Hvordan funger if kommandoen i bash?
      { list; }
              list is simply executed in the current shell environment.  list must be terminated with a newline or semicolon.  This is known  as  a  group
              command.  The  return  status is the exit status of list.  Note that unlike the metacharacters ( and ), { and } are reserved words and must
              occur where a reserved word is permitted to be recognized.  Since they do not cause a word break,  they  must  be  separated  from  list  by
              whitespace.
*klipp*
      if list; then list; [ elif list; then list; ] ... [ else list; ] fi
              The  if list is executed.  If its exit status is zero, the then list is executed.  Otherwise, each elif list is executed in turn, and if its
              exit status is zero, the corresponding then list is executed and the command completes.  Otherwise, the else list is executed,  if  present.
              The exit status is the exit status of the last command executed, or zero if no condition tested true.
Det vil altså si
if {true};
then
 command
elif {false}
then
 command2;
 command3
else
 command 4
fi
eller noe slikt. Jeg er ingen djevel på bash-programmering men det er slik jeg leser manualen. Det kan godt være at det skal være flere eller færre semikolon. Det er stort sett bare å prøve seg frem til du finner noe som virker.
  • 1 måned senere...
  • 4 uker senere...
