er cs2 sperra på 1 gb ram? (bruker maks 1 gb)
Sitat:
"Photoshop CS2 is a 32-bit application. When it runs on a 32-bit operating system, such as Windows 2000, Windows XP Professional, and Mac OS v10.2.8, it can access the first 2 GB of RAM on the computer. The operating system uses some of this RAM, so the Photoshop Memory Usage preference displays only a maximum of 1.6 or 1.7 GB of total available RAM. If you are running Windows XP Professional with Service Pack 2, you can set the 3 GB switch in the boot.ini file, which allows Photoshop to use up to 3 GB of RAM.
Important: The 3GB switch is a Microsoft switch and may not work with all computers. Contact Microsoft for instructions before you set the 3 GB switch, and for troubleshooting the switch. You can search on the Microsoft support page for 3gb for information on this switch."
http://kb.adobe.com/selfservice/viewConten...ternalId=320005
