Når kommer Cowon D2 8 GB og 7 16 GB til Norge?
SRD
Er det noen som vet når Cowon D2 8 GB og iAudio 7 16 GB kommer til Norge?
Ser at begge de to produktene er på forsiden til Cowonglobal.com, men under spesifikasjoner står det bare 4 GB og 8 GB.
Leste forresten her at Iaudio 7 bare har "Average audio quality" :ermm: Stemmer dette? Er det ikke samme lydchip i denne som i D2?
Så på anythingbutipod.com at D2 8 GB skal ha DMB? Hva er dette?
Her er spesifikasjoner for iAudio 7
MP3, OGG, WMA, ASF, FLAC, WAV, MPEG4(video) playback,
FM Radio Receiver and Recording, Voice Recording, Line-In Recording
TXT (Text), JPEG (Image) File Viewer (Image Enlargement, Background Screen
Designation)
Built-in Flash Memory (4G/8G)
260,000 Color 1.3 inch TFT LCD, Resolution 160x128
Long Playback Time : Up to 60 hours playback(Based on company's self-test, The playing
time may be shortened according to LCD usages.)
Multi language support
Enhanced Integrated Navigator
Play/Pause, Recording/Pause While Recording
Next Song/Previous Song, Fast Forward/Rewind, Section Repeat
Resume, Fade-In, AutoPlay Features
Search Speed, Skip Speed Setup
Volume (Digital 40 Levels)
Various EQ and Sound Field Effects
- User-Adjustable 5-Band EQ
- Normal, Rock, Pop, Jazz, Classic, Vocal, User
- Supports BBE, Mach3Bass, MP Enhance, and 3D Surround.
- JetEffect Preset
- EQ Filter
Clock, Alarm, Timer Recording, Sleep Function, Power Saving Shut down.
LCD Auto Off Time Adjustment, Brightness, and Contrast Adjustments
Easy Firmware Upgrade
Supports ID3V2, ID3V1, FileName
Product Info Display (Firmware version, Memory Capacity/Usage)
Supports MAC OS (Data transfer only), Supports Linux v 2.2 or higher (Data transfer only)
Software
-COWON MediaCenter - JetAudio
Playback
format
MP3 : MPEG 1/2/2.5 Layer 3, ~320kbps, ~48khz, mono/stereo
WMA : ~256kbps, ~48khz, mono/stereo
OGG : ~Q10, ~44.1khz, mono/stereo
FLAC : compression level 0~8, ~44.1khz, mono/stereo
WAV : ~48khz, 16bit, mono/stereo
Video File up to 168*128
JPEG, TXT
Memory
PC interface
USB 2.0 High Speed
Folder Limit
200 folders and 2,000 files
File Transfer Speed
Write : max 40Mbps, Read : max 40Mbps
Battery
Built-in Rechargeable Lithium Polymer Battery (Max. 60 Hours Continuous Playback)
Charging Time
About 3.5 hours by adapter (USB)
Buttons
Swing Touch(REC, <,>,PLAY), Power/Hold, VOL+, VOL-, MENU
Display
160 x 128 dot, 260,000 color TFT LCD
SNR
95dB (A-Weighted)
Max Output
16 Ohm earphone : 26mW + 26mW
Frequency Range
20Hz ~ 20KHz
Size
35.6 X 76.1 X 19 mm (H X W X D)
Weight
60g (Include Lithium Polymer battery)
System
Requirements
Pentium 200MHz or Higher
32MB Main Memory or more
50MB Hard Disk Space or more
256 or Higher color display
OS
- Microsoft Windows 98/98se/ME/2000/XP
- MAC OS 9.X, 10.X (Only data transfer supported)
- Linux kernel v2.2 or higher (Only data transfer supported)
USB Port
CD-ROM Drive
Og her er for iAudio D2
MP3, OGG, WMA, FLAC, WAV, APE* , Moving Picture Playback,
FM Radio Receiver and Recording, Voice Recording, Line-In Recording, USB Storage
TXT (Text), JPEG (Image) File Viewer (Image Enlargement, Background Screen Designation)
Built-in Flash Memory (2G/4G)
USB 2.0 Interface
2.5 inch 16 million color 24bit TFT-LCD - QVGA (320x240) Touch Screen support.
Long Playback Time : Music Up to 52 hours, Movie Up to 10hours continuous playback
(Based on company's self-test, the Music playing time may be shortened according to LCD backlight usages.)
Resume, Fade In
- Supports BBE, Mach3Bass, MP Enhance, 3D Surround and Stereo Enhance
Clock, Alarm, Pre-Scheduled Recording, Sleep Function, Power Saving Shut down.
LCD Auto Off Time Adjustment, Brightness Adjustments
Product Info. Display (Firmware version, Memory Capacity/Usage)
Software
- JetShell (File transfer, MP3/WMA/WAV/AUDIO CD PLAY)
- JetAudio VX (Integrated multimedia player software, music/video conversion feature)
Playback
format
FLAC : Compression Level 0 ~ 8, ~44.1khz, mono/stereo
APE* : TBD
Video File up to 320x240(QVGA), 30fps
JPG, TXT
Folder Limit
500 folders and 5,000 files
RADIO support
FM RADIO : 76Mhz ~ 108Mhz, 87.5Mhz ~ 108Mhz
WMA : 32~256kbps recording support
Display
2.5 inch 16 million color(24bit) TFT-LCD : QVGA (320x240) Touch Screen support.
Built-in memory
2GB, 4GB
External
Memory (SD, MMC) Card Slot
PC interface
USB 2.0 High Speed
File transfer speed
Max. 35Mbps (Upload 40Mbps)
Power
Playback
time **
Music : Max. 52 Hours Continuous Playback
Movie : Max. 10 Hours Continuous Playback
Charge time
About 3.5 hours by adapter, About 7 hours by USB
button
3 Button(MENU, VOL-, VOL+), POWER & HOLD Switch
SNR
95dB (A-Weighted)
Frequency Range
20Hz~20KHz
Max Output
16 Ohm earphone : 37mW + 37mW
Size
78.0 X 55.4 X 16.6 mm (W x H x D)
Weight
91g (Include Lithium Polymer battery)
* APE will be supported by future firmware upgrade.
** Playback time is based on company's self-test, The music playing time may be shortened according to LCD backlight usages.
System Requirement
OS
- USB Port
- CD-ROM Drive
iaudio 7 er en flash-iaudio 6... den floppet pga ræva kontroller. dessuten er d2 også videospiller, i7 har vel en del mindre skjerm
9569977[/snapback]
Vet. Den har bare 1.3" skjerm :( .
Men hvordan er lydkvaliteten? Tenkte på en 16 GB iAudio 7 for å bare han en liten Flac-spiller. Eller er kontrollene helt håpløse? iAudio 7 støtter også video:P Men det er på 1.3" skjerm med ubrukelig oppløsning :p
cowon lyd er cowon lyd ;)
U2en og D2en min høres 99% like bra ut, og vet at det vanligvis er standarden på alt cowon
9570403[/snapback]
OK :)
Takker igjen for hjelpen Captain!
Jeg tror jeg kommer til å for en iAudio 7 16 GB, siden jeg trenger en liten spiller. Så skal jeg seinere kjøpe en Cowon med minimum 50 GB Flash minne og minimum 640 x 480 TV-out, siden jeg har en ZVM som jeg kan bruke som videospillere til da. Men skulle gjerne ha prøvd den for å sjekke hvordan knappene og menyene er på den.
Gjest Slettet+89234341
Tror nok iAudio 7 og D2 skal være ganske like lydmessig, siden alle Cowon-spillere kjører samme DAC.
9574950[/snapback]
WRONG
Det gjør de ikke. X5 kjører eks texas instrument chip, andre brukte chips i cowon spillere er eks wolfson og telechips, så det har lite med saken å gjøre :p
Har sverget aldri mer å bruke komplett etter fiaskoen som det stedet har vært og er for tiden... gidder seriøst ikk evente en måned på pakker
Nå kan jeg fortelle at jeg har en iaudio 7. DEn er nok endel mindre enn d2, så det teller en del for meg. Jeg hadde ipod tidligere, og sammenliknet med den er det et forferdelig knotete meny-og brukergrensesnitt. Men til gjengjeld er lyden mange ganger bedre, for ikke å snakke om alle lydinnstillingene som finnes. Min konklusjon er da at til tross for et knotete betjeningssystem, veier lydkvaliteten opp for det negative. Det er den som teller desidert mest for meg. Så lenge du klarer å skrive sms vil du nok sakte men sikkkert venne deg til iaudio også :)
9589499[/snapback]
Har faktisk en venn som har ventet i en måned på en Datamaskin fra komplett, og han venter fortsatt... Men hvis komplett.no får den inn snart, er det vel ikke lenge til noen andre også får den inn.
9590627[/snapback]
Da tror jeg at kommer til å klare å bruke en iAudio 7 :)
Har iAudio 7 og D2 samme innstilllinger når det gjelder lyd?
Tror alle cowon spillere har det. litt artig, har en tyggispakkespiller (iaudio u2) med 10 ganger flere lydinnstillinger enn de digre flaggskipspillerne til andre produsenter, now thats pwned :D
Noen som vet hva Enhanced Integrated Navigator betyr? Har litt lyst på iAUDIO 7, men likte ikke navigasjonen med mappestruktur på iAUDIO X5.
9597868[/snapback]
Kan ikke iAudio 7 velge mellom id3-tags og mappestruktur?
Endret av SRD
Er ikkje Cowon villig til å fikse denne dårlige navigeringa med ein firmwareoppdatering? Ellers vil du jo fort lære deg korleis det fungerer, på ein spelar til kun musikk er det ikkje så viktig å trykke heile tida.
CDON vil vel få inn spelarane etterkvart?
Har ein D2 sjølv, men kunne godt tenke meg ein liten spelar til trening ol.
Endret av Zeph
Cowon U2 ;) Tyggispakkespillernes konge :D
Endret av Slettet+89234341
9598111[/snapback]
Synd det er så liten plass på den :(
Enda ett bilde som viser størrelsesforskjellen:
link
Endret av SRD
9598111[/snapback]
link
9598186[/snapback]
hehe jo da, men mente i fobindelse med trening som det var snakk på. 2GB er mer enn nok for de fleste til slik, for meg funker det også på korte turer hit og dit, buss etc
