Need advice concerning clocking
Hi i have a computer thats a bit old, upgraded bits here and there, and i was woundering if i could get some advice regarding how much i can do to it to make it better "clocking it not buying things" Because if i cant get it 500 mhz better atleast, im buying new hardware but that will take a while so, any advice would be appriciated. Currently using Artic cooling L2 on 3000 rpm for cpu coolant.
Processors Information
Processor 1 (ID = 0)
Number of cores 1
Number of threads 1 (max 1)
Name AMD Athlon XP
Codename Thoroughbred
Specification AMD Athlon XP 2400+
Package Socket A (462)
CPUID 6.8.1
Extended CPUID 7.8
Core Stepping B0
Technology 0.13 um
Core Speed 2020.1 MHz (15.0 x 134.7 MHz)
Rated Bus speed 269.3 MHz
Instructions sets MMX (+), 3DNow! (+), SSE
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 256 KBytes, 16-way set associative, 64-byte line size
FID/VID Control no
Features
K7 Thermal sensor yes
Chipset
Northbridge SiS 741GX rev. 03
Southbridge SiS LPC Bridge rev. 25
Graphic Interface AGP
AGP Revision 3.0
AGP Transfer Rate 8x
AGP SBA supported, enabled
Memory Type DDR
Memory Size 768 MBytes
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 6
Bank Cycle Time (tRC) 9
DIMM #1
General
Memory type DDR
Manufacturer (ID) Melco (7F7F7F8300000000)
Size 256 MBytes
Max bandwidth PC2100 (133 MHz)
Number of banks 1
Data width 64 bits
Nominal Voltage 2.50 Volts
Timings table
Frequency (MHz) 100 133
CAS# 2.0 2.5
RAS# to CAS# delay 2 3
RAS# Precharge 2 3
TRAS 5 6
DIMM #2
General
Memory type DDR
Manufacturer (ID) Kingston (7F98000000000000)
Size 512 MBytes
Number of banks 2
Data width 64 bits
Timings table
CAS# 2.0 2.5
RAS# Precharge 2 3
TRAS 5 6
Hardware monitor
Winbond W83697HF hardware monitor
Voltage sensor 0 1.65 Volts [0x67] (CPU VCore)
Voltage sensor 1 3.23 Volts [0xCA] (AUX)
Voltage sensor 2 2.90 Volts [0xB5] (+3.3V)
Voltage sensor 3 5.05 Volts [0xBC] (+5V)
Voltage sensor 4 12.71 Volts [0xD1] (+12V)
MOTHERBOARD HEAT 35°C (94°F) [0x23] (TMPIN0)
CPU HEAT 43°C (109°F) [0x56] (TMPIN1)
Fan sensor 1 3013 RPM [0x38] (FANIN1)
DMI BIOS
vendor American Megatrends Inc.
version P1.90
DMI System Information
manufacturer American Megatrends Inc.
product K7S41GX
version 1.0
DMI Processor
manufacturer AMD
model AMD Athlon XP 2400+
clock speed 2000.0MHz
FSB speed 133.0MHz
multiplier 15.0x
DMI Memory Controller
correction 32-bit ECC
Max module size 128MBytes
Endret av flexible_hold
You could start by trying to increase the fsb by 5 mhz at a time.
I dont think you have much to gain by tampering with the RAM speed or timings.
I hear the fat lady singing for that putter mate :-P
9527075[/snapback]
ye did that, think it wouldnt start straight after 200 mhz, what is it then if the computer wont start then when i try start it i get cmos error? xD fixed that after i took the battery out but what is that:P?
