Sinna'gurk Skrevet 25. oktober 2010 Rapporter Del Skrevet 25. oktober 2010 Kontrast hva snakker du om? er ikke Sheldon like deilig? Alvor: hvis produsentene satser på at Shamy skal bli en cliffhanger eller noe til neste sesong slutter jeg å følge med tror jeg. Lenke til kommentar
MartinF Skrevet 26. oktober 2010 Rapporter Del Skrevet 26. oktober 2010 Fikk plutselig lyst til å se piloten igjen. Noen utrolig morsomme sitater fra den episoden: Penny: Four years I lived with him! Four years, I mean that's like as long as high school! Sheldon: It took you FOUR YEARS to get through high school! Penny: So, what do you guys do for fun around here? Sheldon: Well, today we tried masturbating for money. Wolowitz: This is unbelievable! It's the 1974 Scientific lecture delivered by Stephen Hawking! Leonard: This is not really a good time. Wolowitz: [talking like a computer] "It's befooore he talked in a computer voooice!" Sheldon: That's where I sit. Penny: What's the difference? Sheldon: What's the difference? In the winter that seat is close enough to the radiator to remain warm, and yet not so close as to cause perspiration. In the summer, it's directly in the path of a cross-breeze created by opening windows there and there. It faces the television at an angle that is neither direct, thus discouraging conversation, nor so far wide as to create a parallax distortion. I could go on, but I think I've made my point. Wolowitz: Enchanté, mademoiselle. Howard Walowitz, Cal tech department of applied physics, you may be familiar with some of my work, it's currently orbiting Jupiter's largest moon taking high resolution digital photographs...? Penny: Penny... I work at the cheesecake factory Og dette er bare fra en episode :O 3 Lenke til kommentar
vikingkylling Skrevet 27. oktober 2010 Rapporter Del Skrevet 27. oktober 2010 Kontrast hva snakker du om? er ikke Sheldon like deilig? Alvor: hvis produsentene satser på at Shamy skal bli en cliffhanger eller noe til neste sesong slutter jeg å følge med tror jeg. Enig, med mindre Sheldon blir gravid. Lenke til kommentar
Olum Skrevet 27. oktober 2010 Rapporter Del Skrevet 27. oktober 2010 Om Sheldon blir gravid kommet i hvertfall jeg til å fortsette å følge med Lenke til kommentar
Blåbær Skrevet 27. oktober 2010 Rapporter Del Skrevet 27. oktober 2010 Jupp, Sheldon blir nok gravid. Lenke til kommentar
vikingkylling Skrevet 27. oktober 2010 Rapporter Del Skrevet 27. oktober 2010 I en vanlig serie ville det ikke skjedd, men vi snakker jo om Sheldon. Han og Amy har jo vurdert å få barn i et laboratorium, så det er ikke så merkelig om Sheldon tar på seg ansvaret. Aner ikke hvordan det skal være mulig, men de finner nok på noe. Da kan de i tillegg fjerne Amy for godt. Lenke til kommentar
Suburbian Hero Skrevet 27. oktober 2010 Rapporter Del Skrevet 27. oktober 2010 (endret) Det er jo mulig for menn å bli gravide, husker at det var en nyhetssak om den første gravide mannen for et par måneder siden. Sheldon som pappa kunne ha vært genialt. Endret 27. oktober 2010 av WCH Lenke til kommentar
Teipball Skrevet 27. oktober 2010 Rapporter Del Skrevet 27. oktober 2010 Nå var det en dame som hadde blitt mann, så en helt vanlig mann var det ikke. Lenke til kommentar
Tok3n Skrevet 29. oktober 2010 Rapporter Del Skrevet 29. oktober 2010 En helt grei episoden, fremdeles ikke noe Penny. Tror det hadde vært morsomt og se hva slags rolle Penny hadde fått i denne episoden hvis hun ikke hadde blitt skrevet ut. Lenke til kommentar
Christoffero89 Skrevet 29. oktober 2010 Rapporter Del Skrevet 29. oktober 2010 hvilken episode er vi oppe i nå? Lenke til kommentar
Thommesen Skrevet 29. oktober 2010 Rapporter Del Skrevet 29. oktober 2010 Duuude, Epguides. (Takk til Hille for en smart ep-løsning). Markert er alle episodene som du kan laste ned gitt dag. Veldig smart faktisk. Lenke til kommentar
Suburbian Hero Skrevet 29. oktober 2010 Rapporter Del Skrevet 29. oktober 2010 Siste scenen i dagens episode, den når Sheldon putter insekter i maten til Leonard anbefaler jeg ikke å se med mat/drikke i munnen. Klarte å sprute vann utover hele skjermen, pga dette var både ekkelt og morsomt samtidig. Ellers var dette en bra episode, og Leonard gjorde det bedre enn vanlig. Fremdeles irriterende at de ikke nevner Penny. Lenke til kommentar
b-real Skrevet 29. oktober 2010 Rapporter Del Skrevet 29. oktober 2010 Herregud, Penny ditt og Penny datt. Klager dere like mye når f.eks Family Guy har en episode der Stewie ikke er med? Lenke til kommentar
Blåbær Skrevet 29. oktober 2010 Rapporter Del Skrevet 29. oktober 2010 Siste scenen i dagens episode, den når Sheldon putter insekter i maten til Leonard anbefaler jeg ikke å se med mat/drikke i munnen. Klarte å sprute vann utover hele skjermen, pga dette var både ekkelt og morsomt samtidig. Ellers var dette en bra episode, og Leonard gjorde det bedre enn vanlig. Fremdeles irriterende at de ikke nevner Penny. Ro deg ned kompis, du spiser slikt hver dag. http://en.wikipedia.org/wiki/Carmine Lenke til kommentar
Khaffner Skrevet 30. oktober 2010 Rapporter Del Skrevet 30. oktober 2010 YOU USED MY TOOTHBRUSH?!?! Lenke til kommentar
vikingkylling Skrevet 30. oktober 2010 Rapporter Del Skrevet 30. oktober 2010 Siste scenen i dagens episode, den når Sheldon putter insekter i maten til Leonard anbefaler jeg ikke å se med mat/drikke i munnen. Klarte å sprute vann utover hele skjermen, pga dette var både ekkelt og morsomt samtidig. Ellers var dette en bra episode, og Leonard gjorde det bedre enn vanlig. Fremdeles irriterende at de ikke nevner Penny. Så du regnet ikke med at han ville gjøre det igjen? Jeg syntes det ble svært forutsigbart. Resten av episoden var grei nok, på grensen til kjedelig. Ikke gav den noe mening heller. Både Leonard og Raj har had sex med søstra til Sheldon uten at det ble nevnt engang, men at Leonard hadde sex med søstra til Raj var stor nok sak til å basere hele episoden på det? Og alle vet jo at Sheldon ikke kan holde på en hemmelighet. Det er ikke akkurat første gang han prøver og feiler totalt. Strengt tatt nådde serien toppen med robot-Sheldon, men etter det har det vært ganskje kjedelig. Det er fortsatt TBBT, så jeg vil fortsette å se en stund til. Men f.eks South Park, Futurama og Simpsons var svært bra is tarten, men ble kjedeligere og kjedeligere etterhvert. Seinfeld og That 70's Show klarte å holde kvaliteten opp til siste slutt (mer eller mindre), men de er unntakene. Det ser ut som om TBBT kan være en fallende stjerne allerede. Lenke til kommentar
Kakeshoma Skrevet 30. oktober 2010 Rapporter Del Skrevet 30. oktober 2010 Grei episode.. Er bedre når Penny er med Lenke til kommentar
evenandreas Skrevet 30. oktober 2010 Rapporter Del Skrevet 30. oktober 2010 Er Penny skrevet ut av serien? :O Lenke til kommentar
Kakeshoma Skrevet 30. oktober 2010 Rapporter Del Skrevet 30. oktober 2010 Nei, hun brakk beinet... Kommer snart sikkert Lenke til kommentar
evenandreas Skrevet 30. oktober 2010 Rapporter Del Skrevet 30. oktober 2010 Penny eller skuespilleren? Lurer på om jeg har hoppet over en episode.. Lenke til kommentar
