Hei, er det noen som kan hjelpe meg?
Jeg har brukt vpn veiviser i asa'n, men jeg får ikke kontakt med det lokale nettverket jeg bruker cisco client v5.0 og jeg får logget meg men der stopper det
Her er konfigen
: Saved
ASA Version 7.2(2)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxxxxxxxxxxxxxxx encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxxxxxxxxxxxxxxx encrypted
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
access-list vpn-client_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool vpn-client-pool 192.168.0.50-192.168.0.100 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
group-policy vpn-client internal
group-policy vpn-client attributes
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value vpn-client_splitTunnelAcl
username xxx1 password /xxxxxxx.xxxxxxx encrypted privilege 0
username xxx1 attributes
vpn-group-policy vpn-client
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group vpn-client type ipsec-ra
tunnel-group vpn-client general-attributes
address-pool vpn-client-pool
default-group-policy vpn-client
tunnel-group vpn-client ipsec-attributes
pre-shared-key *
telnet xxx.xxx.xxx.xxx 255.255.255.255 outside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect pptp
service-policy global_policy global
prompt hostname context
Cryptochecksum:d8726ad7b026e6755824d25e969c6bdf
: end
  • 3 måneder senere...
