Peter Logan's exploding paste
toth
http://gprime.net/board/showthread.php?t=3724
To make Peter Logan's Exploding Paste:
First of all, you need only two ingredients: Iodine crystals and Ammonium Hydroxide.
You can get the iodine at drug stores and pharmacies (you may have to sign for it). Even if you can get pure ammonium hydroxide, you probably don't want it - it's purity affects the strength of the explosive, and you don't want the result to be blowing the wall of your house off.
Very strong household ammonia water will do OK, but it must be clear - if it's cloudy, it won't work.
OK, now we're on to the making.
1. It's a good idea to crush up the iodine crystals - this will make them react faster.
2. Put two tablespoons of the crystals into a glass or pyrex container that will hold at least 500ml..
3. Now add about 100ml of the ammonium hydroxide. You should always add a little more than you need here - if you add too much, it won't affect the outcome, but if you add too little, it will be incomplete.
4. You want to stir the mixture for about ten minutes. If all goes to plan, you should see some bubbles of Hydrogen being given off. When these bubbles stop, the reaction is over.
5. Leave your mixture for about 5 minutes to make sure everything's completely done, and you should see some stuff at the bottom of your container. This is your paste, which can be separated by pouring the whole lot through filter paper. Don't worry about damaging your funnel - the liquid you're getting rid of is just water now.
6. The paste should dry after about an hour, so if you want to keep it, store it with a little water (to keep it damp) in an airtight tin.
7. Remember, if you store it too long, it will decompose!
OK, that's it
Noen som har lyst å ta denne på norsk?
Etter hva jeg forstår er det snakk om ren jod og amoniakk?
Hvis noen kan lage en norsk guide av dette, gjerne med tips om hvor man får ingredienser, hadde det vært flott! :D
Den har jeg tolket i første post som du ser.. Det jeg ville her var mest bare norske former av og merker/forhandlere på ingrediensene.
Grunnen til å få hele oversatt av en som kjenner nevnte detaljer var helst for enkelhets skyld, og slik at den posten kan ha nytte for flest mulig.
(Forresten har språkkunnskaper og kunnskaper om eksplosiver ingenting med hverandre å gjøre, som et tips. ;) )
Endret av toth
Hva om min foretrukne form for å finne ut av det jeg ønsker er å spørre her? Er det fryktelig galt av meg?
Obviously.. :whistle:
9518770[/snapback]
Poenget med dette er at ved å la deg søke deg frem til det selv vil du sannsynligvis plukke opp masse nyttig informasjon på veien :)
Så langt jeg vet (du har ikke gitt uttrykk for noe annet) har du lite peiling på eksplosiver, og å da gi deg en oppskrift rett i hånden ville vært mindre smart. Da er det bedre at du bruker litt tid på det.
Som sagt har jeg jo allerede oppskriften, den står i første post..
Jeg har nå lekt min share med ymse "artige ting å lage i hjemmet" opp igjennom.
Nå var uansett ikke dette noe jeg i første omgang hadde planer om å lage, mer nysgjerrighet etter å ha sett det på Brainiac. Er strengt tatt mer interessert i kunnskapen om "produktet", enn i selve pastaen.
Det jeg reagerte på var at du i føste post spesifikt spurte etter hva disse produktene heter på norsk og hvor man eventuelt kunne få tak i de.
Nyskjærrighet er fint og man kan lære mye av kjøkkenbenk-kjemi. Men som nevnt tidligere; man lærer enda mer ved å jobbe seg gjennom prosessen som det er å komme fram til informansjonen. Dette er ikke riktig forum for en detaljert "kokebok-oppskrift" med norske produktnavn og tilgjengelighet. Det er mange unge mennesker her som for kaster seg over noe som virker kult uten å vite nok av konsekvensene som små variasjoner i et slikt eksperiment kan føre til.
Du virker som du har nok erfaring og kunskap til å finne ut av dette selv uten at noen her skal behøve å gi deg og andre enkle snarveier.
laboratorieutstyr?? Var vel ikke så mye utstyr som trengtes her utenom ting man finner på kjøkkenet?
9519650[/snapback]
Har laget diverse ting med mammas glassboller, plastbeger osv., men det er ikke å foretrekke ;)
Snakker ikke om avansert labutstyr, bare beger/kolber i borosilikat, rørepinner osv.
meget ustabil substans som ikke burde håndteres av uerfarne
9517098[/snapback]
Det er denne som er stabil når den er våt, men med en gang den tørker, kan den eksplodere av selv den minste vibrasjon?
9520930[/snapback]
Jess, det er stabilt vått men når det tørker kan et godt produkt nærmest detonere av egen vekt.
Man skal ikke søle med det heller, når det da tørker har man mange flekker superfølsomt sprengstoff rundt i rommet..:)
