Ståle Skrevet 24. november 2008 Del Skrevet 24. november 2008 Problemer med at 901en min henger seg, og skjermen blir hvit. Ser ut som PCI Interrupt. /home/user> dmesg | grep "PCI Interrupt" [ 13.811175] ACPI: PCI Interrupt 0000:00:1c.2[C] -> Link [LNKC] -> GSI 10 (level, low) -> IRQ 10 [ 13.811770] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11 [ 13.811781] ACPI: PCI Interrupt 0000:00:1c.3[D] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11 [ 14.166767] ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LNKA] -> GSI 3 (level, low) -> IRQ 3 [ 14.168314] ACPI: PCI Interrupt 0000:00:1f.2 -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11 [ 24.670632] ACPI: PCI Interrupt 0000:00:1b.0[A] -> Link [LNKA] -> GSI 3 (level, low) -> IRQ 3 [ 26.259221] ACPI: PCI Interrupt 0000:04:00.0[A] -> Link [LNKB] -> GSI 5 (level, low) -> IRQ 5 [ 14.510000] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 7 [ 14.510000] ACPI: PCI Interrupt 0000:00:1d.0[A] -> Link [LNKH] -> GSI 7 (level, low) -> IRQ 7 [ 14.620000] ACPI: PCI Interrupt 0000:00:1d.1 -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11 [ 14.730000] ACPI: PCI Interrupt 0000:00:1d.2[C] -> Link [LNKC] -> GSI 10 (level, low) -> IRQ 10 [ 14.840000] ACPI: PCI Interrupt 0000:00:1d.3[D] -> Link [LNKA] -> GSI 3 (level, low) -> IRQ 3 [ 15.640000] ACPI: PCI Interrupt 0000:00:1d.7[A] -> Link [LNKH] -> GSI 7 (level, low) -> IRQ 7 [ 41.870000] ACPI: PCI Interrupt 0000:00:1f.3 -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11 Lenke til kommentar
roy_nor Skrevet 25. november 2008 Del Skrevet 25. november 2008 Et kjapt spm: Hvordan duger 900Mhz dothan CPU'n til videoavspilling (848x480, audio 128kbps,video 23 fps 125kbps. Vi snakker altså Naruto/Bleach en gang i uka =) Ser på Asus eee 904 HD som passer perfekt med tanke på pris-lagringsplass-størrelse. Lenke til kommentar
Spectre Skrevet 25. november 2008 Del Skrevet 25. november 2008 Hva slags videoformat snakker vi om for filene? Videobitraten er vel litt lav? (mangler ett siffer?) Jeg vil tro det går greit, men den vil nok slite med høyere oppløsninger. Jeg har både 900 (Dothan) og 1000h. 900'en sliter på 720p media (x.264/mkv). 1000h klarer 720p greit. Lenke til kommentar
kromitt Skrevet 25. november 2008 Del Skrevet 25. november 2008 Kjøpte en 901 med Norsk tastatur og Norsk XP. Er det mulig få innstallert Engelsk XP med Windows lisens som følger med PC eller må en kjøpe Engelsk XP lisens utenom? Lenke til kommentar
joffe11 Skrevet 25. november 2008 Del Skrevet 25. november 2008 Hvordan tror dere Lenovos nye Ideapad http://www.digi.no/php/art.php?id=795560 er ift til Eee 1000H Lenke til kommentar
deaktivert443556 Skrevet 25. november 2008 Del Skrevet 25. november 2008 Kjenner jeg Lenovo riktig, så skal de vel bytte plass på Fn og Ctrl samt at de plasserer Esc over F1. Slike ting får meg til aldri å kjøpe Lenovo. I tillegg vil vel PCen fylles opp med standard Lenovo BloatWare. Positivt med støtte for 3G, men mangel på Bluetooth... huff. Jeg skjønner heller ikke helt hvordan det er "støtte for" 1,5 GB minne. Betyr det at det som standard er 1 GB, men at den er utvidbar til 1,5? I så fall må det jo være to spor til minnebrikker, og da burde det virkelig være mulig å kjøre 1 GB i begge disse. Faktisk så burde 2x2 GB være mulig, uten at jeg er veldig kjent med begrensninger på dette området. Lenke til kommentar
Eulogy Skrevet 25. november 2008 Del Skrevet 25. november 2008 (endret) Hvor lang batteritid er det på Asus 1000H? Noen som har byttet til større HD på den? Ifølge de fleste nettbutikkene som selger Lenovo Ideapad, så skal det være bluetooth på de maskinene. Endret 25. november 2008 av Eulogy Lenke til kommentar
deaktivert443556 Skrevet 25. november 2008 Del Skrevet 25. november 2008 Med WLAN holder batteriet ca 5 timer for meg. Lenke til kommentar
Eulogy Skrevet 25. november 2008 Del Skrevet 25. november 2008 Med nedsatt lys? Er det mye støy eller er den ganske stillegående? Lenke til kommentar
Dragonlove Skrevet 25. november 2008 Del Skrevet 25. november 2008 Satte inn en 2Gb rambrikke i min EEE 901, men i XP viser det bare 0,99Gb hva må jeg gjøre for at det skal vise 2? Lenke til kommentar
Spectre Skrevet 25. november 2008 Del Skrevet 25. november 2008 (endret) Hvor lang batteritid er det på Asus 1000H? Noen som har byttet til større HD på den? Jeg kan bekrefte ca 5 timers batteritid som nevnt ovenfor med WLAN/BT på og lysstyrken på ca 50%. Har lest på eeeuser at mange har byttet til 250 og 320GB disker, det er tilsynelatende helt uproblematisk, og påvirker visstnok ikke batteritiden i noen særlig grad. Satte inn en 2Gb rambrikke i min EEE 901, men i XP viser det bare 0,99Gb hva må jeg gjøre for at det skal vise 2? Har du prøvd å gå inn i BIOS'en for å sjekke at den oppdager minnet der? Endret 25. november 2008 av Spectre Lenke til kommentar
Zemeckis Skrevet 26. november 2008 Del Skrevet 26. november 2008 Hvor lett er det å bytte ut rambrikke på Eee 1000H? Er det bare å skru løs det dekselet under som man kan skru av? Lenke til kommentar
Spectre Skrevet 26. november 2008 Del Skrevet 26. november 2008 Det er bare å skru av dekselet under ja. Lenke til kommentar
bennybanan Skrevet 26. november 2008 Del Skrevet 26. november 2008 Har hatt asus ee 700 en stund no og tenkte å installere xp og se hvordan det gikk. Har laget meg en xp usb stick, men får ikke bootet fra den. Den finner den ikke, er det noe spesiell måte man må gjøre dette på? Lenke til kommentar
Spectre Skrevet 26. november 2008 Del Skrevet 26. november 2008 Ja, du må formatere usb sticken slik at den kan bootes. Det finnes mange guider for hvordan en kan gjøre dette om du googler litt. Se f.eks denne: http://wiki.eeeuser.com/windowsxpusb Lenke til kommentar
Zeph Skrevet 26. november 2008 Del Skrevet 26. november 2008 (endret) Nokon som har prøvd seg på justering av farger, konstrast og gamma på EEE? Det er for lyst og kalde fargar ved filmavspeling. Treng batteriet lang tid på å lade seg opp? Eg har hatt det på lading i heile natt, når eg lot den gå i 4-5 minuttar og såg film i dag så slo den seg heilt av, alt vart svart. Fekk ikkje skrudd den på igjen utan straumtilførsel. Same skjer no, eg får slått den på igjen, men den blir heilt svart, ingen lys, før Windows er oppe og går. Plugger eg den i går det fint. Endret 26. november 2008 av Zeph Lenke til kommentar
Minus Skrevet 26. november 2008 Del Skrevet 26. november 2008 Med mindre du har et uoriginalt batteri som er kjempestort, så skal batteriet være fulladet og vare i rundt 5 timer med halv belysning. Det er i hvert fall min erfaring. Lenke til kommentar
Zeph Skrevet 26. november 2008 Del Skrevet 26. november 2008 Byrjar å bli litt skeptisk her. Den slår seg av etter få minuttar dersom eg tar ut straumtilførselen. Windows informerer om at det er over 5 timar igjen. Får ingen advarsler opp. Plutseleg slår skjermen seg av, alle lys slokner og PC-en er ikkje til å få liv i utan å plugge i straumtilførsel. Lenke til kommentar
djgudleif Skrevet 26. november 2008 Del Skrevet 26. november 2008 (endret) Har en Asus EEE med 16 GB. Må få kjøpt minnekort snart. Innstallerte nettopp ubuntu! Boota fra minnepenna siden jeg ikke har skaffet noe eksternt CD-rom enda. Takla ikke xandros. Første gang med ubuntu! HELT RÅTT Så intelligent operativsystem... Uff... Blir helt sjokkert Endret 26. november 2008 av ikkespisgress Lenke til kommentar
deaktivert443556 Skrevet 26. november 2008 Del Skrevet 26. november 2008 Den slår seg av etter få minuttar dersom eg tar ut straumtilførselen. Mens du faktisk bruker den...? Du har ikke veldig spesielle strøm-innstillinger som gjør at den går i hvile-/dvalemodus etter kort tid når den går på batteri? Lenke til kommentar
