Telle antall linjer, legge til bilde og fortsette
Kakkle, jeg er ikke helt sikker på hvor jeg skal plassere koden din...
Det er denne koden jeg har (den delen jeg tror telle scriptet skal være)
Klikk for å se/fjerne innholdet nedenfor
if ( (!isset( $_GET['action'] )) || (empty( $_GET['action'] )) || ($_GET['action'] === "veiw" ))
$posttoreplace = array(
"/{emailorurl}/",
"/{name}/",
"/{comments}/",
"/{date}/",
$fp = fopen( $config["guestbookpost"], "r" );
$posttpl = fread( $fp, filesize( $config["guestbook"] ) );
fclose( $fp );
if( !isset($_GET['num']) || !is_numeric($_GET['num']) )
	 $start = 0;
	 $end = $config["numpostsperpage"];
else
	$start = $_GET['num'] * $config["numpostsperpage"];
	$end = $start + $config["numpostsperpage"];
$title = "FredrikMoe.com - Gjestebok";
if( $config["newestfirst"] === "yes" )
	$order = " ORDER BY `ID` DESC ";
else
	$order = " ORDER BY `ID` ASC ";
$query = mysql_query( "SELECT * FROM ".$config["mysqlguestbooktable"]."".$order."LIMIT ".$start.",".$end."" );
$isresults = FALSE;
$i = 0;
$posts = "";
while( $post = mysql_fetch_array( $query, MYSQL_ASSOC ) )
	if( strstr ( $post["EMAILORURL"], "@" ) )
		 $emailorurl = "mailto:".stripslashes( $post["EMAILORURL"] );
	else
		if( preg_match( "/http:\/\//i", $post["EMAILORURL"] ) )
			 $emailorurl = stripslashes( $post["EMAILORURL"] );
		else
			 $emailorurl = "http://".stripslashes( $post["EMAILORURL"] );
	$comments = preg_replace($smiles, $rsmiles, stripslashes( $post["COMMENTS"] ));
	$name = stripslashes( $post["NAME"] );
	$postreplace = array(
	$emailorurl,
	$name,
	$comments,
	$post["DATE"]
	$posts .= preg_replace($posttoreplace, $postreplace, $posttpl);
	$i++;
$text .= "<br /><br />";
if( $i >= $config["numpostsperpage"] )
	$isresults = TRUE;
if( $start >= $config["numpostsperpage"] )
	$prev = ($start / $config["numpostsperpage"]) - 1;
	$posts .= "<a href=\"".$_SERVER['PHP_SELF']."?num=".$prev."\">Forrige</a> ";
if( $isresults )
	$next = ($start / $config["numpostsperpage"]) + 1;
	$posts .= " <a href=\"".$_SERVER['PHP_SELF']."?num=".$next."\">Neste</a>\n";
Endret av Microsoftbruker
Du må legge inn $teller=1 før while løkken som skriver ut innleggene, også legger du inn if setningen etter du har skrevet ut et innlegg (inni while løkken). $teller++ må da være på slutten av whileløkken.
Ser forresten at du allerede har en $i som du bruker, så du kan jo bare bruke den, istedetfor å lage en ny $teller.
Men pass da på at siden den starter på 0, så vil 0%5 ==0, dvs at den vil begynne med en annonse etter det første innlegget allerede, men det er bare å plusse på 1 i if setningen. ;)
Det funket ikke :( (eller jeg har gjort en feil)
Her er koden, tror jeg gjorde som du sa...
$isresults = FALSE;
$i = 1;
$posts = "";
	else
		else
	   if($i%5==0) {
echo 'skriv ut en annonse';
	$emailorurl,
	$name,
	$comments,
	$post["DATE"]
	$i++;
Den printer ut "Skriv en annonse" men den printer den i toppen av gjesteboken.
Det ser ikke ut som om du skriver ut innleggene inni while løkken, men legger de inn i en variabel, kanskje ?
Da må du isåfall også legge disse annonsene inn i variabelen. F.eks:
if($i%5==0) {
  $posts .= "Skriv inn en annonse her, kanskje ?";
Eller noe sånt.
