Kan ikke brenne CD-er med NEC ND-3540
shit89
Får ikke brent CD-er med min dvd-brenner. Dette har naturligvis fungert før, men nå klarer den ikke å lese ubrente CD-er eller skrive til dem. Jeg har naturligvis prøvd andre brennere, andre brennemedier og brenneprogrammer, men det er CD-er den ikke klarer å brenne. Hva kan problemet være?
Mvh. Kristian
Her er en logg fra Nero:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.10.1.0
Internal Version: 7, 10, 1, 0
Recorder: <_NEC DVD_RW ND-3540A> Version: 1.04 - HA 1 TA 0 - 7.10.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <_NEC DVD_RW ND-3540A >Version: 1.04 - HA 1 TA 0 - 7.10.1.0
=== Scsi-Device-Map ===
CdRomPeripheral : _NEC DVD_RW ND-3540A nvatabus Port 0 ID 0 DMA: Off
DiskPeripheral : SAMSUNG SP2004C nvatabus Port 1 ID 0 DMA: Off
DiskPeripheral : SAMSUNG SP1614C nvatabus Port 1 ID 2 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3540A D: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 493MB (505532kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.10.2007
CueSheet
17:17:57 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
17:17:57 #2 Text 0 File Burncd.cpp, Line 3196
'Buffer underrun'-beskyttelse aktivert
17:17:57 #3 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using CD-R/RW media
17:17:57 #4 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 366219 ( 81:24.69)
Last address to be written: 325114 ( 72:16.64)
17:17:57 #5 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD DVD)
17:17:57 #6 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: _NEC DVD_RW ND-3540A;
CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
ATIP Data:
Special Info [hex] 1: C0 00 90, 2: 61 0F 11 (LI 97:15.17), 3: 4F 3B 46 (LO 79:59.70)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
17:17:57 #7 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
17:17:57 #8 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_RAW_MODE1 (Cue Sheet Track)
2 indices, index0 (150) provided
original disc pos #0 + 325115 (325115) = #325115/72:14.65
relocatable, disc pos for caching/writing not required/not required
-> TRM_ULTRARAW96_MODE1, 2448, config 4, wanted index0 0 blocks, length 325115 blocks [D: _NEC DVD_RW ND-3540A]
17:17:57 #9 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [D: _NEC DVD_RW ND-3540A] for write in raw writing
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_ULTRARAW96_MODE1, 2448/0x04, FilePos 0 367200 796248720, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 325115 | 0 | 0x00
325115 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
17:17:57 #10 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
17:17:57 #11 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
17:17:57 #12 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
17:17:57 #13 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
17:17:57 #14 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
17:17:57 #15 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 48x (7 200 KB/s)
17:17:57 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
17:17:57 #17 Text 0 File MMC.cpp, Line 17687
StartDAO : CD-Text - Off
17:17:57 #18 Text 0 File MMC.cpp, Line 22363
Set BUFE: Buffer underrun protection -> ON
17:17:57 #19 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
17:18:07 #20 SPTI -1106 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 FF FF CF 24 00 00 1A 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03
Buffer x00000000: Len xf8a0
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
17:18:07 #21 CDR -1106 File Writer.cpp, Line 303
Power calibration error
17:18:08 #22 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 48x (7 200 KB/s)
17:18:09 #23 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
17:18:14 #24 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
17:18:14 #25 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Endret av shit89
  • 4 måneder senere...
