Ikke råd til å kjøpe en Hummer? Bygg din egen..
b-real
http://fullsizebronco.com/forum/showthread.php?t=25748
Hi guys
I’m new to this forum, as you can see,
I need your advise, this might be long. Since I’m a Ford nut but always wanted a Hummer but don’t have lots of money, I decided to fabricate my own base on Ford truck frame (I told you I’m a ford nut) right now I have a 1987 F150 4x4 and a 1991 E250 van. since I know the 8.8 rear won’t last long with 37” tire, I will used the 10.25
out of the van but I’m questioning the front, I’m not sure if I should just do a 8bolt swap to the TTB d44 or just swap the hole thing to a solid hd44
Kept in mind that I will not be rock crawling with it, it will be used as my daily driver and for pulling a car trailer. Fabrication for the SAS is not a problem for me
I found a scrap ward that as a good chose of axle that I can chose from
I know solid axles are better for offroad/rock crawling but what about ride quality?
I’m not worry about high-speed handling (how fast can you go with a brick wall after all!)
I know I don’t have a big bronco (I do have a 90BroncoII) but I ask these question on other
Ford truck forum but never got straight answers
You guy’s seen to know all about SAS vs TTB so your advise will be greatly appreciated
Ferdig resultat:
Brilliant...flere slike folk her i verden.
