*løst* Hvordan lager jeg en .bat som viser ip info?
Jeg lurer på hordan jeg kan lage en fil som viser ip informasjon. Jeg vet at jeg bare kan lage en .bat fil med "ipconfig/all" men den forsviner slike fort som du trykker på den.... Så hvordan skal jeg få den til å bli?
Endret av Sniken_123
Er på litt tynn is her, men kan du bruke dette ?
PAUSE
Suspends processing of a batch program and displays a message prompting the user to press any key to continue.
Prompting the user to continue the program
Windows 2000 displays the following message in response to the pause command:
Press any key to continue . . .
Dividing a batch file into sections
If you press CTRL+C to stop a batch program, Windows 2000 displays the following message: Terminate batch job (Y/N)?
If you press Y (for yes) in response to this message, the batch program ends and control returns to the operating system. Therefore, you can insert the pause command before a section of the batch file you may not want to process. While pause suspends processing of the batch program, you can press CTRL+C and then Y to stop the batch program
Examples
Suppose you want a batch program to prompt the user to change disks in one of the drives. To do this, you might create the following file:
@echo off
:begin
copy a:*.*
echo Please put a new disk into drive A
pause
goto begin
In this example, all the files on the disk in drive A are copied to the current directory. After the displayed comment prompts you to place another disk in drive A, the pause command suspends processing so that you can change disks and then press any key to resume processing. This particular batch program runs in an endless loop. The goto BEGIN command sends the command interpreter to the begin label of the batch file. To stop this batch program, press CTRL+C and then Y.
