HELT identisk ram for å få dual channel?
Khaffner
Vi har en laptop her hjemme som skal oppgraderes litt. nå har den 256mb PC4200.
Vi skal kjøpe en 256mb'er til og vil helst ha dualchannel. må vi kjøpe en rambrikke som er identisk helt ned til merket, eller vil det virke hvis spesifikasjonene er identiske?
på den nåværende rambrikken står det:
Hynic korea 03 256MB 1Rx16 PC2-4200S-444-12
HYMP532S64BP6-C4 AB
går det greit hvis jeg kjøper en brikke med 256MB PC4200, uansett merke?
Q: Will Non-Dual Channel Matched RAM work in my nforce2 motherboard?
It most certainly, will. As long as it fits the requirements of Dual Channel operation (two of the same types of memory, same size modules, speed, etc). Two modules of the same model/brand purchased from the same vendor at the same time is essentially as likely to work properly in a dual channel configuration as is a dual channel kit.
The ONLY thing you can lose by buying "single channel" memory for use in Dual Channel mode is that manufacturers may or may not provide support and replace your memory if it won't work in dual channel mode, whereas if Dual Channel memory fails to work in Dual Channel mode, the manufacturers will help you resolve the problem and possibly replace the memory to ensure proper Dual Channel operation.
There are instances of people using two different types of RAM together and have had no problems. You can't damage your motherboard or RAM just by trying to use two un-identical module in Dual Channel mode. But be advised that if the machine is unstable for any reason, it is entirely possible to corrupt your data upon operation of the machine. Mis-matched memory sticks in a dual channel configuration often produce unstable operation, so as with any new overclocking or upgrading venture make sure you have adequate backups so you can recover from a data loss.
Kilde: http://www.dslreports.com/faq/9231
I teorien kreves det like brikker fordi produsentene ikke vil risikere å si noe som kan føre til inkompatibilitet og sure kunder. I praksis vil det ofte, men ikke alltid, gå fint å kombinere brikker som er teknisk like. (type, hastighet, og likt antall fysiske brikker på modulen). Jeg vil anslå en suksessrate på 80% for de som prøver.
Ellers så synes jeg i likhet med Bjørn Roger at det var litt lite med 2*256MB og ville nok satset på en del mer når du først er i gang med å oppgradere maskina og ram er så billig som det er nå. DDR2 SODIMM 512MB-brikker går ofte billig unna på bruktmarkedet (under 100kr pr stk), mens 1GB sjeldnere er på bruktmarkedet. Nye koster derimot fra drøye 200 kr. DDR SODIMM er mye dyrere. Der får man bare 512MB for 200 kr.
Så konklusjonen er at jeg kan bruke 2 teknisk identiske brikker, fra forskjellige produsenter?
9592025[/snapback]
samme produsent og merke må brukes.
Har testet med forskjellige brikker fra ulike produsenter OG:: Blåskjerm og diverse restarter og heng som resultat, MEN det kan kansje virke..:-)
