greigutt Skrevet 8. oktober 2007 Del Skrevet 8. oktober 2007 (endret) Hei. Har en server som tryner alt for ofte. Jeg har kjørt en minnedump og analyse, men kan ikke si jeg skjønner stort. Noen som skjønner mer enn meg? Her er minnedumpen: Microsoft ® Windows Debugger Version 6.6.0007.5 Copyright © Microsoft Corporation. All rights reserved. Loading Dump File [c:\memdump\Mini100807-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols Executable search path is: c:\i386 Windows Server 2003 Kernel Version 3790 (Service Pack 2) MP (2 procs) Free x86 compatible Product: LanManNt, suite: TerminalServer SingleUserTS Built by: 3790.srv03_sp2_gdr.070304-2240 Kernel base = 0x80800000 PsLoadedModuleList = 0x808af9c8 Debug session time: Mon Oct 8 02:24:56.785 2007 (GMT+2) System Uptime: 1 days 9:09:28.240 Loading Kernel Symbols .......................................................................................... .................... Loading User Symbols Loading unloaded module list .. Unable to load image msiscsi.sys, Win32 error 2 *** WARNING: Unable to verify timestamp for msiscsi.sys *** ERROR: Module load completed but symbols could not be loaded for msiscsi.sys ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 100000D1, {d606f0e, d0000002, 1, ba638405} Unable to load image tm_cfw.sys, Win32 error 2 *** WARNING: Unable to verify timestamp for tm_cfw.sys *** ERROR: Module load completed but symbols could not be loaded for tm_cfw.sys *** WARNING: Unable to verify timestamp for e1000325.sys *** ERROR: Module load completed but symbols could not be loaded for e1000325.sys Probably caused by : msiscsi.sys ( msiscsi+4405 ) Followup: MachineOwner --------- 0: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If kernel debugger is available get stack backtrace. Arguments: Arg1: 0d606f0e, memory referenced Arg2: d0000002, IRQL Arg3: 00000001, value 0 = read operation, 1 = write operation Arg4: ba638405, address which referenced memory Debugging Details: ------------------ WRITE_ADDRESS: 0d606f0e CURRENT_IRQL: 2 FAULTING_IP: msiscsi+4405 ba638405 10803e010f85 adc byte ptr [eax-7AF0FEC2h],al CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: DRIVER_FAULT_SERVER_MINIDUMP BUGCHECK_STR: 0xD1 PROCESS_NAME: Idle LAST_CONTROL_TRANSFER: from 8083ffb5 to ba638405 STACK_TEXT: WARNING: Stack unwind information not available. Following frames may be wrong. 808a33f0 8083ffb5 00000000 00000000 87fa2008 msiscsi+0x4405 808a3420 ba35fb41 87d28170 87c76710 89055ad8 nt!IopfCompleteRequest+0xcd 808a3438 ba369627 8859cab0 00000000 00000030 tcpip!TCPDataRequestComplete+0xa6 808a345c ba36276a 00000000 89055a70 00000000 tcpip!TCPSendComplete+0x151 808a3494 ba36161b 890d8658 009b5c18 00000000 tcpip!IPSendComplete+0x126 808a34b8 b9488b3f 8906a008 879b5c18 00000000 tcpip!ARPSendComplete+0x108 808a3500 ba91f996 89972ab0 879b5c18 00000000 tm_cfw+0x6b3f 808a3518 ba91ffa8 808a3538 879b5c18 00000000 e1000325+0x996 808a3530 ba924ece 89a09e78 879b5c18 00000000 e1000325+0xfa8 808a3554 ba9245c7 89442008 879b5c18 808a3580 e1000325+0x5ece 808a3588 ba91f56a 00442008 f7235466 89a09e78 e1000325+0x55c7 808a35a8 8083d99a 89442394 89442380 00000000 e1000325+0x56a 808a3600 80839b2f 00000000 0000000e 00000000 nt!KiRetireDpcList+0xca 808a3604 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x37 STACK_COMMAND: kb FOLLOWUP_IP: msiscsi+4405 ba638405 10803e010f85 adc byte ptr [eax-7AF0FEC2h],al SYMBOL_STACK_INDEX: 0 FOLLOWUP_NAME: MachineOwner MODULE_NAME: msiscsi IMAGE_NAME: msiscsi.sys DEBUG_FLR_IMAGE_TIMESTAMP: 41939183 SYMBOL_NAME: msiscsi+4405 FAILURE_BUCKET_ID: 0xD1_W_msiscsi+4405 BUCKET_ID: 0xD1_W_msiscsi+4405 Followup: MachineOwner /greigutt Endret 7. november 2007 av greigutt Lenke til kommentar
Fritz0r Skrevet 8. oktober 2007 Del Skrevet 8. oktober 2007 DRIVER_IRQL_NOT_LESS_OR_EQUAL Denne tyder på BIOS/driver feil Oppdater BIOS (Reinstaller om du allerede har siste) Oppdater samtlige drivere, Chipset, lydkort, skjermkort, osv. Lenke til kommentar
lohelle Skrevet 8. oktober 2007 Del Skrevet 8. oktober 2007 Ser at det er iscsi initiator tjenesten som svikter i dette tilfellet (msiscsi.sys).. Bruker dere Iscsi (sentral lagring) ? Eller er det andre systemfiler den svikter på andre ganger? Om det er samme filen som svikter hver gang, prøv å stenge ned denne tjenesten (ev. avinstallere ms iscsi initiatoren) Kan det være en ressurskonflikt? (nic eller eventuell iscsi hba) DRIVER_IRQL_NOT_LESS_OR_EQUAL pleier å være ustabile drivere eller maskinvare.. (minnebrikker??) Lenke til kommentar
greigutt Skrevet 8. oktober 2007 Forfatter Del Skrevet 8. oktober 2007 Bruker iscsi ja... Jeg ser at msiscsi.sys er gammel (Type år 2004), men har en identisk server med samme oppsett som ikke sliter.... Jeg har lyst til å reinstallere iscsi initiatoren ja, men tør ikke da jeg ikke har passord til iscsikabinettet... Når er det egentligl man trenger dette? Jeg skal sjekke flere .dmp-filer imorgen, for å se om det er samme hver gang, kom aldri så langt idag... Jeg tipper også det er driverproblemer, må bare finne ut hvilke (er jo nærliggende å tro det er msiscsi, men siden den andre serveren kjører greit så blir jeg i tvil) Bare å komme med flere innspill eller spørsmål /greigutt Lenke til kommentar
greigutt Skrevet 17. oktober 2007 Forfatter Del Skrevet 17. oktober 2007 Hei igjen. Har nå oppdatert server med IBMs nyeste Update Xpress (drivere, firmware og bios), har fått to ulike stop errors etter dette, men begge er DRIVER_IRQL_NOT_LESS_OR_EQUAL, så jeg vil tro det er drivere, minne eller disk. Kjører IBMs diagnoseverktøy nå, og memtest86 står for tur. Tenkte bare jeg skulle oppdatere tråden på hva jeg har gjort. Det er bare å komme med innspill! /greigutt Lenke til kommentar
greigutt Skrevet 7. november 2007 Forfatter Del Skrevet 7. november 2007 Man lærer så lenge man lever, jeg kjørte diagnose av de ørten siste bsodene, og veldig mange av de gikk på tcpip og noen trend.sys-filer. Oppdaterte nettverkskortdriverne og fjerna antivirus, nå har serveren 2 uker oppetid motfor 2-3 dager tidligere.... I tillegg gikk backup cånn ca akkurat dobbelt så fort uten antivirus..... Lenke til kommentar
