samba/smb.conf
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentary and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = valhall
# server string is the equivalent of the NT Description field
server string = %h (Ubuntu Samba) Server
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
; wins support = no
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
; wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
dns proxy = no
# What naming service and in what order should we use to resolve host names
# to IP addresses
; name resolve order = lmhosts host wins bcast
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
; interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself. However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
; bind interfaces only = true
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/log.%m
# Put a capping on the size of the log files (in Kb).
max log size = 1000
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
; syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
syslog = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# "security = user" is always a good idea. This will require a Unix account
# in this server for every user accessing the server. See
# /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/ServerType.html
# in the samba-doc package for details.
; security = user
# You may wish to use password encryption. See the section on
# 'encrypt passwords' in the smb.conf(5) manpage before enabling.
encrypt passwords = yes
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
passdb backend = tdbsam
obey pam restrictions = yes
; guest account = nobody
invalid users = root
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
; unix password sync = no
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan < for
# sending the correct chat script for the passwd program in Debian Sarge).
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\sUNIX\spassword:* %n\n *Retype\snew\sUNIX\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
; pam password change = no
########## Domains ###########
# Is this machine able to authenticate users. Both PDC and BDC
# must have this setting enabled. If you are the BDC you must
# change the 'domain master' setting to no
; domain logons = yes
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of the user's profile directory
# from the client point of view)
# The following required a [profiles] share to be setup on the
# samba server (see below)
; logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
; logon path = \\%N\%U\profile
# It specifies the location of a user's home directory (from the client
# point of view)
; logon drive = H:
; logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
; logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe. The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
########## Printing ##########
# If you want to automatically load your printer list rather
# than setting them up individually then you'll need this
; load printers = yes
# lpr(ng) printing. You may wish to override the location of the
# printcap file
; printing = bsd
; printcap name = /etc/printcap
# CUPS printing. See also the cupsaddsmb(8) manpage in the
# cupsys-client package.
; printing = cups
; printcap name = cups
# When using [print$], root is implicitly a 'printer admin', but you can
# also give this right to other users to add drivers and set printer
# properties
; printer admin = @lpadmin
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
; include = /home/samba/etc/smb.conf.%m
# Most people will find that this option gives better performance.
# See smb.conf(5) and /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/speed.html
# for details
# You may want to add the following on a Linux system:
# SO_RCVBUF=8192 SO_SNDBUF=8192
socket options = TCP_NODELAY
# The following parameter is useful only if you have the linpopup package
# installed. The samba maintainer and the linpopup maintainer are
# working to ease installation and configuration of linpopup and samba.
; message command = /bin/sh -c '/usr/bin/linpopup "%f" "%m" %s; rm %s' &
# Domain Master specifies Samba to be the Domain Master Browser. If this
# machine will be configured as a BDC (a secondary logon server), you
# must set this to 'no'; otherwise, the default behavior is recommended.
; domain master = auto
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
; idmap uid = 10000-20000
; idmap gid = 10000-20000
; template shell = /bin/bash
#======================= Share Definitions =======================
# Un-comment the following (and tweak the other settings below to suit)
# to enable the default home directory shares. This will share each
# user's home directory as \\server\username
;[homes]
; comment = Home Directories
; browseable = no
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server. Un-comment the following parameter
# to make sure that only "username" can connect to \\server\username
; valid users = %S
# By default, the home directories are exported read-only. Change next
# parameter to 'yes' if you want to be able to write to them.
; writable = no
# File creation mask is set to 0600 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0664.
; create mask = 0600
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
; directory mask = 0700
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
; comment = Network Logon Service
; path = /home/samba/netlogon
; guest ok = yes
; writable = no
; share modes = no
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
; comment = Users profiles
; path = /home/samba/profiles
; guest ok = no
; browseable = no
wins support = no
restrict anonymous = no
domain master = no
preferred master = no
max protocol = NT
acl compatibility = winnt
ldap ssl = No
server signing = Auto
guest account = levas
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
[Networkshare]
path = /home/stikko/Desktop/Networkshare
guest ok = yes
read only = no
[Networkshare2]
path = /home/stikko/Desktop/Networkshare2
guest ok = yes
read only = no
[Networkshare3]
path = /home/stikko/Desktop/Networkshare3
guest ok = yes
Ok, det ser ut som om mappene du har delt er Public og at du ikke har lagt til noen brukere som skal ha adgang til de:
kcontrol->Internet & Network->File Sharing
velg Change på aktuell mappe, huk bort Public, More Samba Options->Users, og legg til de brukerne som skal ha adgang.
Okai, nå er jeg tilbake i XP. Prøvde det du sa over. Først kom jeg ikke inn på serveren i det hele tatt, deretter satt jeg "security lvl" til Share, da kan jeg se mappen, men ikke få tilgang - noe som forsåvidt skal stemme? Spørsmålet er jo da, hvordan får jeg tilgang til serveren?
;[profiles]
; guest ok = no
; browseable = no
wins support = no
domain master = no
max protocol = NT
ldap ssl = No
[printers]
browseable = no
printable = yes
create mask = 0700
# printer drivers
[print$]
[Networkshare]
path = /home/stikko/Desktop/Networkshare/
valid users = levas
write list = levas
case sensitive = no
strict locking = no
msdfs proxy = no
stikko@Selkos:~$
Yupp, nå står den på user ja. Nå har jeg dog et helt annet problem, skulle koble til noen andre disker, noe som ikke gikk helt smertefritt - fikk deretter litt "hjelp" fra en kar på MSN, og nå vil ikke Kernel starte, herlig ...
Edit: Takk Gud, det fungerer igjen. Prøvde på en "cdisk", noe som ga "FATAL ERROR" og reboot ...
Endret av Stikko
Hihi, hoho! Det fungerer!
Det tok bare hele natta, og halve morgenen, men nå fungerer det nøyaktig slik det skal. Reinstallerte hele serveren, la altså inn Ubuntu på nytt. Deretter installerte jeg Samba, delte mappene, opprettet bruker, før jeg tilslutt åpnet konfigurasjonfilen til Samba, etter litt fram og tilbake der fikk jeg endelig logget meg på med brukernavn og passord!
Fryd og glede :D
Fryd og glede :D
Kjempebra! Jeg ser at log-in funksjonalitet i Samba er noe mange vil ha, og som ikke er godt nok beskrevet i howto'en, skal ta en ny runde der så snart jeg får tid slik at de neste bør kunne løse dette på et par minutter. Ellers tviler jeg på at noen ny installering var nødvendig, men personlig editerer jeg /etc/fstab manuelt, så jeg er veldig interessert i å høre detaljer rundt hvilke issues du hadde med diskene? Selv om du roter til ting slik at det ikke vil boote, er det nesten alltid fort gjort å få systemet oppe å gå igjen. Siden alle "herjinger" du gjorde med Samba ligger i smb.conf, er også veldig fort gjort å "nullstille" (f.eks. kopiere over en generisk konfig fil), så ikke vær redd for å skru. En liten back-up av sentrale konfig filer kan være en grei ting selvfølgelig, men det er vel alltid brukere her som kan poste en. Du kan redigere fra en live-CD dersom det er så ille at systemet ikke booter.
Sånn, da har jeg oppdatert howto'en, du får ta en titt og se om det du har strevd med er godt nok dekket.
Endret av Del
Re-installering er ganske sikkert helt unødvendig, selv om det er veldig fort gjort med K/Ubuntu. Hvis du klarer å forklare hva du prøver å sette opp, så er det lett å hjelpe. Bare post smb.conf filen din, så finner vi nok fort ut av det.
Mitt problem med booting var nok ikke relatert til Samba, men heller til IDE-kontrolleren min. Jeg har totalt 4 disker i serveren, 2 SATA og 2 PATA, kun de to førstnevnte fungerer. Tror dog jeg heller skal opprette en ny tråd for dette, så holder vi det oversiktlig :)
hva er det jeg gjør galt, gir snart opp jeg
;[profiles]
; guest ok = no
; browseable = no
wins support = no
[printers]
browseable = no
printable = yes
create mask = 0700
# printer drivers
[print$]
[HJEMME]
path = /hjemme
guest ok = yes
read only = no
case sensitive = no
strict locking = no
msdfs proxy = no
valid users = tore
admin users = tore
Endret av vetle
Litt tidlig for det ennå, vi vet jo ikke engang om du vil ha log-in til mappen, eller om du bare vil kunne gå rett inn på den (uten å logge inn) fra hvilken som helst bruker/maskin i nettverket ditt.
Hvis du kan gi oss svar på det, samt poste hele smb.conf, så finner vi sikkert for ut av det.
ok
Jeg har 5 PC-er koblet sammen med en switch og en router fra netgentel,
Alle pcene er medlem av en workgrp som heter huset.
Jeg vil da at jeg skal kunne bruke kubuntu boxen til et felles lagrings område,
3 av pcene har ikke passord ved pålogging (kona og 1 hver til ungene) De 2 andre har pålogging med passord.
OS på pcene er 4 x xp og en vista
Jeg vil da ha mulighet til å nå kubuntu boxen fra alle pcene, uten å måtte bruke passord.
Alle har egen bruker, men altså kun 2 av pcene med passord
takk for kjempe god hjelp
# errors.
[global]
workgroup = HUSET
server string = %h server (Samba, Ubuntu)
;   wins support = no
dns proxy = no
# to IP addresses
# that connects
max log size = 1000
;   syslog only = no
syslog = 0
;   security = user
# parameters must be set (thanks to Ian Kahan <<[email protected]> for
# point of view)
;   logon drive = H:
# printcap file
;   printing = bsd
;   printing = cups
# properties
# for details
domain master = no
max protocol = NT
ldap ssl = No
;[homes]
;   browseable = no
;   valid users = %S
;   writable = no
;[netlogon]
;   guest ok = yes
;   writable = no
;   share modes = no
;[profiles]
;   guest ok = no
;   browseable = no
wins support = no
[printers]
browseable = no
printable = yes
create mask = 0700
# printer drivers
[print$]
[HJEMME]
path = /hjemme
guest ok = yes
read only = no
case sensitive = no
strict locking = no
msdfs proxy = no
valid users = tore
admin users = tore
OK, flott. Hvis jeg forstår deg riktig vil du da at alle skal ha tilgang til de delte mappene uten å trenge å bruke brukernavn og passord når de går inn på delt mappe. Da må du sette ned sikkerhetsnivået til Share som forklart i den første skjulte biten i punkt 1.4 her:
https://www.diskusjon.no/index.php?showtopic=818603
Så anbefaler jeg deg å opprette mappen du skal dele i hjemmekatalogen til brukeren din på Kubuntu maskinen, nå har du lagt den helt øverst i et område vanlige brukere ikke normalt har adgang til. Fra terminal oppretter du mappen f.eks. slik:
mkdir /home/tore/hjemme
så legger du den til som delt mappe etterpå i kcontrol, drar og slipper de filene du måtte ønske ned i den mappen, så starter du samba på nytt med
sudo /etc/init.d/samba reload
Nå skal mappen komme opp i XP der hvor delte mapper kommer opp (network places eller noe slikt, jeg har begynt å glemme hvordan det så ut i MS, sorry).
