kfc001 Skrevet 25. september 2007 Del Skrevet 25. september 2007 Hei jeg har problemer med at min PC ikke yter det den kan yte, her er litt info om min PC, problemet jeg har er at naar jeg spiller spill bruker min CPU bare 20-40% av det den kan i folge windows task manager (process) og rundt 60% av rammen. Dette gjor at alle spill lagger mye, eks wow,anarchy online og flere MMORPG Hva bor jeg kjope nytt eller fikse for og faa bedre FPS, og hvorfor yter den ikke 100% som min andre AMD 3000 PC gjor. Kan det vare att det innebygde grafikk kortet er daarlig? ------------------ System Information ------------------ Time of this report: 8/20/2007, 16:41:46 Machine name: TEST_TEST Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_qfe.070227-2300) Language: English (Regional Setting: Thai) System Manufacturer: To Be Filled By O.E.M. System Model: To Be Filled By O.E.M. BIOS: Default System BIOS Processor: Intel® Pentium® 4 CPU 3.20GHz (2 CPUs) Memory: 478MB RAM Page File: 303MB used, 1122MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.2180 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Sound Tab 1: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: Intel® 82865G Graphics Controller Manufacturer: Intel Corporation Chip type: Intel® 82865G Graphics Controller DAC type: Internal Device Key: Enum\PCI\VEN_8086&DEV_2572&SUBSYS_25721849&REV_02 Display Memory: 96.0 MB Current Mode: 1024 x 768 (32 bit) (85Hz) Monitor: Plug and Play Monitor Monitor Max Res: 1600,1200 Driver Name: ialmrnt5.dll Driver Version: 6.14.0010.4396 (English) DDI Version: 9 (or higher) Driver Attributes: Final Retail Driver Date/Size: 9/19/2005 20:52:38, 36990 bytes WHQL Logo'd: Yes WHQL Date Stamp: n/a VDD: n/a Mini VDD: ialmnt5.sys Mini VDD Date: 9/19/2005 15:00:54, 1302332 bytes Device Identifier: {D7B78E66-6632-11CF-D56A-7805A3C2CB35} Vendor ID: 0x8086 Device ID: 0x2572 SubSys ID: 0x25721849 Revision ID: 0x0002 Revision ID: 0x0002 Video Accel: Deinterlace Caps: n/a Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Not Available DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run ------------- Sound Devices ------------- Description: C-Media Wave Device Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: PCI\VEN_8086&DEV_24D5&SUBSYS_97611849&REV_02 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: cmuda.sys Driver Version: 5.12.0001.0049 (English) Driver Attributes: Final Debug WHQL Logo'd: Yes Date and Size: 5/11/2005 18:21:08, 1332544 bytes Other Files: Driver Provider: C-Media Inc. HW Accel Level: Full Cap Flags: 0xF5F Min/Max Sample Rate: 100, 100000 Static/Strm HW Mix Bufs: 33, 32 Static/Strm HW 3D Bufs: 33, 32 HW Memory: 0 Voice Management: No EAX 2.0 Listen/Src: Yes, Yes I3DL2 Listen/Src: Yes, Yes Sensaura ZoomFX: Yes Registry: OK Sound Test Result: Not run --------------------- Sound Capture Devices --------------------- Description: C-Media Wave Device Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: cmuda.sys Driver Version: 5.12.0001.0049 (English) Driver Attributes: Final Debug Date and Size: 5/11/2005 18:21:08, 1332544 bytes Cap Flags: 0x41 Format Flags: 0xCC0 ----------- DirectMusic ----------- DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS DLS Version: 1.00.0016.0002 Acceleration: n/a Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port C-Media Wave Device, Software (Kernel Mode), Output, DLS, Internal Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal Registry: OK Test Result: Not run ------------------- DirectInput Devices ------------------- Device Name: Mouse Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: USB Keyboard Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x0A81, 0x0101 FF Driver: n/a Device Name: USB Keyboard Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x0A81, 0x0101 FF Driver: n/a Poll w/ Interrupt: No Registry: OK ----------- USB Devices ----------- + USB Root Hub | Vendor/Product ID: 0x8086, 0x24D7 | Matching Device ID: usb\root_hub | Service: usbhub | Driver: usbhub.sys, 9/16/2004 16:06:46, 57856 bytes | Driver: usbd.sys, 8/22/2001 23:00:00, 4736 bytes ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ + HID Keyboard Device | Vendor/Product ID: 0x0A81, 0x0101 | Matching Device ID: hid_device_system_keyboard | Service: kbdhid | Driver: kbdhid.sys, 8/3/2004 22:58:36, 14848 bytes | Driver: kbdclass.sys, 8/3/2004 07:58:34, 24576 bytes | + Terminal Server Keyboard Driver | Matching Device ID: root\rdp_kbd | Upper Filters: kbdclass | Service: TermDD | Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes | Driver: kbdclass.sys, 8/3/2004 07:58:34, 24576 bytes | + HID-compliant mouse | Vendor/Product ID: 0x04F3, 0x0210 | Matching Device ID: hid_device_system_mouse | Service: mouhid | Driver: mouclass.sys, 2/7/2006 12:57:53, 23040 bytes | Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes | + Terminal Server Mouse Driver | Matching Device ID: root\rdp_mou | Upper Filters: mouclass | Service: TermDD | Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes | Driver: mouclass.sys, 2/7/2006 12:57:53, 23040 bytes ---------------------------- DirectPlay Service Providers ---------------------------- DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180) IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180) Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180) Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180) DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run DirectPlay Test Result: Not run Registry: OK ------------------- DirectPlay Adapters ------------------- DirectPlay8 Modem Service Provider: Communications cable between two computers DirectPlay8 Serial Service Provider: COM1 DirectPlay8 IPX Service Provider: IPX Adapter 1 - (00000000,0019660B0E4E) DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 - ----------------------- DirectPlay Voice Codecs ----------------------- Voxware VR12 1.4kbit/s Voxware SC06 6.4kbit/s Voxware SC03 3.2kbit/s MS-PCM 64 kbit/s MS-ADPCM 32.8 kbit/s Microsoft GSM 6.10 13 kbit/s TrueSpeech 8.6 kbit/s ------------------------- DirectPlay Lobbyable Apps ------------------------- ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 3.2 GB Total Space: 38.2 GB File System: NTFS Model: ST380815AS Drive: D: Free Space: 37.1 GB Total Space: 38.2 GB File System: NTFS Model: ST380815AS Drive: E: Model: LITE-ON COMBO SOHC-5236V Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Thai), 8/3/2004 07:59:54, 49536 bytes Lenke til kommentar
Mompen Skrevet 25. september 2007 Del Skrevet 25. september 2007 Er nok dessverre det innebygde grafikkortet kombinert med lite ram som gjør at du får dårlig ytelse.. Evt om du hadde kjøpt 512mb ram til, helst et eget skjermkort om det er mulig. Trenger ikke koste mer enn en tusenlapp til sammen for at du skal ha en grei pc som kan dra de spillene der Lenke til kommentar
chrisdvx Skrevet 25. september 2007 Del Skrevet 25. september 2007 Hei jeg har problemer med at min PC ikke yter det den kan yte, her er litt info om min PC, problemet jeg har er at naar jeg spiller spill bruker min CPU bare 20-40% av det den kan i folge windows task manager (process) og rundt 60% av rammen. Dette gjor at alle spill lagger mye, eks wow,anarchy online og flere MMORPG Hva bor jeg kjope nytt eller fikse for og faa bedre FPS, og hvorfor yter den ikke 100% som min andre AMD 3000 PC gjor. Kan det vare att det innebygde grafikk kortet er daarlig? ------------------ System Information ------------------ Time of this report: 8/20/2007, 16:41:46 Machine name: TEST_TEST Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_qfe.070227-2300) Language: English (Regional Setting: Thai) System Manufacturer: To Be Filled By O.E.M. System Model: To Be Filled By O.E.M. BIOS: Default System BIOS Processor: Intel® Pentium® 4 CPU 3.20GHz (2 CPUs) Memory: 478MB RAM Page File: 303MB used, 1122MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.2180 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Sound Tab 1: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: Intel® 82865G Graphics Controller Manufacturer: Intel Corporation Chip type: Intel® 82865G Graphics Controller DAC type: Internal Device Key: Enum\PCI\VEN_8086&DEV_2572&SUBSYS_25721849&REV_02 Display Memory: 96.0 MB Current Mode: 1024 x 768 (32 bit) (85Hz) Monitor: Plug and Play Monitor Monitor Max Res: 1600,1200 Driver Name: ialmrnt5.dll Driver Version: 6.14.0010.4396 (English) DDI Version: 9 (or higher) Driver Attributes: Final Retail Driver Date/Size: 9/19/2005 20:52:38, 36990 bytes WHQL Logo'd: Yes WHQL Date Stamp: n/a VDD: n/a Mini VDD: ialmnt5.sys Mini VDD Date: 9/19/2005 15:00:54, 1302332 bytes Device Identifier: {D7B78E66-6632-11CF-D56A-7805A3C2CB35} Vendor ID: 0x8086 Device ID: 0x2572 SubSys ID: 0x25721849 Revision ID: 0x0002 Revision ID: 0x0002 Video Accel: Deinterlace Caps: n/a Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Not Available DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run ------------- Sound Devices ------------- Description: C-Media Wave Device Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: PCI\VEN_8086&DEV_24D5&SUBSYS_97611849&REV_02 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: cmuda.sys Driver Version: 5.12.0001.0049 (English) Driver Attributes: Final Debug WHQL Logo'd: Yes Date and Size: 5/11/2005 18:21:08, 1332544 bytes Other Files: Driver Provider: C-Media Inc. HW Accel Level: Full Cap Flags: 0xF5F Min/Max Sample Rate: 100, 100000 Static/Strm HW Mix Bufs: 33, 32 Static/Strm HW 3D Bufs: 33, 32 HW Memory: 0 Voice Management: No EAX 2.0 Listen/Src: Yes, Yes I3DL2 Listen/Src: Yes, Yes Sensaura ZoomFX: Yes Registry: OK Sound Test Result: Not run --------------------- Sound Capture Devices --------------------- Description: C-Media Wave Device Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: cmuda.sys Driver Version: 5.12.0001.0049 (English) Driver Attributes: Final Debug Date and Size: 5/11/2005 18:21:08, 1332544 bytes Cap Flags: 0x41 Format Flags: 0xCC0 ----------- DirectMusic ----------- DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS DLS Version: 1.00.0016.0002 Acceleration: n/a Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port C-Media Wave Device, Software (Kernel Mode), Output, DLS, Internal Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal Registry: OK Test Result: Not run ------------------- DirectInput Devices ------------------- Device Name: Mouse Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: USB Keyboard Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x0A81, 0x0101 FF Driver: n/a Device Name: USB Keyboard Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x0A81, 0x0101 FF Driver: n/a Poll w/ Interrupt: No Registry: OK ----------- USB Devices ----------- + USB Root Hub | Vendor/Product ID: 0x8086, 0x24D7 | Matching Device ID: usb\root_hub | Service: usbhub | Driver: usbhub.sys, 9/16/2004 16:06:46, 57856 bytes | Driver: usbd.sys, 8/22/2001 23:00:00, 4736 bytes ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ + HID Keyboard Device | Vendor/Product ID: 0x0A81, 0x0101 | Matching Device ID: hid_device_system_keyboard | Service: kbdhid | Driver: kbdhid.sys, 8/3/2004 22:58:36, 14848 bytes | Driver: kbdclass.sys, 8/3/2004 07:58:34, 24576 bytes | + Terminal Server Keyboard Driver | Matching Device ID: root\rdp_kbd | Upper Filters: kbdclass | Service: TermDD | Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes | Driver: kbdclass.sys, 8/3/2004 07:58:34, 24576 bytes | + HID-compliant mouse | Vendor/Product ID: 0x04F3, 0x0210 | Matching Device ID: hid_device_system_mouse | Service: mouhid | Driver: mouclass.sys, 2/7/2006 12:57:53, 23040 bytes | Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes | + Terminal Server Mouse Driver | Matching Device ID: root\rdp_mou | Upper Filters: mouclass | Service: TermDD | Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes | Driver: mouclass.sys, 2/7/2006 12:57:53, 23040 bytes ---------------------------- DirectPlay Service Providers ---------------------------- DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180) IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180) Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180) Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180) DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run DirectPlay Test Result: Not run Registry: OK ------------------- DirectPlay Adapters ------------------- DirectPlay8 Modem Service Provider: Communications cable between two computers DirectPlay8 Serial Service Provider: COM1 DirectPlay8 IPX Service Provider: IPX Adapter 1 - (00000000,0019660B0E4E) DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 - ----------------------- DirectPlay Voice Codecs ----------------------- Voxware VR12 1.4kbit/s Voxware SC06 6.4kbit/s Voxware SC03 3.2kbit/s MS-PCM 64 kbit/s MS-ADPCM 32.8 kbit/s Microsoft GSM 6.10 13 kbit/s TrueSpeech 8.6 kbit/s ------------------------- DirectPlay Lobbyable Apps ------------------------- ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 3.2 GB Total Space: 38.2 GB File System: NTFS Model: ST380815AS Drive: D: Free Space: 37.1 GB Total Space: 38.2 GB File System: NTFS Model: ST380815AS Drive: E: Model: LITE-ON COMBO SOHC-5236V Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Thai), 8/3/2004 07:59:54, 49536 bytes 9569328[/snapback] Hei, før vi kan si noe om hva som gjør at disse spillene ikke virker som det skal, så snakker vi litt om Tak Manager i Windows, Det er ikke om og gjøre at dette skal ligge så nærme 100% som mulig, det er omvendt, jo mindre CPU & RAM maskinen bruker jo bedre. dvs at man har mer og gå på, du sier at når du spiller ligger maskinen din på 20-40 av CPU, dette er ok, hadde den ligget på 100% da hadde du trengt en større CPU, 60% av minne er ganske mye, så du ville nok ha nytt godt av mer minne. Men hoved problemet ditt her er skjermkortet. Så konklusjonen er: 1. Nytt skjermkort 2. Mer minne Da vil du nok oppleve at de spillene du nevner fungerer MYE bedre. Mvh Christian Lenke til kommentar
