Arnold3 Skrevet 30. september 2007 Del Skrevet 30. september 2007 Prøvde å lage en meny etter en oppskrift herfra Meny Tut Får bare opp en blank skjerm ingen feilmeldinger.... hva er galt? <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <?php $sqlConn = mysql_connect("localhost", "root", "") or die("Couldn't connect to database"); $dbConn = mysql_select_db("webshop", $sqlConn) or die("Couldn't connect to database"); $sql = "select * from Nodes where parentID = 0 order by title asc"; $nodeResult = mysql_query($sql) or die("SELECT query failed"); $counter = 0; ?> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <title> Dynamic Menus </title> <style> .root_td { background-color: #000000; color: #FFCF00; font-family: Verdana; font-size: 8pt; font-weight: bold; height: 22; padding-left: 5; } .child_td { background-color: #D1D1D1; color: #000000; font-family: Verdana; font-size: 8pt; font-weight: bold; text-decoration: underline; height: 22; padding-left: 10; padding-right: 10; padding-bottom: 3; } body { color: #000000; font-family: Verdana; font-size: 8pt; font-weight: normal; } a { color: #000000; } </style> <script language="JavaScript"> function ToggleNode(nodeObject, imgObject) { if(nodeObject.style.display == '' || nodeObject.style.display == 'inline') { nodeObject.style.display = 'none'; imgObject.src = 'plus.gif'; } else { nodeObject.style.display = 'inline'; imgObject.src = 'minus.gif'; } } </script> <body> <body bgcolor="#FFFFFF"> <table width="250" border="0" cellspacing="0" cellpadding="0"> <?php while($node = mysql_fetch_array($nodeResult)) { ?> <tr> <td class="root_td"> <img id="img_root_<?php echo $counter; ?>" onClick="ToggleNode(td_root_<?php echo $counter; ?>, img_root_<?php echo $counter; ?>)" border="0" src="minus.gif" style="cursor:hand"> <?php echo $node[1]; ?> </td> </tr> <tr> <td id="td_root_<?php echo $counter++; ?>" class="child_td"> <table width="100%"> <?php $sql = "select * from nodes where parentId = {$node[0]} order by title asc"; @$childResult = mysql_query($sql); while($child = mysql_fetch_row($childResult)) { ?> <tr> <td class="child_td"> <a href="<?php echo $child[2]; ?>"> <?php echo $child[1]; ?> </a> </td> </tr> <?php } ?> </table> </td> </tr> <?php } ?> </table> </body> </html> Lenke til kommentar
Ståle Skrevet 30. september 2007 Del Skrevet 30. september 2007 Har du satt inn noe i databasen? Far du ikke noe kildekode heller? Lenke til kommentar
Arnold3 Skrevet 30. september 2007 Forfatter Del Skrevet 30. september 2007 Ja har laget database og lagt inn litt data. Får ikke opp noe helt blankt. Lenke til kommentar
Ståle Skrevet 30. september 2007 Del Skrevet 30. september 2007 Får ikke opp noe helt blankt. forklar litt naermere. Lenke til kommentar
Arnold3 Skrevet 30. september 2007 Forfatter Del Skrevet 30. september 2007 Er helt ny på dette så jeg skulle ønske jeg fant noe lettere script. skjønner ikke en dritt av dette. Lenke til kommentar
Arnold3 Skrevet 30. september 2007 Forfatter Del Skrevet 30. september 2007 Når jeg åpner dokumentet i Firefox etter jeg har lagret det på webserver viser den bare hvit, ikkenoe text. Lenke til kommentar
trrunde Skrevet 30. september 2007 Del Skrevet 30. september 2007 høyreklikk og velg vis kilde, er den også blank? Lenke til kommentar
Arnold3 Skrevet 30. september 2007 Forfatter Del Skrevet 30. september 2007 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <title> Dynamic Menus </title> <style> .root_td { background-color: #000000; color: #FFCF00; font-family: Verdana; font-size: 8pt; font-weight: bold; height: 22; padding-left: 5; } .child_td { background-color: #D1D1D1; color: #000000; font-family: Verdana; font-size: 8pt; font-weight: bold; text-decoration: underline; height: 22; padding-left: 10; padding-right: 10; padding-bottom: 3; } body { color: #000000; font-family: Verdana; font-size: 8pt; font-weight: normal; } a { color: #000000; } </style> <script language="JavaScript"> function ToggleNode(nodeObject, imgObject) { if(nodeObject.style.display == '' || nodeObject.style.display == 'inline') { nodeObject.style.display = 'none'; imgObject.src = 'plus.gif'; } else { nodeObject.style.display = 'inline'; imgObject.src = 'minus.gif'; } } </script> <body> <body bgcolor="#FFFFFF"> <table width="250" border="0" cellspacing="0" cellpadding="0"> </table> </body> </html> her er kildekoden til den blanke siden Lenke til kommentar
Ståle Skrevet 30. september 2007 Del Skrevet 30. september 2007 Da ma det vaere mangel pa oppforinger i databasen skift denne linjen @$childResult = mysql_query($sql); med denne $childResult = mysql_query($sql); Lenke til kommentar
Arnold3 Skrevet 30. september 2007 Forfatter Del Skrevet 30. september 2007 her er databasen SQL result Host: localhost Database: webshop Generation Time: Sep 30, 2007 at 07:41 Generated by: phpMyAdmin 2.10.3 / MySQL 5.0.45 SQL query: SELECT * FROM `Nodes` LIMIT 0, 30 ; Rows: 9 nodeID Title url parentID 3 Sko www.google.com NULL 4 Klær http://www.google.no/ NULL 5 Sekker http://www.google.no/ NULL 7 Pensko http://www.google.no/ 3 8 Joggesko http://www.google.no/ 3 10 Bukser http://www.google.no/ 4 11 Jakker http://www.google.no/ 4 12 Ryggsekker http://www.google.no/ 5 13 Drittsekker http://www.google.no/ 5 Lenke til kommentar
Zeph Skrevet 30. september 2007 Del Skrevet 30. september 2007 Emnetittelen i denne tråden er lite beskrivende for trådens innhold og det er derfor ingen god emnetittel. Jo bedre og mer beskrivende emnetittelen er, jo lettere er det for andre å skjønne trådens innhold og det vil være lettere å treffe den riktige forumbrukeren med det rette svaret. Ber deg derfor om å endre emnetittel slik at du unngår at en moderator stenger tråden. Vennligst forsøk å ha dette i tankene neste gang du starter en tråd, og orienter deg om hva vår nettikette sier om dårlig bruk av emnetitler. Bruk -knappen i første post for å endre emnetittelen. (Dette innlegget vil bli fjernet ved endring av emnetittel. Ikke kommenter dette innlegget, men gjerne dette innlegget når tittelen er endret, så vil det bli fjernet..) Lenke til kommentar
