NVIDIA 780i chipsett
Uglegutt
Beklager for at jeg var litt uspesifikk, men svarte på: "Blir vel støtte for DDR3 og 45nm der?".
Husker ikke om det er 780i eller 790i som har DDR3, men det er enten begge, eller 790i.
Skal finne det ut :)
EDIT: DDR2 er veldig bra det også.
780i klokker dårlig. Foreløpig hvertfall.
EDIT2: Ser ut til at 780i kommer med noen HK som støtter DDR2, og noen som støtter DDR3.
780i kommer den 17 Desember.
Endret av Intern
Blir litt spennende og se hvordan 780i klokker med Quad.
Har ikke helt trua, da 780i bare er et 680i chipsett med pci-x kontroller i tillegg :dontgetit:
http://www.fudzilla.com/index.php?option=c...5&Itemid=37
Hvor kom pci-x inne i bildet? Er du sikker på at du ikkje mener pci-e(xpress)?
Han mener nok PCI-E ja, siden 780i er en revidert utgave av 680i med en PCI-E 2.0-kontroller i tillegg.
XFX has just announced Nforce 780i SLI motherboard. The new motherboard will support triple SLI with three PCI Express 2.0 slots.
XFX's Nforce 780i SLI motherboard will use the new NV Monitor which includes full overclocking for Intel's Yorkfield and Wolfdale CPUs. It will include Nvidia's Firstpacket, Dualnet and Mediashield technologies. The new XFX 780i SLI will also feature support for up to 1200MHz DDR2 memory, six SATA drives, ten USB ports and FSB of up to 1333MHz.
Interesting fact is that this will be a first motherboard that will include ESA or Enthusiast System Architecture, the same one that Nvidia is preaching about for last few months. The plan is to allow users to integrate different ESA components into one platform, so they can have greater real-time system control.
Kilde.
Edit:
We wont tell you much details but we will tell that MSI has finished the development of its two Nforce 780i motherboard. The first one will be know as P7N Diamond while the second one is named P7N Platinum.
MSI has some unique features and did a lot to a reference design of the board but the most important, 780i works with Yorkfield quad cores has PCIe 2.0 support and it works with Tri SLI.
This is how it look.
Kilde.
Endret av Sindre Aleksander
