Ønsker div info om Mitsubishi Eclipse
MaSo
1st Generation (1990-1994)
Eclipse: Base FWD model equipped with a 92 hp naturally-aspirated engine 1.8 L 8-valve SOHC 4G37 engine
Eclipse GS: Upgraded FWD model with slightly more equipment
Eclipse GS DOHC: Upgraded FWD model equipped with a 136 hp naturally-aspirated 2.0 L 16-valve DOHC 4G63 non-turbo engine
Eclipse GS-T: Top FWD model equipped with a 180-195 hp turbocharged 2.0 L 16-valve DOHC 4G63T engine
Eclipse GSX: AWD model equipped with a 180-195 hp turbocharged 2.0 L 16-valve DOHC 4G63T engine
2nd Generation (1995-1999)
Eclipse: Base FWD model equipped with a 140 hp 2.0 L 16-valve DOHC Chrysler 420A engine
Eclipse RS: Equipment Upgraded FWD model equipped with a 140 hp 2.0 L 16-valve DOHC Chrysler 420A engine
Eclipse GS: Equipment upgraded FWD model equipped with a 140 hp 2.0 L 16-valve DOHC Chrysler 420A engine
Eclipse GS Spyder: Convertible FWD model equipped with a 141 hp 2.4L 16-valve SOHC Mitsubishi 4G64 engine
Eclipse GS-T: Hardtop FWD model equipped with a 210 hp turbocharged 2.0 L 16-valve DOHC Mitsubishi 4G63 engine
Eclipse GS-T Spyder: Convertible FWD model equipped with a 210 hp turbocharged 2.0 L 16-valve DOHC Mitsubishi 4G63 engine
Eclipse GSX: AWD model equipped with a 210 hp turbocharged 2.0 L 16-valve DOHC Mitsubishi 4G63 engine
3rd Generation (2000-2005)
Eclipse RS & GS: Base model equipped with a 150 hp 2.4 L 16-valve SOHC Mitsubishi 4G64 engine
Eclipse GS Spyder: Convertible FWD model equipped with a 150 hp 2.4 L 16-valve SOHC Mitsubishi 4G64 engine
Eclipse GT: Hardtop FWD model equipped with a 200 hp (205 hp federal spec 2000-2001 only) 3.0 L 24-valve SOHC Mitsubishi 6G72 engine
Eclipse GT Spyder: convertible FWD model equipped with a 200 hp (205 hp federal spec 2000-2001 only) 3.0 L 24-valve SOHC Mitsubishi 6G72 engine
Eclipse GTS: Hardtop FWD model equipped with a 210 hp 3.0 L 24-valve SOHC Mitsubishi 6G72 engine with Mitsubishi Variable Induction Management (MVIM)
Eclipse GTS Spyder: convertible FWD model equipped with a 210 hp 3.0 L 24-valve SOHC Mitsubishi 6G72 engine with MVIM
4th Generation (2006-)
Eclipse GS: Base FWD model equipped with a 162 hp 2.4 L 16-valve SOHC Mitsubishi 4G69 engine
Eclipse GS Spyder: Convertible FWD model equipped with a 162 hp 2.4 L 16-valve SOHC Mitsubishi 4G69 engine
Eclipse GT: Hardtop FWD model equipped with a 263 hp 3.8 L 24-valve SOHC Mitsubishi 6G75 engine
Eclipse GT Spyder: Convertible FWD model equipped with a 260 hp 3.8 L 24-valve SOHC Mitsubishi 6G75 engine
Kilde
edit10: puh, ferdig^^
Endret av PepsiCo
  • 3 uker senere...
Mitsubishi GSX:
http://www.garaget.org/video/82wphxzoaqoq
er ikke mange av de i norge så mulig man må importere selv ifra f.eks sverige
http://youtube.com/watch?v=RCqCyzx12BA
http://youtube.com/watch?v=v5WkurWswg8
http://www.garaget.org/video/ola3ik3ffper
http://youtube.com/watch?v=s1ZWJjC648I
http://youtube.com/watch?v=Yzjr19F5nHE
F.eks en standar subaru wrx undersyrer mye mere enn mistsubishi, og audi rs4\s4 og rs6 er trege i forhold på bane pga litt dårlig 4wd og understyrer også mye mere.
Er så genialt det 4wd systemet til mistubshi bilen min er så ekstrem morsom å kjøre på grus og glatt føre. :thumbup:
3 og 4 gen er amerikans, mens 1 og 2 er japansk\euro og er den gromme varianten
Endret av freddy85
Så med andre ord er 1.- og 2.-generasjons GSX de eneste som virkelig er verdt å ha. Om du har planer på å lage noe skikkelig heftige saker ut av den. FWD går jo greit den og, men det er begrenset med hva du kan gjøre. Alle VTEC-monstrene til Honda er vel FWD, så det er ikke ubrukelig.
Jeg har -92 modellen av eclipse og er veldig fornøyd.
Kan ikke så masse om bil, men den går veldig godt og er sinnsyk god å kjøre =)
Har 2.0 literen på 150 hester, drar veldig godt og gearkassa er så evig elsk :thumbup:
Eneste minuset er at hele bilen er såå evig lav, høyde over bakken, taket, og front.
Og bakseteplassen er heller ikke å skryte av, du får knapt to dvergeskimoer inn :ermm:
Men veldig bra bil vel og merke =)
