Hente ut $_POST info fra loop
Heisann. Jeg lager et testscript på pure f. I scriptet skal man skrive inn Navn, URL, velge kategori og en beskrivelse. Hele scriptet fungerer i samkjør med en database og kategoriene hentes ut derfra. Når jeg har fylt ut feltene og valgt kateogri ble kategori-raden blank i databasen.
Tror feilen ligger i denne delen av scriptet:
if(!isset($_POST['add']))
			echo "<table width='29%' border='0' align='center' >";
            echo "<tr>";
			echo $text;
            echo "<td width='20%' height='25'>";
            echo "<form action='".$_SERVER['self']."' method='post'>";
            echo "Name: </td><td width='70%'><input type='text' size='45' name='name' value='" . $_SESSION['name'] . "'></td>";
            echo "</tr>";
            echo "<tr>";
            echo "URL: </td><td width='70%'><input type='text' size='45' name='url' value='" . $_SESSION['url'] . "'></td>";
            echo "</tr>";
			echo "<tr>";
			echo "Kategori: </td><td width='70%'>";
			// Find all categoryeis
			$catf = "SELECT cat_name, cat_id FROM cat ORDER BY cat_id DESC";
			$catfind = mysql_query($catf) or die(mysql_error());
			echo "<select name='category'><br />";
			while ($catrow=mysql_fetch_assoc($catfind))
				echo "<option value='".$catrow['cat_id']."'>".$catrow['cat_name']."</option>";
			mysql_free_result($catfind);
			echo "</select></td>";
            echo "</tr>";
			echo "<tr>";
            echo "<td width='20%' height='100'>";
            echo "Beskrivelse: </td><td width='70%'><textarea name='desc' rows='15' cols='45' >" . $_SESSION['desc'] . "</textarea></td>";
            echo "</tr>";
            echo "<tr>
            echo "</td><td width='70%'>";
            echo "<input type='submit' name='add' value='Legg til'></td></form>";
            echo "</tr>";
            echo "</table>";
// Getting the post info into normal vars for database use
				$_POST['name'] = $name;
				$_POST['url'] = $url;
				$_POST['category'] = $cat;
				$_POST['desc'] = $desc;
				// Insert all the info into the database
				$sql3 = "INSERT INTO link (link_id, link_title, link_url, link_desc, link_posted, user_id, cat_id) 	VALUES ('$iddd','$name','$url','$desc','$now','$userID','$cat')";
				$result3 = mysql_query($sql3) or die(mysql_error());
Hele scriptet: http://pastebin.com
(Har også problem med at
// Add one to get a new ID
                                       $stupid = 1;
                                       $iddd = $idd + $stupid
Ikke funker. Noen som veit hvorfor ikke iden blir økt med en? (Klipt ut av hele scriptet))
Endret av TheClown
Under den siste linjen du har postet:
var_dump($sql3);
Det er meget mulig at spørringen din ikke inneholder det du tror den vil gjøre. Dette på grunn av at
meget sansynlig skulle ha vært
$name = mysql_real_escape_string($_POST['name']);
$url = mysql_real_escape_string($_POST['url']);
$cat = mysql_real_escape_string($_POST['category'] );
$desc = mysql_real_escape_string($_POST['desc']);
Når det er sagt så er det et par grunnregler du bør lære deg:
1: Alltid feilsjekk informasjon som kommer fra eksterne kilder (også databaser) slik at du er sikker på at dette ikke er ting som kan ødelegge for deg
2: Bruk alltid beskrivende variabelnavn. Hvis du har flere spørringer så bruk gjerne tabellnavnet i variabelene som brukes til å behandle spørringen med. Variabler som $sql424 er veldig uheldige.
3: Når du skal feilsøke noe som mangler så legg til kall i skriptet som skriver ut verdiene underveis. På den måten så kan du finne ut hvor verdiene forsvinner.
Nei, nei :p
Jeg har skjekket databasene flere ganger, og jeg vet at den skriver riktig info. Problemet er det at jeg tror ikke at jeg har satt til $_POST ordentlig på kategori.
And IDen; En loop heter ut den høyeste IDen som finnes i databasen og slutter loopen (altså bare en løkke), så fører jeg databaseinfoen vidre til en vanelig variable. Så skal jeg legge til 1 slik at variablen blir en høyere enn det den orginalt var.
Problemet er bare det at loopen henter og skriver samme verdi, som akkurat nå er 10.
Endret av TheClown
// Get the highest ID from the database
                                       $idget = "SELECT link_id FROM link where link_id = (SELECT max(link_id) FROM link)"; $resultt=mysql_query($idget) or die(mysql_error());
                                       while ($roww=mysql_fetch_assoc($resultt))
                                               $idd = $roww['link_id'];
                                       mysql_free_result($resultt);
                                       $stupid = 1;
                                       $iddd = $idd + $stupid;
Loopen er unødendig?
PHP
<?php
$stupid = 1;
Gir vel samme resultat
Endret av Runar0
Jeg ville ha gjordt det slik, og sql ser unødvendig tungvint ut
PHP
<?php
$idget "SELECT max(link_id) id FROM link";
$idd=mysql_fetch_assoc(mysql_query($idget));
echo $idd['id'];
// evt hvis man ønsker maks id + 1
$idget "SELECT max(link_id)+1 id FROM link";
echo $idd['id'];
             echo "<tr>";
    echo $text;
             echo "</tr>";
             echo "<tr>";
             echo "</tr>";
    echo "<tr>";
             echo "</tr>";
    echo "<tr>";
             echo "</tr>";
             echo "<tr>
             echo "</tr>";
             echo "</table>";
Når du først skal skrive ut såpass mye HTML-kode, lønner det seg å benytte seg av EOF, eller heredoc.
Lite eksempel:
PHP
<?php
$minVariabel "Hei på deg din sei!:)";
$output = <<<EOF
<html>
<head>
<title>PHP-testside</title>
</head>
<body>
<h1>$minVariabel</h1>
<br>
<h2>$minVariabel</h2>
<br>
<p>$minVariabel</p>
</body>
</html>
EOF;
echo $output;
Kan være greit å legge ved en link til en eller flere sider om forklarer litt mer on hva EOF/Heredoc gjør for noe. Jeg fant denne: http://en.wikipedia.org/wiki/Here_document
Men vil ikke <pre> tagen gjøre det samme ?
Jeg pleier alltid å bruke \n (linjeskift) for å gjøre kildekoden mer lesbar, men dette ser ut til å være en enklere metode, lært noe i dag og :)
Endret av crowly
