Må man recorde på tex når vi skal spille i Compoer
daxie
Må man recorde på tex når vi skal spille i Compoer??
- Jeg lurer på det fordi jeg spiller dårlig når man recorder pga fps dropp..
Men det skulle jo ikke være unøvendig og recorde når det er folk som ser på, eller?
Takk for svar, JOA
Players are not allowed to open any configuration files manually for any reason
or to have console enabled. It is the players responsibility to check that their
console is not enabled prior to playing. If the console is found to be enabled
after a match has commenced, that player will be removed from the tournament and
a forfeit loss issued. Any player caught with any configuration file opened up
manually will be immediately removed from the tournament area.
Det er fra rules i cs 1.6
